I have a question regarding the rings shown on some charts and not
others. They are a dashed ring and are labeled "FEEDER FACILITIES" and/or "ENROUTE FACILITIES". The may not be on all charts nor both on the same chart. For example http://naco.faa.gov/d-tpp/0801/06000LD15.PDF. I tried the Google route and that didn't work. I thought some of the ATC folks could help me find out their meaning. Ross KSWI |
I corrected the subject...
Ross wrote: I have a question regarding the rings shown on some charts and not others. They are a dashed ring and are labeled "FEEDER FACILITIES" and/or "ENROUTE FACILITIES". The may not be on all charts nor both on the same chart. For example http://naco.faa.gov/d-tpp/0801/06000LD15.PDF. I tried the Google route and that didn't work. I thought some of the ATC folks could help me find out their meaning. Ross KSWI |
NACO plates are not to scale outside of the 10-mile ring. Having the dashed
lines enables them to show you fixes that would normally be too far away to print. Bob Gardner "Ross" wrote in message news:E%xfj.86$TO.51@trnddc01... I corrected the subject... Ross wrote: I have a question regarding the rings shown on some charts and not others. They are a dashed ring and are labeled "FEEDER FACILITIES" and/or "ENROUTE FACILITIES". The may not be on all charts nor both on the same chart. For example http://naco.faa.gov/d-tpp/0801/06000LD15.PDF. I tried the Google route and that didn't work. I thought some of the ATC folks could help me find out their meaning. Ross KSWI |
Ross wrote:
I have a question regarding the rings shown on some charts and not others. They are a dashed ring and are labeled "FEEDER FACILITIES" and/or "ENROUTE FACILITIES". The may not be on all charts nor both on the same chart. For example http://naco.faa.gov/d-tpp/0801/06000LD15.PDF. I tried the Google route and that didn't work. I thought some of the ATC folks could help me find out their meaning. Ross KSWI A more complete answer is: where a 10 mile ring is shown, the chart is not to scale outside that ring. Where a 10 mile ring is not shown, the chart is to scale throughout the plan view. Example: http://www.naco.faa.gov/d-tpp/0801/06941R18.PDF |
Sam Spade wrote:
Ross wrote: I have a question regarding the rings shown on some charts and not others. They are a dashed ring and are labeled "FEEDER FACILITIES" and/or "ENROUTE FACILITIES". The may not be on all charts nor both on the same chart. For example http://naco.faa.gov/d-tpp/0801/06000LD15.PDF. I tried the Google route and that didn't work. I thought some of the ATC folks could help me find out their meaning. Ross KSWI A more complete answer is: where a 10 mile ring is shown, the chart is not to scale outside that ring. Where a 10 mile ring is not shown, the chart is to scale throughout the plan view. Example: http://www.naco.faa.gov/d-tpp/0801/06941R18.PDF So a circle will always show either a fix for the feeder facilities and / or a VOR, etc for enroute facilities and the circle will go though the fix or VOR, etc? Just want to be sure I understand. |
Ross wrote:
So a circle will always show either a fix for the feeder facilities and / or a VOR, etc for enroute facilities and the circle will go though the fix or VOR, etc? Just want to be sure I understand. The circle is just for cartographic convenience. All it shows is that the stuff outside the circle is NOT to scale. The stuff outside the circle might be feeder stuff or it might be an actual piece of the approach (an IAF may indeed be outside the circle). You're reading too much into it. |
On Jan 4, 4:59*pm, Ross wrote:
I have a question regarding the rings shown on some charts and not others. They are a dashed ring and are labeled "FEEDER FACILITIES" and/or "ENROUTE FACILITIES". *The may not be on all charts nor both on the same chart. For examplehttp://naco.faa.gov/d-tpp/0801/06000LD15.PDF. I tried the Google route and that didn't work. I thought some of the ATC folks could help me find out their meaning. Ross KSWI Basically they are there to tell you that there are facilities that are on other charts, such as in this case, a STAR and an enroute chart. FWIW, my understanding is that NACO is starting to remove the FEEDER and ENROUTE rings off of charts as they add unnecessarily clutter. |
Brad wrote:
On Jan 4, 4:59 pm, Ross wrote: I have a question regarding the rings shown on some charts and not others. They are a dashed ring and are labeled "FEEDER FACILITIES" and/or "ENROUTE FACILITIES". The may not be on all charts nor both on the same chart. For examplehttp://naco.faa.gov/d-tpp/0801/06000LD15.PDF. I tried the Google route and that didn't work. I thought some of the ATC folks could help me find out their meaning. Ross KSWI Basically they are there to tell you that there are facilities that are on other charts, such as in this case, a STAR and an enroute chart. FWIW, my understanding is that NACO is starting to remove the FEEDER and ENROUTE rings off of charts as they add unnecessarily clutter. Thats nice to know. Thanks -- Regards, Ross C-172F 180HP KSWI |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
