Towing stability studies
Old January 27th 08, 03:12 PM posted to rec.aviation.soaring
chris
Default Towing stability studies
On Jan 27, 7:37 am, nimbusgb wrote:
On 26 Jan, 18:20, wrote:
If you can stand the size and poor gas milage, it's hard to go wrong
with a pickup or commercial van with a solid axle and a factory tow
package, BTW
My suggestions/opinions only; your milage may vary.
Ray Warshaw
1LK
I'm hoping for a solution to trailer sway in the Acura MDX that I am
waiting for delivery next week. The MDX has a Trailer Stability Assist
program included in the Vehicle Stability Assist system. Of course,
TSA doesn't fix whatever is causing the sway in the first place but at
least it should eliminate the effects. I've tried various solutions on
my trailer and the one with the greatest positive effect was inflating
the tires to max rated pressure. I think the fundamental problem on my
trailer is the wimpy torsion bar suspension.
Steve
If you have an airfoil shaped fin box on the trailer try fitting a
'spoiler strip' to either side of the finbox!
I had a ventus B Turbo in a Komet II trailer that used to quietly
dance behind what was normally a perfect tow vehicle. The sway was
usually kicked off by a passing car or when overtaking a big rig or
bus on the motorway. Taping 2 25 mm aluminium right angles about 1m
long, vertically about 100mm behind the leading edge of the fin box
killed the horizontal lift on the box and transformed the handling.
I often got some very strange looks from other club members about it
but I swear it worked a treat.
I'll second your comment. I have a Komet trailer with a symmetrical
airfoil tailfin. Gusts from passing large trucks would cause it to
sway. I think the curling air caused just the right angle of attack,
and an ugly harmonic say until out of the wake of the truck. I also
added the right angle aluminum bars just as you described. These
spoilers really added 5-15mph more safe speed to the trailer, very
dramatic change.
As far as mechanical side sway [not the aerodynamic type] changing to
stiff sidewall tires "V-rated" and keeping them inflated solved the
issue for me. Factory tires/ones you get when you buy a car can be
terrible.
Instead of 32psi I keep the front tires inflated to 35psi and the
rears at 40psi. Also helps gas mileage.
Chris
Old January 27th 08, 04:09 PM posted to rec.aviation.soaring
package, BTW
Ray Warshaw
1LK
Steve
dramatic change.
terrible.
Chris
I've heard about the spoiler fix but never tried it. I was told to put
the spoilers at the trailing edge of the fin. I also talked to a Komet
factory rep at an SSA Convention a few years back and he told me the
cause of sway was absolutely not aerodynamic!
Steve
Old January 27th 08, 05:44 PM posted to rec.aviation.soaring
nimbusgb
Have you noticed how the boxes on new trailers are now square
Old January 27th 08, 06:54 PM posted to rec.aviation.soaring
John Galloway[_1_]
now square
If we're talking Cobra, isn't it just metal top - square,
grp top - curvy?
Old January 27th 08, 07:01 PM posted to rec.aviation.soaring
Bruce
Indeed Ian
However, I think a lot of swaying trailer diseases is caused by vortex shedding.
Which is why architects tend not to make too symmetrical buildings.
This is usually triggered by a disturbance to the streamline flow - such as
passing a large vehicle.
Having a turbulator about 30% forward of the back of the trailer works very well
on mine. Don't know who fitted it - but there is a little (about 8mm high)
aluminium profile just ahead of the opening section. Probably fitted to deflect
water past the gap. Mine is a 1971 Anschou trailer with the little wing shaped
doghouse for the fin, but it tows very well.
Old January 27th 08, 07:20 PM posted to rec.aviation.soaring
John Galloway[_1_]
now square
grp top - curvy?
Old January 27th 08, 10:19 PM posted to rec.aviation.soaring
1LK
I did almost the same with my LAK trailer but used pop rivits and
sealer when I was towing with a Chevy Blazer. Without them, the rig
was dicy over 60 mph; after they were added it was rock-steady at
Arizona highway speeds (75 mph). The P/U I replaced the Blazer with
probably wouldn't have needed them, though.
Ray Warshaw
1LK
Old January 28th 08, 09:01 PM posted to rec.aviation.soaring
Jeremy Zawodny
Do you have any photos of this installation? I'm wondering if it'll
help settle down my Komet.
Jeremy
Old January 29th 08, 02:57 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Try it!
Use some scrap 25mm (1") square scrap wood, steel tubing, etc. Anything
that presents a 25mm flat surface at right angles to the fin box skin
will do. Put it on temporarily with Gaffer, Duct or even parcel tape. Do
a short tow. Try moving the strips to sere what works best.
If/when it works well enough, spend the time and money to get 25 mm
alloy angle strip and attach it properly.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old January 31st 08, 06:15 AM posted to rec.aviation.soaring
nimbusgb
now square
grp top - curvy?
The latest square finbox I saw was on a GRP top.
Tow vehicle -- electronic stability control Greg Arnold Soaring 4 June 8th 06 12:31 PM
Atmospheric stability and lapse rate Andrew Sarangan Piloting 39 February 11th 05 05:34 AM
Roll Stability in lifting body and flying wing aircraft Fred the Red Shirt Home Built 2 December 3rd 04 10:24 PM
U.S. Air Force Moves Ahead With Studies On Air-Breathing Engines Otis Willie Military Aviation 0 October 29th 03 03:31 AM
Air Force office studies aging aircraft Otis Willie Military Aviation 2 August 30th 03 06:05 PM
