Multi engine fuel crossfeed question (Duchess twin)
Old January 14th 08, 07:43 PM posted to rec.aviation.piloting
akiley
Default Multi engine fuel crossfeed question (Duchess twin)
Hi All, I'm working on my multi rating in a Beech Duchess. I'm
curious about an item that doesn't seem well covered in the POH and
elsewhere for that matter.
What if you loose one engine at altitude, allowing plenty of time to
try to fix. You determine that you ran the right tank dry of fuel.
According to the fuel diagram, you should be able to run both engines
off one tank. The fuel line exits each tank and splits: one going to
the opposite fuel selector and one going to the closest engines fuel
selector.
If this is doable, why is it not talked about more? It's not a "fix"
option on the checklist and not discussed in the text of the POH.
Crossfeed is considered an emergency operation according to the POH,
and also "level flight only". Could this be why? Possible fuel
starvation on the crossfeeding engine from maneuvering to land, where
it may be safer to feather and secure the dead engine and do your one
shot landing.
.... akiley
Old January 14th 08, 08:33 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
akiley wrote in news:2e7dbffb-645c-49b6-9687-
selector.
shot landing.
... akiley
I have no idea what you're asking here. If you've lost an engine, why
would you be needing to run both off one tank?
Now, if you mean that you still have a long way to go and that you'll run
one dry before you get where you are going, then , yes, that's what it's
for.
You also want to alternate a bit to keep any imbalance from getting
crazy. I haven't flown a duchss n a long time, but I don't remember there
being anything too strange about the crossfeed arrangements. But if you
lost one there's nothing stopping you from crossfeeding from the oppostie
tank. Likelywise, if you have a leak in one tank, there's no reason I can
see you can't run both engines off of the remaining tank.
Sounds like they are (quite rightfully) discouraging 2recreational
crossfeeding" that some guys do just to "balance em out perfectly" This
usually leads to a massive imbalance, or even worse, having both engines
flame out due to ou getting distracted and forgetting.
It happens.
Bertie
Old January 14th 08, 09:09 PM posted to rec.aviation.piloting
akiley
selector.
shot landing.
... akiley
for.
It happens.
Bertie
In essence, I was asking if there was any reason not to run both
engines off one tank. In singles, "switch tanks" always seems to be
part of the emergency checklist for a rough engine, yet in the
Duchess POH (and a Seneca I for that matter) "crossfeed" isn't
mentioned as a diagnostic step where it seems like is should be. I
was wondering if I had missed something.
... Akiley
Old January 14th 08, 09:52 PM posted to rec.aviation.piloting
akiley wrote in
to try to fix. You determine that you ran the right tank dry of
fuel. According to the fuel diagram, you should be able to run both
engines off one tank. The fuel line exits each tank and splits:
one going to the opposite fuel selector and one going to the
closest engines fuel selector.
"fix" option on the checklist and not discussed in the text of the
POH. Crossfeed is considered an emergency operation according to
the POH, and also "level flight only". Could this be why?
Possible fuel starvation on the crossfeeding engine from
maneuvering to land, where it may be safer to feather and secure
the dead engine and do your one shot landing.
... akiley
run one dry before you get where you are going, then , yes, that's
what it's for.
there being anything too strange about the crossfeed arrangements.
But if you lost one there's nothing stopping you from crossfeeding
from the oppostie tank. Likelywise, if you have a leak in one tank,
there's no reason I can see you can't run both engines off of the
remaining tank. Sounds like they are (quite rightfully) discouraging
2recreational crossfeeding" that some guys do just to "balance em out
perfectly" This usually leads to a massive imbalance, or even worse,
having both engines flame out due to ou getting distracted and
forgetting.
It happens.
Bertie
OK, if I'm following you, you're suggesting that you've lost an engine
for no apparent reason. You decide that it might be a fuel problem, so
you want to feed off the tank on the opposite side to see if that fixes
it.
Sounds like a good idea to me. You would have to be very, very careful
that it wasn't a fuel line on the failed side that caused the problem in
the first place, otherwise you could lose all the fuel. That's what
happened to that A330 that deadsticked into the Azores. But it sounds
like a reasonable thng to do if that is what you suspect the problem is.
Just make sure you do it slowly and deliberately. you don't want to end
up gliding due to a poor selection.
