Piston single research
Old January 28th 08, 04:33 PM posted to rec.aviation.owning,rec.aviation.piloting
Jay Honeck[_2_]
Default Piston single research
Note a book but...
http://www.risingup.com/planespecs/
Just remember (as has been noted here on past occasions) that the data in
this webpage is often laughably inaccurate.
The page on the Pathfinder, for example, lists a "62 gallon" fuel capacity.
The correct answer is either 50 (without tip tanks; although I don't believe
any were built *without* tip tanks, but I could be wrong) or 84 gallons with
tip tanks.
When they get basic stuff like that wrong, I tend to lose faith in the rest
of the data.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old January 28th 08, 07:54 PM posted to rec.aviation.owning,rec.aviation.piloting
Ross
Jay Honeck wrote:
Note a book but...
in this webpage is often laughably inaccurate.
capacity. The correct answer is either 50 (without tip tanks; although I
don't believe any were built *without* tip tanks, but I could be wrong)
or 84 gallons with tip tanks.
rest of the data.
You are correct. I just looked at my aircraft and it lists 42 gal. I
believe it is 39 with 1.5 unusable each wing.
Regards, Ross
C-172F 180HP
KSWI
Cessna's next piston single [email protected] Owning 0 February 11th 06 07:14 PM
IFR w/pax under Single-Pilot/Single Aircraft 135 Bravo8500 Owning 20 March 9th 05 09:37 PM
Lancair Columbia 400: The World's Fastest Certified Piston Single Engine Aircraft! David Ross Aviation Marketplace 0 August 24th 04 07:13 PM
Cessna's new piston single. Dan Luke Piloting 3 July 7th 04 12:54 AM
How to ACCURATELY measure fuel/gas in a single-engine piston aircraft? NoSpam Piloting 31 January 9th 04 01:45 AM
