737 Blown Across Ramp
Old December 28th 07, 01:35 AM posted to rec.aviation.piloting
Jim Macklin
Default 737 Blown Across Ramp
Brakes should not be used to secure an airplane that is not attended, always
use chocks. An airline class airplane might be secured in strong winds with
chocks and a heavy tug with the tow bar.
"Matt Whiting" wrote in message
| Phil wrote:
| I know they call it the Windy City, but this is ridiculous...
http://www.aero-news.net/index.cfm?C...-86c169181d87&
| Phil
| What do you want to bet that the brakes weren't set?
| Matt
Old December 28th 07, 01:47 AM posted to rec.aviation.piloting
Mike Noel
Another reason to rely on chocks instead of brakes is the unreliability of a
hydraulic parking brake. The pressure can bleed off and release the brake
after a bit. So the mistake might have been setting the parking brake
instead of using chocks.
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
Phil
Matt
Old December 28th 07, 02:14 AM posted to rec.aviation.piloting
Matt Whiting
Robert M. Gary wrote:
On Dec 27, 1:14 pm, Matt Whiting wrote:
http://www.aero-news.net/index.cfm?C...642-d205-411d-...
Phil
That would be odd. Why would the brakes be set if no one was on board?
Makes it a bit tough to tow.
Uh, to keep the wind from blowing it around? :-)
Old December 28th 07, 02:15 AM posted to rec.aviation.piloting
Matt Whiting
On Dec 27, 1:55 pm, wrote:
So it doesn't roll away in the wind all on it's own with no one on board?
Or, if they were expecting to tow it in the immediate future, where were
the chocks to make sure it doesn't roll away in the wind all on it's own
until they got around to towing it?
While its possible that someone does it, I'm not aware of any operator
that sets the brake on aircraft when its not occupied. Usually chalks
work just fine and are easier to move when you need to tow. In smaller
aircraft there are other reasons to avoid setting the brake, like
changes in outside pressure could burst the brake seals.
Are chalks anything like chocks?
Matt
Old December 28th 07, 02:16 AM posted to rec.aviation.piloting
Matt Whiting
On Dec 27, 3:18 pm, "Bob Gardner" wrote:
Chocks, Robert, chocks. Use your dictionary.
How do you know I don't use chalks?
Given your demonstrated knowledge about parking aircraft ... I suspect
that you do use chalks.
Old December 28th 07, 02:25 AM posted to rec.aviation.piloting
Since the biggest change in outside pressure that is likely to happen
is on the order of a pound and the working pressure in brakes is at
least an order of magnitude greater than that, I find it highly unlikely.
Perhaps if one were to land after extended flight at 10,000 feet at
Tucson in the middle of summer, the drastic temperature change might
have an effect, but I doubt it.
I've heard this many times and yet can imagine no situation other than
maybe leaving the brakes on for months at a time where it would do anything.
Any wrenches out there with real experiance feel free to contridict.
Jim Pennino
Remove .spam.sux to reply.
Old December 28th 07, 03:16 AM posted to rec.aviation.piloting
F. Baum
-Robert
Robert, out of everyone so far you are the closest. The brakes are
released as soon as the chalks in signal is recieved. This is mainly
done to facilitate brake cooling because airlines typicaly work with
45 minute turn times and leaving them set would greatly increase QTA
The brake temp actually peaks about 10 minutes after landing .the fuse
plugs can melt if the brake are left set . The 737 has a brake
acumulator which will sufice for several parking brake applications,
but chalks are still used for safety reasons . Just before push the
process is reversed, The parting brake is set before the tug is hooked
up and the chalks removed. Someone ask about brake pressures; the A&B
hydraulics run at 3000 LBS which is reduced to 300 at the gear (In the
event of a leak this prevents a total loss of fluid) I was not able to
open the link but I hope this helps.
FB
Old December 28th 07, 03:20 AM posted to rec.aviation.piloting
RST Engineering
Anyone who watched the Bears game on Sunday and saw Brent Fabre say that it
was the coldest game he'd ever played it knows that it was an absolute ice
rink at Midway. You could have set those brakes at a thousand psi and that
sucker would have fancydanced across the ice in that wind.
No chocks, only tiedowns could have kept that aircraft from moving.
"If you think you can, or think you can't, you're right."
--Henry Ford
"aluckyguess" wrote in message
Phil
-Robert
I hear chalks fix the problem.
Proof FAA Managers are full blown certified IDIOTS SOS Instrument Flight Rules 1 December 1st 07 05:05 AM
Proof FAA Managers are full blown certified IDIOTS SOS Piloting 1 November 29th 07 07:44 PM
Ramp riders 5 Paul Aviation Photos 0 November 19th 06 10:09 PM
MMU ramp fee Peter Gottlieb Piloting 25 August 9th 03 12:49 AM
Flight TWA 800 was shot down/blown up by Al Quadea? Tiger Military Aviation 0 July 3rd 03 05:38 PM