You might also consider, on the day, the wisdom of relighting an engine
with a fuel problem. It's all a trade off of various risks. Wx, how far
you have to go vs how much gas you got left, that sort of stuff. If you
don't really need it to get where you are going, it might be better not
to take the risk. If you are in the middle of a mountain range and you
need it to keep your altitude above MORA at night, different story. Not
that you should be there anyway.
Manufacturers, the FAA and schools will steer you towards the checklists
and procedures for some very good reasons. Experience with some of these
situations has produced a pattern of th emost likely causes and the
results of getting too creative with the systems. If they recommend you
do something a certain way, do it that way. But, if you 're off the
page, knowing how the system works will enable you to analyse the
problem with a good chance of a solution.
Bertie
Old January 14th 08, 11:01 PM posted to rec.aviation.piloting
akiley
... akiley
what it's for.
forgetting.
It happens.
Bertie
it.
Bertie
Thanks for the good point. Remember in the original post I made a
scenario where I exhausted the fuel in the right tank. Fuel pressure
and quantity gauges confirmed this. So I decide to try to crossfeed
from the good engine side to the engine that I lost due to fuel
starvation. But good point. What if I lost all the fuel in that tank
because of some problems like a leak that may effect the full tank if
I crossfeed.
.... akiley
Old January 14th 08, 11:37 PM posted to rec.aviation.piloting
akiley wrote in
akiley wrote
innews:5c24ef75-4385-4897-a75d-
om:
akiley wrote in
and elsewhere for that matter.
time to try to fix. You determine that you ran the right tank
dry of fuel. According to the fuel diagram, you should be able
to run both engines off one tank. The fuel line exits each tank
and splits: one going to the opposite fuel selector and one
going to the closest engines fuel selector.
the POH. Crossfeed is considered an emergency operation
according to the POH, and also "level flight only". Could this
be why? Possible fuel starvation on the crossfeeding engine from
... akiley
why would you be needing to run both off one tank?
you'll run one dry before you get where you are going, then , yes,
that's what it's for.
getting crazy. I haven't flown a duchss n a long time, but I don't
remember there being anything too strange about the crossfeed
arrangements. But if you lost one there's nothing stopping you
from crossfeeding from the oppostie tank. Likelywise, if you have
a leak in one tank, there's no reason I can see you can't run both
engines off of the remaining tank. Sounds like they are (quite
rightfully) discouraging 2recreational crossfeeding" that some
guys do just to "balance em out perfectly" This usually leads to a
massive imbalance, or even worse, having both engines flame out
It happens.
Bertie
be part of the emergency checklist for a rough engine, yet in the
engine for no apparent reason. You decide that it might be a fuel
problem, so you want to feed off the tank on the opposite side to see
if that fixes it.
careful that it wasn't a fuel line on the failed side that caused the
problem in the first place, otherwise you could lose all the fuel.
That's what happened to that A330 that deadsticked into the Azores.
But it sounds like a reasonable thng to do if that is what you
suspect the problem is. Just make sure you do it slowly and
deliberately. you don't want to end up gliding due to a poor
selection. You might also consider, on the day, the wisdom of
relighting an engine with a fuel problem. It's all a trade off of
various risks. Wx, how far you have to go vs how much gas you got
left, that sort of stuff. If you don't really need it to get where
you are going, it might be better not to take the risk. If you are in
the middle of a mountain range and you need it to keep your altitude
above MORA at night, different story. Not that you should be there
anyway. Manufacturers, the FAA and schools will steer you towards the
checklists and procedures for some very good reasons. Experience with
some of these situations has produced a pattern of th emost likely
causes and the results of getting too creative with the systems. If
they recommend you do something a certain way, do it that way. But,
if you 're off the page, knowing how the system works will enable you
to analyse the problem with a good chance of a solution.
Bertie
I crossfeed.
If you exhausted the fuel in one tank with a simple system like a
Duchess or Seneca has, it can only be because there wasn't much to begin
with ( you wouldn't do that, right) or because it's spilling out
somewhere it shouldn't. If you can see it coming out of the tank ( left
the cap off? ) then you might have a case for x-feeding. If not, it
might be leaking downstream of where the other tank joins into the
failed side's fuel system.
