Cleveland...Or Tost?
Old January 3rd 08, 06:35 PM posted to rec.aviation.soaring
Paul Hanson
Default Cleveland...Or Tost?
A Happy New Year to All! I am thinking about getting
a hydraulic disc conversion wheel/brake for my SZD-59.
I have not heard anything bad about Cleveland setups,
and have not anything bad the Tost equivalents either.
Both setups can/have been done. Both being about the
same price (read expensive), and both the same amount
of work to install, naturally I want the better of
the two. I hope this is not a religious war subject,
I just want to hear more opinions and I know there
are a few of those here...
Paul Hanson
"Do the usual, unusually well"--Len Niemi
Old January 3rd 08, 07:22 PM posted to rec.aviation.soaring
On Jan 3, 10:35*am, Paul Hanson
Paul Hanson
If you want it to stop Cleveland.
Al
Old January 3rd 08, 07:24 PM posted to rec.aviation.soaring
Andy[_1_]
On Jan 3, 11:35*am, Paul Hanson
I'd start by asking which brand current new sailplanes use.
Schleicher seems to have gone with Cleveland (ASW-28).
I'd also ask about price and availability of consumables. In 5 years
I have never needed to do anything to the brake on my 28 but I think
the Cleveland brake pads are easy to get.
It would be hard to fault the 28 brake. It's powerful, progressive,
does not drag, and needs no maintenance.
Andy
Old January 3rd 08, 07:49 PM posted to rec.aviation.soaring
What Al said.
Cleveland brake is reliable, parts are readily available and braking
power is unsurpassed. I believe everything AS-W since the -20B came
with 500x5 Cleveland and I retrofitted one to my AS-W12 as well.
Old January 3rd 08, 09:14 PM posted to rec.aviation.soaring
Tim Mara
after reading many of the responses to your message, typically never 100%
correct, what most don't realize is that most of the TOST Hydraulic brake
systems are, and most of the system parts used by the glider manufacturers
supplied to them by TOST are in fact......"Cleveland" Brake parts.....only
with some modifications by TOST, usually to change the fluid type to(DOT 4
brake fluid rather tan Hydraulic fluid)...What TOST has done has assemble
the brakes along with the brake components to make up the kit that is used
on gliders.
see my website page for some available kits on
http://www.wingsandwheels.com/page32.htm
tim
"Paul Hanson" wrote in message
Paul Hanson
Old January 3rd 08, 11:20 PM posted to rec.aviation.soaring
Peter Thomas
relining my 5' Tost drum brake shoes with a modern
compound(eg vintage motocycle racing) worked for me
(£25 and a friend sized them)
Pete
Paul Hanson
'Do the usual, unusually well'--Len Niemi
Old January 3rd 08, 11:42 PM posted to rec.aviation.soaring
hans
Schempp-Hirth and Lange offer now the Beringer brakes
http://www.beringer.fr/
Paul Hanson
Old January 4th 08, 07:52 AM posted to rec.aviation.soaring
bumper
For use with Mil Spec 5606 fluid (the red petroleum based fluid that is
standard for small aircraft in the US), the O-rings and seals are normally
Buna-N rubber. If the Cleveland brake parts have been modified by Tost to
use DOT brake fluid, they do this by changing the O-rings and seals to EPDM
rubber to make them compatible with automotive DOT brake fluid. Stemme uses
such modified Cleveland calipers and DOT fluid in the S10-VT. Schleicher
uses unmodified Cleveland calipers and 5605 fluid in the ASH26E (and I
assume all their current gliders).
While automotive DOT fluids have advantages for high temperature braking
applications, the fluid attacks many paints, is hygroscopic, and thus will
sometimes promote corrosion in brake systems not specifically designed for
it (i.e. early Cleveland calipers and pucks with bare aluminum, as opposed
to anodized, will often corrode and cause fluid leakage at the seals. Some
automotive restorers will line the caliper bore with brass sleeves and
anodize the pucks to restore these corroded brake components.
For glider and small aircraft brakes, I prefer 5605 fluid.
bumper
zz
Minden NV
Quiet Vents and MKII high tech yaw strings
"Tim Mara" wrote in message
on gliders.
tim
message ...
Paul Hanson
Old January 4th 08, 03:37 PM posted to rec.aviation.soaring
Andy[_1_]
Why did Tost find it necessary to change the fluid type and is that
change approved by Cleveland?
Andy
Old January 6th 08, 06:22 PM posted to rec.aviation.soaring
On Jan 3, 6:42 pm, hans wrote:
Schempp-Hirth and Lange offer now the Beringer brakeshttp://www.beringer.fr/
Thanks Hans for pointing this out. The Beringer is the best setup
I've had on any sailplane - light, great stopping power, beautifully
made. That said, it is a fair bit of work to replace an existing wheel
brake assembly.
If it was so easy to engineer, you wouldn't need to replace yours...
Hope that's helpful !
Best Regards, Dave "YO"
FS Tost E85 Release scooter Soaring 0 March 7th 06 02:31 AM
FS Tost E85 Release scooter Soaring 0 November 22nd 05 01:11 AM
Tost release on L-19? Roy Bourgeois Soaring 2 November 29th 04 10:24 PM
Cessna 182 Tost 337? [email protected] Soaring 6 May 15th 04 03:24 PM
Tost springs Lord Struthers Soaring 1 October 10th 03 10:49 PM
