#101
Gene Nygaard wrote:
Based on our review, we made eight recommendations intended to improve the use of the metric system within NASA in accordance with national policy and NASA guidance. We recommended NASA: • reexamine the Agency’s effort to convert to the metric system and develop a new approach for converting to the metric system, • closely monitor technical interfaces between metric and English units, • reinvigorate the metric waiver system, and • use the metric system as the preferred system for interactions with the public Gene Nygaard Sounds pretty official to me... -- -Gord. |
#102
"Tarver Engineering" wrote...
If we left things alone, instead of being globalist egotistical loons, these problems would not occur. If we left things alone, we would not progress. |
#103
When we engage in industry, we must use the language of that industry, as well as the existing infrastructure. A big part of training to do engineering is to apply a reference and measurement system applicable to the problem. Aerospace is expressed in feet, pounds, clockwise and attempts to use alternative SI units have resulted in problems. The aerospace industry developed first and foremost in the USA. Before there was such a thing as "aerospace," the fuel and aviation industries evolved with a preference for measuring liquid fuels such as gasoline and kerosene in gallons. By your argument, aerospace should measure fuel in gallons. |
#104
Hi
You all might want to read the story below about the Gimli Glider. http://www.flightsafety.org.au/articles/t0357.php Here's an extract from the above. Cheers...Chris The flight from Montreal to Edmonton, including a brief stop in Ottawa, required 22,300kg of fuel, an amount expressed as mass because of the importance of knowing an aircraft's weight. The mechanics needed to work out how many litres made up 22,300kg. They could then subtract the 7,682 litres already in the tanks, and use the fuel gauge on the refueling truck to tell when they had reached the right number of litres to make up 22,300kg. But the 767 was the first aircraft in Air Canada's fleet to use metric units (kilograms) rather than imperial (pounds). Metric units were being phased in across Canada, and the conversions were still causing confusion. With the help of First Officer Quintal, the ground crew used the correct procedure to calculate the weight in kilos. However, they had not been trained in correct conversion, so the figure of 1.76 provided by the refueling company on their refueling document, was taken to be the required multiplier. It was typical of the numbers seen on previous slips and they assumed that the numbers provided over the previous few months had indicated specific gravity in the new metric system. They decided to multiply 7,682 by 1.76. This would mean 13,597kg remained in the tanks, requiring an infusion of 8,703kg to bring the fuel level up to 22,300kg. They then divided 8,703kg by 1.76, assuming that this conversion would give them the correct volume in litres. Through this calculation, the crew determined that 4,916 litres needed to be added from the fuel truck. The problem was that 1.77 is the multiplier that converts litres into pounds, not kilograms: to convert litres into kilograms you need to multiply by 0.8. Flight 143 did not have 22,300kg on board, it had about 10,000kg, less than half the amount of A-1 kerosene jet fuel needed to get the aircraft to Edmonton. The refueller didn't know where the flight was headed, so no alarm bells rang for him as he poured fuel into the tanks. Using a computer to calculate fuel also caused confusion over responsibilities. In the past, when fuel was calculated manually, a flight engineer's duties included checking the fuel load. Flight engineers were a thing of the past on this 767, as a Presidential task force, under Ronald Reagan, had determined that aircraft could be built to be operated by two pilots instead of three, if the tasks previously given to the second officer (flight engineer) were either fully automated or handled by ground staff. Responsibility for ensuring adequate fuelling had passed to the maintenance branch. But because these men were not trained to calculate fuel, they assumed the pilots would make sure it was done properly. The problem was neither of the pilots was trained in this technical task. Safety procedures had failed to keep pace with new technology. As the investigation later concluded: 'Air Canada ... neglected to assign clearly and specifically the responsibility for calculating the fuel load in an abnormal situation.' The investigation attacked Air Canada's training procedures, noting 'both flight crew and maintenance personnel seemed to be somewhat mesmerised by the complex, computerised characteristics of the 767. They did not appear to have sufficient background knowledge of these aspects of the aircraft. They did not appear to have received sufficient training about some of the critical aircraft systems, in particular, the fueling system.' |
#105
Wait. How about the 100, 200, 400, etc. meter swim and track and field
races? Not to mention the world altitude flying records, which are in meters. And more and more... John Keeney wrote: But nobody weighs things in "grams", it's always "kilograms". Nor do the measure things in "meters" (as was stated concerning building a house) they measure in "milimeters". |
#106
snip All fuel is bought as weight, that is how an aircraft works. The fact that you pay for volume is a book keeper's issue. I have never seen anyone buy avgas by weight for small GA aircraft like the Cessna 172. Dan, U. S. Air Force, retired |
#107
#108
Tarver Engineering wrote:
Why change from the units of aerospace to some other arbitrary set of units in the first palce? That question does not parse. The problem is not a 'change' from setA to setB. The problem is multiple units for the same thing. UnitX coexists with unitY (and perhaps unitZ). You may wish to ask: Q1. "Why do we want to reduce the co-existence of multiple units for the same thing?" Q2. "If that is what we want, then which ones should be eliminated in which circumstances?" The units of aerospace are controlled by Annex 5 of the ICAO Chicago convention. "The standardized system is based on the International System of Units (SI) and will eventually eliminate the use of different units of measurement for the same quantity and provide for the standardized application of all units of measurement for those quantities used in air and ground operations. It is nevertheless necessary to retain for the foreseeable future the use of some commonly used non-SI units [in parallel with SI units], such as the foot [in parallel with the metre] for the measurement of altitude. www.icao.int/icao/en/pub/memo.htm Over a long period, the problem is being resolved. The trend is towards metric, not away from it. North American aviation converted from F to C in 1996. US military airports now give Terminal Area Forecast visibility in metres. All without a fuss. Similarly there was no fuss in British and Irish aviation when they dropped the use of many imperial units. The units used in aviation in Britain and most most countries are now: nautical mile = long ranges (navigation) ....spoken as 'mile' metre, cm, mm = short range (visibility, runway length, rain, snow) foot = altitude knot = horizontal speed ft/min = vertical speed hPa = pressure °C = temperature kg, metric ton = weight litre = fuel volume statute mile, fahrenheit = not used Why is anyone working in NASA Operations that does not know aircraft units? One of the more bizarre features of NASA is that they quote height in nautical miles. |
#109
#110
On Fri, 24 Oct 2003 20:51:10 +0200, Andreas Parsch wrote:
Alan Minyard wrote: Actually, the unit of mass is the gram. Of course the gram is a unit of mass, but it's not _the_ unit (depends on the definition of "_the_" ;-) ). All I said is that the kilogram is used in SI to derive units, and not the gram (as in 1 N = 1 kg m / s^2). Andreas I look at it as "a kilogram is 1,000 grams, therefore the underlying "unit" of mass is the gram". Simply a matter of semantics, and I suppose that the two definitions are interchangeable. :-) Al Minyard |
| Bush's guard record | JDKAHN | Home Built | 13 | October 3rd 04 10:38 PM |
| Space Elevator | Big John | Home Built | 111 | July 21st 04 05:31 PM |
| U.S. Troops, Aircraft a Hit at Moscow Air Show | Otis Willie | Military Aviation | 0 | August 28th 03 11:04 PM |