One other reason you might not be getting fuel is a failed fuel pump.
Maybe both the elec and mech pump is gone on one side. The elec pump on
th eoposite side should be able to pressurise the fuel system on the
opposite side. It did in at least one airplane I have flown. Very
unlikely, I know, but it could be and this one has happened to me once
in a twin Beech on the ground.
Old January 15th 08, 03:15 AM posted to rec.aviation.piloting
akiley
On Jan 14, 6:37 pm, Bertie the Bunyip wrote:
om:
akiley wrote in
... akiley
It happens.
Bertie
if that fixes it.
Bertie
I crossfeed.
I seem to recall some twins had problems with fuel lines chafing,
which cased the fuel line to rupture draining the tank into the wing
area behind the engine somewhere. Maybe you wouldn't want to try to
restart that failed engine using crossfeed! Also, can't a clogged
fuel tank vent cause a vacuum, then fuel starvation?
So maybe the aircraft manufacturer doesn't want to suggest the option
of restarting a failed engine by crossfeeding from the opposite engine
because: It might be dangerous in some cases like you mention. Fuel
leaking internally. Maybe securing that failed engine, which turns
off fuel and electricity on that side is a safer option.
.... akiley
Old January 15th 08, 04:07 AM posted to rec.aviation.piloting
akiley wrote in
Haven't heard of it but I'd be surprised if it hadn't happened
somewhere, sometime.
Yep!
Well, they did provide you with a crossfeed! You do what you have to do,
but you'd want to be sure of what it is you're doing.
If you needed the engine to keep you from hitting somethng, the ground,
for instance, then you don't have a lot of choice.
So it all depends. You might know for sure why it shut down. Hard to say
even when you;re sitting there next to the engine.
In jets it's something we might consider a bit more seriously since they
can flame out just from very heavy rain, for instance ( shouldn't,
though) We're trained to attempt a restart if there's no apparent damage
to the engine, but we're not trained to try and see if fuel from the
opposite tank will fix it. If the tank on that side has run dry, I'd be
just as wary of a restart never mind one from the other tank as I would
in a light twin for the same reason you stated. But if I knew why the
fuel was gone and it wasn't dangerous to restart and I was very sure of
that, well then, sure, I'd attempt a restart and I would use the fuel
from the opposite tank.
Bertie
Old January 15th 08, 12:35 PM posted to rec.aviation.piloting
akiley
Yep!
Bertie
Good points, I think I have a better understanding of the situation
now.
Thanks ... akiley
Old January 15th 08, 12:50 PM posted to rec.aviation.piloting
akiley wrote in
wrote
innews:f4c009c3-4d05-46f4-9ceb-c54f686f33d7
@e25g2000prg.googlegroups.c
om:
wing area behind the engine somewhere.
Yep!
option of restarting a failed engine by crossfeeding from the
opposite engine because: It might be dangerous in some cases like
you mention. Fuel leaking internally. Maybe securing that failed
engine, which turns off fuel and electricity on that side is a
safer option.
do, but you'd want to be sure of what it is you're doing.
ground, for instance, then you don't have a lot of choice.
say even when you;re sitting there next to the engine.
they can flame out just from very heavy rain, for instance (
shouldn't, though) We're trained to attempt a restart if there's no
apparent damage to the engine, but we're not trained to try and see
if fuel from the opposite tank will fix it. If the tank on that side
has run dry, I'd be just as wary of a restart never mind one from the
other tank as I would in a light twin for the same reason you stated.
But if I knew why the fuel was gone and it wasn't dangerous to
restart and I was very sure of that, well then, sure, I'd attempt a
restart and I would use the fuel from the opposite tank.
Bertie
now.
Kay!
Probably more than you wanted to know, but it's hard to tell exactly
what someone wants to know here!
Bertie
CFII or multi-engine? Casey Hansen Piloting 3 April 23rd 04 12:57 AM
Multi-Engine Before Commercial? David B. Cole Piloting 30 April 18th 04 04:46 PM
Time Building Multi Engine Midway Aviators Aviation Marketplace 0 March 9th 04 04:57 AM
multi engine ultralight trainers [email protected] Owning 0 January 1st 04 07:10 PM
Multi-Engine which one ? B25flyer Piloting 4 December 11th 03 06:43 PM
