![]() If your software has it how much are you using this feature? Do you tend to use it more than traditional MC/ballast/bugs settings for final glide calculation? I am suspicious of usefulness of this feature in fast changing conditions. What is your experience? AK |
On Dec 24, 7:26 pm, AK wrote:
If your software has it how much are you using this feature? Do you tend to use it more than traditional MC/ballast/bugs settings for final glide calculation? I am suspicious of usefulness of this feature in fast changing conditions. What is your experience? AK I use SeeYou Mobile and rely on L/D achieved a lot. But it is not either or, you use both and just because there is a display of L/D achieved in a nav box nothing else on the display has changed so I'm not sure what the concern would be - go try it out for yourself. If you think the achieved L/D is temporary and want to ignore it just do so. See a consistent bad L/D and think you are in a big hole of bad stuff or the wind is being unkind and want to assume it keeps going that way then do that instead. Want to split the difference do that. Want to ignore the stupid computer then do that. And achieved L/D has the beauty of being simply derived from raw GPS data and is unlikely to be wrong - and if nothing else when conditions are suitable you want to make sure that your polar calculated numbers and achieved L/D converge. Within reason having more sources of data is a good thing. What you do with that data to turn it into actionable information is what matters. Darryl |
At 03:30 25 December 2007, Ak wrote:
If your software has it how much are you using this feature? Do you tend to use it more than traditional MC/ballast/bugs settings for final glide calculation? I am suspicious of usefulness of this feature in fast changing conditions. What is your experience? AK The SeeYou mobile the manual recommends flying final glides by comparing the required L/D ('Req L/D') with the flown L/D ('Cur. L/D'). There are 3 things to be aware of: 1) L/D is a misnomer in this context - the figures are glide angle with respect to the ground. 2) You need to use a separate measurement to indicate when you are within range before you start the glide - ie to determine the starting required glide angle. 3) The 'Cur L/D' varies dramatically above and below the 'Req L/D' as you fly through lift and sink and so it is almost impossible to compare Crrent and Required L/Ds in a short time frame. However you can use these features very usefully - albeit not quite as the manual says: 1) When approaching final glide height monitor your arrival height with whatever buffer you choose and when you start the glide take note of the Req L/D - this is the glide angle from the start of the glide to the finish point. NB this *is* dependent on the accuracy of your polar, bugs, wind calculation but it gives you a best guesstimate of when to start the glide. 2) During the glide monitor the Req L/D and if that number is getting larger you are falling below glide - if so you can choose to back off the McReady setting until you have your buffer height achievable again and monitor the new Req L/D. The same in reverse if your Req L/D number is getting smaller and you are gaining on glide. The advantage of flying glides by angle rather than by the usual way is that it is entirely pragmatic and gives good information irrespective of errors in bugs, polar and wind. You are now finding out what you can actually achieve on the glide. Also if you fly final glides in the conventional way with an arrival height buffer then you are flying parallel to the best achievable glide angle towards your height buffer - i.e any extra height above the buffer gets proportionately larger as you get closer to home. If you fly by angle then the Req L/D at you current McReady setting converges vertically on the best achievable glide angle towards your height buffer. So I think the glide angle method is both more confidence inspiring and less wasteful. You can still compare Cur and Req L/Ds but that is only meaningful in areas free of vertical air movement. John Galloway |
Thank you both for your reply. I like John's approach which is
"validation" of traditional calculation which can be as much science as it is art. |
Note that some Garmin GPSes (e.g. my GPSmap 60CS, which also has a
barometer) can display "Glide Ratio" and and "Glide Ratio to Destination". I find the latter most useful, monitoring whether it is increasing or decreasing during a glide to an airport as well as keeping track of whether an airport is within glide range. The "Glide Ratio" value is not as useful, since the averaging time is rather short so the display varies considerably and "mental averaging" must be done. (BTW, to aid in using the "Glide Ratio to Destination" I have added 1000 feet to the airport elevations in my database.) We don't need no stinkin' PDAs! :-) Jack |
On Dec 24, 8:26*pm, AK wrote:
If your software has it how much are you using this feature? Do you tend to use it more than traditional MC/ballast/bugs settings for final glide calculation? I am suspicious of usefulness of this feature in fast changing conditions. What is your experience? AK I don't use Flown L/D very much, but use Required L/D a lot. After awhile, you get a good feel for what your glider can do in various conditions. For example, in my LS6 I'm happy when I have 25/1 to the place I want to land at (and I use L/D to the field elevation to prevent weird numbers showing up at close ranges). 30/1 is good for starting a long final glide. 35/1 is iffy but close. Makes keeping track of landable fields easy at a glance, and makes a nice cross check during climb to final glide and during the glider. Kirk 66 |
SeeYou task settings | Tuno | Soaring | 7 | February 22nd 07 03:51 AM |
New DMSt task: 4 TPs | Klaus T. | Soaring | 0 | January 9th 06 12:03 AM |
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione | Steve Leonard | Soaring | 2 | September 14th 05 03:49 AM |
1000k comp task | Mel Dawson | Soaring | 0 | July 5th 05 08:22 PM |
New Task | JJ Sinclair | Soaring | 5 | October 23rd 03 01:36 AM |
