Just to add to my virtual "Binder of Obscure Trivia", I'm wondering.
Where could I find data on the runway length needed for land-based operations (for takeoff and landing) for: F-16 F-15 F-14 F/A-22 B-52 B-1 E-2 E-3 E-8 MiG-29 MiG-23 MiG-25 Su-27 MiG-31 Su-30 C-130 C-5 C-141 C-17 If people don't have such data, or don't want to give it, OK.:-) I'm just wondering where I could *find* such data. John |
On Tue, 28 Oct 2003 03:46:46 -0500, John Penta
wrote: Just to add to my virtual "Binder of Obscure Trivia", I'm wondering. Well, start the folder of BOT with a statement that takeoff and landing rolls depend on a lot of factors such as gross weight, temperature, field elevation, wind and slope. In other words it varies--a lot! Then note that a NATO "standard" runway was defined as 8000 feet approximately, so that tells you an all purpose figure that works most of the time. Certainly a longer runway will allow for heavier loads, greater safety margins, and broader range of density altitude conditions. Typically most fighter aircraft (not STOL) will use about 1500-4000 feet of ground roll for take-off, depending upon load. Century series aircraft consumed a bit more pavement. Where could I find data on the runway length needed for land-based operations (for takeoff and landing) for: F-16 F-15 F-14 F/A-22 B-52 B-1 E-2 E-3 E-8 MiG-29 MiG-23 MiG-25 Su-27 MiG-31 Su-30 C-130 C-5 C-141 C-17 If people don't have such data, or don't want to give it, OK.:-) I'm just wondering where I could *find* such data. John |
On Tue, 28 Oct 2003 14:21:19 GMT, Ed Rasimus
wrote: On Tue, 28 Oct 2003 03:46:46 -0500, John Penta wrote: Just to add to my virtual "Binder of Obscure Trivia", I'm wondering. Well, start the folder of BOT with a statement that takeoff and landing rolls depend on a lot of factors such as gross weight, temperature, field elevation, wind and slope. In other words it varies--a lot! Then note that a NATO "standard" runway was defined as 8000 feet approximately, so that tells you an all purpose figure that works most of the time. Certainly a longer runway will allow for heavier loads, greater safety margins, and broader range of density altitude conditions. Typically most fighter aircraft (not STOL) will use about 1500-4000 feet of ground roll for take-off, depending upon load. Century series aircraft consumed a bit more pavement. Thanks for the info. I wasn't looking for exact stuff, more what the lengths are that planners use when planning for basing, emergency fields...things like that. The numbers that would (all other things being equal) allow one to intelligently say "X can go here, here, here, and here, but not here, here, here, and here. Meanwhile, Y can go here, here, here, and here..." Um. I really hope I'm making sense. John |
On Wed, 29 Oct 2003 16:17:58 -0500, John Penta
wrote: On Tue, 28 Oct 2003 14:21:19 GMT, Ed Rasimus wrote: Well, start the folder of BOT with a statement that takeoff and landing rolls depend on a lot of factors such as gross weight, temperature, field elevation, wind and slope. In other words it varies--a lot! Typically most fighter aircraft (not STOL) will use about 1500-4000 feet of ground roll for take-off, depending upon load. Century series aircraft consumed a bit more pavement. Thanks for the info. I wasn't looking for exact stuff, more what the lengths are that planners use when planning for basing, emergency fields...things like that. The numbers that would (all other things being equal) allow one to intelligently say "X can go here, here, here, and here, but not here, here, here, and here. Meanwhile, Y can go here, here, here, and here..." You are making sense and considering the sort of stuff that a lot of folks tend to overlook. There are even more issues than mentioned. Things like load bearing capacity of the pavement. Aircraft not only need to be supported by the runway, but also by the taxiways and ramps. Large aircraft especially can sink through the pavement at high gross weights. "Footprint" weight is important, considering max gross weights as well as size and number of tires on the landing gear. There are also some shortcuts to make runways that might not otherwise be suitable OK. Things like jet barriers and arresting gear. A runway too short for safe takeoff at high gross weight because it is inadequate for a high speed abort, might become useable with a departure end barrier installed. Or, a too short recovery field might become an option with an approach end barrier capability deployed and a suitably tail-hook equipped aircraft. And, when considering suitability, don't forget compatible instrument approaches. |
Ed Rasimus wrote in message . ..
On Wed, 29 Oct 2003 16:17:58 -0500, John Penta wrote: On Tue, 28 Oct 2003 14:21:19 GMT, Ed Rasimus wrote: SNIP: Things like load bearing capacity of the pavement. Aircraft not only need to be supported by the runway, but also by the taxiways and ramps. Large aircraft especially can sink through the pavement at high gross weights. "Footprint" weight is important, considering max gross weights as well as size and number of tires on the landing gear. SNIP: Back in late 1957 I delivered their first F86D to the Kelly TX ANG to replace their F80s. Upon deplaning we discovered the Dog's main gear had sunk not into but through the asphalt of their parking ramp. . . . Walt BJ |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | January 1st 05 08:29 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | December 1st 04 07:28 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 04 08:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | July 1st 04 09:27 AM |
| rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | June 1st 04 09:27 AM |
