737 Blown Across Ramp
Old December 28th 07, 08:28 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
Default 737 Blown Across Ramp
RST Engineering wrote:
No chocks, only tiedowns could have kept that aircraft from moving.
Chocks aren't perfect. At my home field we often get violent downbursts
from thunderstorms in the summer. Peak gusts of 60-70 kts aren't unusual. I
use both chocks and tiedowns, and I've found that after a particularly bad
storm, the chocks were often blown away from wheels and the plane was sitting
slightly sideways with the tiedowns pulled tight.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200712/1
  #33
Old December 28th 07, 09:49 PM posted to rec.aviation.piloting
Robert M. Gary
On Dec 28, 12:05*pm, Bertie the Bunyip wrote:
"Robert M. Gary" wrote in news:5d5a8261-1459-465f-9e7e-
On Dec 27, 10:32*pm, Bertie the Bunyip wrote:
The best reason I can think of for not relying on the parking brake in a
wind is that they are not very reliable. Schwinn could make a better
arrangement than you see on most Cessnas, for instance.
Brakes are next to useless in very high winds anyway. After all, if the
wing is being lifted....
I've never had occasion to stand on an airplane's brake but when I use
the same amount of foot pressure on my Mooney as in my Saturn the
Saturn will stop in 1/2 the distance.
Well, you have twice the wheels, dontcha?
But about 1/2 the weight. The Saturn weights 4300 lbs.
-Robert
  #34
Old December 28th 07, 10:17 PM posted to rec.aviation.piloting
F. Baum
* Chocks aren't perfect. *
They may not be perfect but close. The chocks typicaly used on
airlines could have prevented this. There are no provisions for tying
down a jet. The 737 manual does recommend leaving the parking brake
set in windy conditions.
Message posted via AviationKB.comhttp://www.aviationkb.com/Uwe/Forums.aspx/aviation/200712/1
  #35
Old December 28th 07, 11:21 PM posted to rec.aviation.piloting
Rich Ahrens[_2_]
Not to mention we're talking winter here. I've been at the controls of a
172, engine idling, foot brakes fully applied, and been pushed sideways
across an icy ramp by the wind. Found out later a Citation (I think -
some small bizjet) had slid off a taxiway. In Iowa, no less. Proving it
not only sucks there, it also blows...
  #36
Old December 28th 07, 11:36 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
brake in
a
better arrangement than you see on most Cessnas, for instance.
if the
use the same amount of foot pressure on my Mooney as in my Saturn
the Saturn will stop in 1/2 the distance.
-Robert
He heh. I was only kidding. it's an apples oranges thing anyway.
Bertie
  #37
Old December 28th 07, 11:37 PM posted to rec.aviation.piloting
Rich Ahrens wrote in
ouse.com:
in a wind is that they are not very reliable. Schwinn could make a
the wing is being lifted....
a 172, engine idling, foot brakes fully applied, and been pushed
sideways across an icy ramp by the wind.
Wow, you're almost like a seaplane in those conditions.
think - some small bizjet) had slid off a taxiway. In Iowa, no less.
Proving it not only sucks there, it also blows...
Bwawhahwhahwhhahwh!
Bertie
  #38
Old December 28th 07, 11:57 PM posted to rec.aviation.piloting
"F. Baum" wrote in
hmm, I think you may be mistaken about the tie down provisions. I've never
seen anthing except the tug/towbar thng you mentioned, but I think some may
have a spot where a ring can be screwed in , maybe where the hardpoints for
the jacks go. I'll ask the guys next chance I get.
Bertie
  #39
Old December 29th 07, 04:50 PM posted to rec.aviation.piloting
Matt Whiting
F. Baum wrote:
On Dec 27, 4:18 pm, "Bob Gardner" wrote:
While its possible that someone does it, I'm not aware of any operator
that sets the brake on aircraft when its not occupied. Usually chalks
work just fine and are easier to move when you need to tow. In smaller
aircraft there are other reasons to avoid setting the brake, like
changes in outside pressure could burst the brake seals.
-Robert
Robert, out of everyone so far you are the closest. The brakes are
released as soon as the chalks in signal is recieved. This is mainly
done to facilitate brake cooling because airlines typicaly work with
45 minute turn times and leaving them set would greatly increase QTA
The brake temp actually peaks about 10 minutes after landing .the fuse
plugs can melt if the brake are left set . The 737 has a brake
acumulator which will sufice for several parking brake applications,
but chalks are still used for safety reasons . Just before push the
process is reversed, The parting brake is set before the tug is hooked
up and the chalks removed. Someone ask about brake pressures; the A&B
hydraulics run at 3000 LBS which is reduced to 300 at the gear (In the
event of a leak this prevents a total loss of fluid) I was not able to
open the link but I hope this helps.
FB
Chalks. Ha, ha, ha... That is hilarious.
Proof FAA Managers are full blown certified IDIOTS SOS Instrument Flight Rules 1 December 1st 07 05:05 AM
Proof FAA Managers are full blown certified IDIOTS SOS Piloting 1 November 29th 07 07:44 PM
Ramp riders 5 Paul Aviation Photos 0 November 19th 06 10:09 PM
MMU ramp fee Peter Gottlieb Piloting 25 August 9th 03 12:49 AM
Flight TWA 800 was shot down/blown up by Al Quadea? Tiger Military Aviation 0 July 3rd 03 05:38 PM
