Harley oil cooler for interior heat.
Old December 26th 07, 11:52 PM posted to rec.aviation.homebuilt
Default Harley oil cooler for interior heat.
I don't have heat inside my canard plane. Now am considering piping
hot engine oil to the cabin through a small oil cooler with a blower.
I am looking at a Harley Dyna oil cooler - about the right size. My
question is whether such a cooler will stand the typical aircraft oil
pressure. My engine oil pressure goes up to about 80 psi when cold
then goes down to about 60 psi. I have seen Harleys with oil cooler
pressure gauges 60psi. But shouldn't they have an extra safety stress
factor?
Any bike experts out there?
I already had an engine heat exchanger with the fan there that I tried
but there was too much CO coming through - so I removed the air
plumbing.
SQ2000 http://www.abri.com/sq2000
Old December 27th 07, 01:02 AM posted to rec.aviation.homebuilt
Morgans[_2_]
factor?
It seems like I recall someone saying that the oil cooler did not put out
enough heat in the winter to be very useful.
It would seem like the bike cooler would be tough enough. I would use it,
but put two in line petcocks in the line to bypass the cooler, and put them
where you can reach it while you are flying. If it did leak, you could turn
it off, but as big of a consideration is the fact that you will not want to
be using it in the summer, anyway!
Jim in NC
Old December 27th 07, 04:31 AM posted to rec.aviation.homebuilt
Bill Daniels
"Morgans" wrote in message
factor?
them where you can reach it while you are flying. If it did leak, you
could turn it off, but as big of a consideration is the fact that you will
not want to be using it in the summer, anyway!
Jim in NC
Not enough heat? Try flying a GLIDER at -50F. Can you say, "electric
socks"?
Old December 27th 07, 05:11 AM posted to rec.aviation.homebuilt
"Bill Daniels" bildan@comcast-dot-net wrote in message
socks"?
Bill,
That is why I do my glider maintenance in the winter. Wave flying is just
to cold for my old bones.
HP-14 "6F"
http://www.soaridaho.com/Schreder
Old December 30th 07, 01:30 AM posted to rec.aviation.homebuilt
XYZ
Why go to all the plumbing hassles, use electric heat, cheaper, lighter,
safer....
Have a great day
Scott
"Anthony W" wrote in message
news:wTCcj.2631$si6.495@trndny08...
factor?
plumbing.
That same cooler is sold for other bikes that have higher oil pressure.
Harleys usually only have 4 or 5 PSI oil pressure because the roller
bottom end doesn't need pressure only volume. My local VW shop has plate
type oil coolers much cheaper than the Harley ones. It wouldn't hurt to
check out your local VW shops and auto parts stores then there's always
aircooled.net .
Tony
Old January 1st 08, 11:37 PM posted to rec.aviation.homebuilt
Kyle Boatright
I have never heard anyone who was happy with the little quartz heaters
typically used in EZ's and the like. The concensus seems to be that the
amount of heat put out is very limited and consumes an enormous (at least
from a GA perspective) amount of electricity.
"XYZ" wrote in message
safer....
Have a great day
Scott
factor?
plumbing.
aircooled.net .
Tony
Old January 2nd 08, 07:46 PM posted to rec.aviation.homebuilt
Dan Youngquist
safer....
Because a (for example) 80 amp alternator puts out only a nominal 960
watts at 12v. Even if you could use all that for heating -- which of
course you can't -- it would be a pretty anemic heater.
-Dan
Old January 2nd 08, 09:59 PM posted to rec.aviation.homebuilt
As the original poster that was my problem too. I only have a 60A
alternator and could not afford the heat from a typical fan heater. I
need that alternator for important things - like keep flying.
safer....
-Dan
Oil Cooler Al Girdvainis/Penni Abram Home Built 0 November 26th 04 01:28 AM
Metal in the Oil Cooler Justin H Home Built 4 August 18th 04 11:28 AM
Oil cooler? Rick Home Built 1 March 22nd 04 09:41 AM
harley engine Air Methods Corporation Home Built 1 September 21st 03 08:13 PM
