Buying an incomplete project
Old January 5th 08, 05:28 PM posted to rec.aviation.homebuilt
JAX
Default Buying an incomplete project
This is my first trip into the homebuilt world. I'm probably going to
buy a 90% complete project, and want to know if there will be any
paperwork hassles I'll have to jump through to get it registered.
I realize I won't have the repair authorization as I did not build 51%
of the plane, but what should I look for as far as documentation from
the current owner and what will the FAA expect to see from me?
I have AC 20-27F, but during a very quick glance-through I didn't
notice any specific mentions. Any help appreciated!
Old January 5th 08, 06:11 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Get a tall stack of detail photos for documentation.
Apply for the repairman's certificate when it comes time to
do all the paperwork. The so-called 51% rule does not apply there.
Study it in detail.
Have fun!
Richard
Old January 5th 08, 06:58 PM posted to rec.aviation.homebuilt
jerry wass
Study it in detail.
Have fun!
Richard
You will have to convince the examiner/DAR/whatever--that the First builder did it under
"experimental" rules
Get all the documentation you can get from the first builder that
you can--photos showing him working on it, notarized statement would be
helpful--maybe even his telephone # if that stays available.. Jerry
Old January 5th 08, 09:24 PM posted to rec.aviation.homebuilt
Charles Vincent
If the project you get is 90% done, there will in all likely hood still
be 51% left for you to do. Both technically and in reality. Study the
checklists carefully.
Charles
Old January 5th 08, 10:04 PM posted to rec.aviation.homebuilt
Kyle Boatright
"JAX" wrote in message
Any of the builders who worked on the aircraft can get the repairman's
certificate. The key is that you need to be able to demonstrate that 51% of
the airplane was amateur built.
KB
Old January 5th 08, 11:05 PM posted to rec.aviation.homebuilt
Bill Daniels
"Charles Vincent" wrote in message
If the project you get is 90% done, there will in all likely hood still be
Charles
So true. 90% of the work is usuually the last 10% of the project.
Old January 5th 08, 11:07 PM posted to rec.aviation.homebuilt
On Sat, 5 Jan 2008 17:04:29 -0500, "Kyle Boatright"
Technically only the "majority" builder is supposed to get the certificate, but
unless the project is practically turnkey, the OP shouldn't have a problem.
I've known a couple of folks who have received the certificate on projects that
were practically structurally complete when they bought them. The systems work
is probably much more important....
Old January 5th 08, 11:58 PM posted to rec.aviation.homebuilt
JAX
Greta stuff guys, thanks! Keep it coming, the advice is much
appreciated...
Old January 6th 08, 11:54 PM posted to rec.aviation.homebuilt
Dave S
51% of the airplane was amateur built.
KB
Last I read it was 51% of the TASKS of building the plane.
ergo.. if a plane has 100 ribs in the wing, if you build ONE rib, you
have accomplished the task of building wing ribs and do not have to
build all 100 of them.. or 51 of them...
thats where the quickbuilds tread the line..
Interesting to note that the nonprimary builder can get the repairmans
cert. I knew that only one person COULD have it, but presumed it was the
one who did the majority of the building.
Dave
Old January 7th 08, 03:42 AM posted to rec.aviation.homebuilt
. *The systems work
Ron Wanttaja- Hide quoted text -
Judging by the preponderance of fuel starvation problems in
experimentals in the NTSB database that sounds absolutely right.
It seems like fuel delivery problems account for half of all
experimental accidents and off airport landings.
The other half seems like pilot error in one form or another (which is
par for the flying course).
In the designs I've looked at, not a single structural failure occured
that wasn't pilot caused, and there was only one of those and the
pilot was high on mary jane.
buying help John Doe Owning 21 August 17th 05 07:08 PM
Considering buying a share Paul Tomblin Owning 15 February 3rd 05 05:24 PM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 04:03 AM
BUYING Cap 10b(c) os_pivo Aviation Marketplace 0 October 13th 03 07:15 PM
FS:CoF and why I won't be buying it Steve House Simulators 4 August 16th 03 02:24 AM
