Rodent Deterrent?
Old January 5th 08, 11:37 PM posted to rec.aviation.soaring
rlovinggood
Default Rodent Deterrent?
I opened up my trailer today and found a live mouse in the cockpit.
Naturally, there was a lot of mouse poop in the cockpit and in the
trailer. I had made at least one mistake of leaving a good supply of
crackers and granola bars in the cockpit and up front in the trailer.
Little bugger had a great home, complete with large food supply.
Tomorrow, the glider will get its annual condition inspection and I'll
be looking closely at tubing and wiring. I don't know if I'll have a
chance to do a leak check tomorrow on the system, but I will soon. My
quick look today didn't show any teeth marks.
Does anyone know a deterrent to rodents? How can I keep them out of
the trailer? The trailer stays parked outside, unfortunately. Would
moth balls work if placed in both the trailer and the cockpit?
Thanks,
Ray Lovinggood
Carrboro, North Carolina, USA
Old January 5th 08, 11:51 PM posted to rec.aviation.soaring
Brad[_2_]
Ray,
Don't you have some ferrets??
They are your answer to getting the mice to de-ass your trailer!
Brad
see.............mousebgone.com
trailer. *I had made at least one mistake of leaving a good supply of
be looking closely at tubing and wiring. *I don't know if I'll have a
chance to do a leak check tomorrow on the system, but I will soon. *My
Does anyone know a deterrent to rodents? *How can I keep them out of
the trailer? *The trailer stays parked outside, unfortunately. *Would
Thanks,
Ray Lovinggood
Old January 6th 08, 12:02 AM posted to rec.aviation.soaring
rlovinggood
Brad,
Yes, my wife has a ferret, "Wolfgang". But I don't know if she'll
like me for leaving her fert in the trailer that is about 56 miles
from the house.
But, she is in Belgium right now and will be there through early March
(they call it "sabbatical". I call it an extended vacation...)
I wonder what little Wolfgang would think about running up and down
inside the fuselage?
I'll also look into mousebgone.com.
Thanks,
Ray
Old January 6th 08, 12:10 AM posted to rec.aviation.soaring
Brad[_2_]
Ray,
when you clean out Wolfgangs litter box, put a little bit of that
special stuff in a small tray and put it in the trailer.
Years ago when I was rebuilding my ASK-14 wings, I noticed when I
removed the canvas there was a conga line of dead baby mice spread out
along the spar. I had put some ferret stuff in the wing root cuz I
heard mice running around inside. Apparently mom left and the baby
mice went looking for her.
Brad
On Jan 5, 4:02*pm, rlovinggood wrote:
Brad,
Yes, my wife has a ferret, "Wolfgang". *But I don't know if she'll
from the house.
(they call it "sabbatical". *I call it an extended vacation...)
Thanks,
Ray
Old January 6th 08, 12:24 AM posted to rec.aviation.soaring
rlovinggood
Brad:
EXCELLENT! Little Wolfgang does leave a pile every day and I'll take
some with me tomorrow morning.
Ferret Poop in the Trailer!
Hope my wife doesn't find out. If she does, she'll probably charge me
for the service...
Thanks for the info. And thanks for the link to mousebgone.com where
they sell the stuff that I can get here every day.
Ray
Old January 6th 08, 12:29 AM posted to rec.aviation.soaring
Ray,
The best way to keep mice away is to prevent them from getting inside
in the first place. That means patching up every little nook, cranny,
seam, gap, hole, crack that a mouse could get through. And they can
get through amazingly small openings. 1/4 inch hardward cloth is good
as is aluminum flashing. Self tapping sheet metal screws are
wonderful.
Then, make sure you leave nothing food-like inside the trailer.
Then hang original style Napthaline moth balls by the handfull in old
nylons in the wing roots, spoiler boxes, and fuselage. Remove before
flight.
Then put some of the really deadly (not warfrin) mouse killer bars in
the trailer (in containers accessable to mice but not dogs and cats
that might show up around the trailer some fateful day in the future)
If you do all that you will probably not have any mouse damage come
springtime. The damage can be considerable especially corrosion from
mouse urine. The smell can be impossible to remove and is nearly
fatal in an enclosed cockpit on a warm day.
Matt
Thanks,
Ray Lovinggood
Old January 6th 08, 12:30 AM posted to rec.aviation.soaring
Brad[_2_]
You are most welcome..............ferrets rule!
Brad
On Jan 5, 4:24*pm, rlovinggood wrote:
Brad:
EXCELLENT! *Little Wolfgang does leave a pile every day and I'll take
Hope my wife doesn't find out. *If she does, she'll probably charge me
for the service...
Thanks for the info. *And thanks for the link to mousebgone.com *where
Ray
Old January 6th 08, 12:55 AM posted to rec.aviation.soaring
ZZ
Thanks,
Ray Lovinggood
Ray
Matt is right on...build them out. However, if one gets past that
effort, a glue trap is very effective, especially if you place a small
dab of peanut butter in the center. They can't resist the stuff and it
is likely that they will cruise right on by the wires and tubing to get
to the trap. Put a large piece of cloth in the cockpit because he might
spread a bit of glue about trying to escape. Usually they get glue in
the nose and mouth and quickly suffocate. Once a month or so, check the
trap and replace it if occupied or refresh the PB if not.
One word of warning...don't forget about it and sit on it for an entire
flight. Ask me how I know this?
Paul
Old January 6th 08, 01:00 AM posted to rec.aviation.soaring
Brad[_2_]
years ago a friend and I checked out a homebuilt wooden motorglider,
think it was an Oldershaw? The wings were stored LE down in the
trailer and the mice had moved in. The LE at the root rib was rotten
due to all that mouse urine..........Matt is right on with that
comment!.
Brad
On Jan 5, 4:29*pm, wrote:
Ray,
in the first place. *That means patching up every little nook, cranny,
seam, gap, hole, crack that a mouse could get through. *And they can
as is aluminum flashing. *Self tapping sheet metal screws are
wonderful.
nylons in the wing roots, spoiler boxes, and fuselage. *Remove before
flight.
springtime. *The damage can be considerable especially corrosion from
mouse urine. *The smell can be impossible to remove and is nearly
Matt
Thanks,
Ray Lovinggood
Carrboro, North Carolina, USA- Hide quoted text -
- Show quoted text -
Old January 6th 08, 01:29 AM posted to rec.aviation.soaring
rlovinggood
All,
Thanks for your inputs. The trailer is a "Swan", which is a
clamshell, fiberglass top, trailer that looks a bit like an older
Cobra or Komet. The only place I think they could get in is at the
rear where the top comes down on the tailgate. Not sure if that is a
tight, i.e., smaller than a mouse, seal or not. If that is the
opening, I'll have to see what can be done to make it tighter. Don't
think hardware cloth is the answer in this case.
While I do enjoy the new trailer, I guess it has a fault: It makes a
nice mouse home. While my old trailer had several faults, I can't
blame it for attracting rodents. Heck, it probably repelled them with
its sheer ugliness. Since it wasn't very weather tight, with large
gaps between the rear (and only) door and the trailer frame, and could
have allowed LARGE critters in, I'm kind of surprised this never
happened when I had that trailer. Guess it was too ugly outside and
too cold inside. I guess the little furries didn't find it as
attractive as the nice new Swan.
Wish I could live where the trailer could stay inside a nice building
and my wife's pets could keep the unwanted critters at bay. But it
stays tied down outside.
Thanks,
Ray
