![]() Is Branson going to certify White Knight Two and SpaceShipTwo? http://www.heraldtribune.com/article...0838/-1/HELP07 NEW YORK -- A select group of rich tourists may be blasting into space within a few years in a craft that developers say is about 70 percent complete. British billionaire Richard Branson and the aerospace designer Burt Rutan on Wednesday unveiled a model of SpaceShipTwo, the vehicle they hope will be able to take passengers about 62 miles above Earth for the fun of it, with test flights possibly beginning this year. ... About 200 prospective passengers from 30 countries have made reservations, shelling out $200,000 each. But: http://www1.airweb.faa.gov/REGULATOR...6?OpenDocument Part 91 GENERAL OPERATING AND FLIGHT RULES Subpart D--Special Flight Operations Sec. 91.319 Aircraft having experimental certificates: Operating limitations. (a) No person may operate an aircraft that has an experimental certificate-- (1) For other than the purpose for which the certificate was issued; or -- (2) Carrying persons or property for compensation or hire. (b) No person may operate an aircraft that has an experimental certificate outside of an area assigned by the Administrator until it is shown that-- (1) The aircraft is controllable throughout its normal range of speeds and throughout all the maneuvers to be executed; and (2) The aircraft has no hazardous operating characteristics or design features. (c) Unless otherwise authorized by the Administrator in special operating limitations, no person may operate an aircraft that has an experimental certificate over a densely populated area or in a congested airway. The Administrator may issue special operating limitations for particular aircraft to permit takeoffs and landings to be conducted over a densely populated area or in a congested airway, in accordance with terms and conditions specified in the authorization in the interest of safety in air commerce. (d) Each person operating an aircraft that has an experimental certificate shall-- (1) Advise each person carried of the experimental nature of the aircraft; (2) Operate under VFR, day only, unless otherwise specifically authorized by the Administrator; and (3) Notify the control tower of the experimental nature of the aircraft when operating the aircraft into or out of airports with operating control towers. [(e) No person may operate an aircraft that is issued an experimental certificate under §21.191 (i) of this chapter for compensation or hire, except a person may operate an aircraft issued an experimental certificate under §21.191 (i)(1) for compensation or hire to- (1) Tow a glider that is a light-sport aircraft or unpowered ultralight vehicle in accordance with §91.309; or (2) Conduct flight training in an aircraft which that person provides prior to January 31, 2010. (f) No person may lease an aircraft that is issued an experimental certificate under §21.191 (i) of this chapter, except in accordance with paragraph (e)(1) of this section. (g) No person may operate an aircraft issued an experimental certificate under §21.191 (i)(1) of this chapter to tow a glider that is a light-sport aircraft or unpowered ultralight vehicle for compensation or hire or to conduct flight training for compensation or hire in an aircraft which that persons provides unless within the preceding 100 hours of time in service the aircraft has- (1) Been inspected by a certificated repairman (light-sport aircraft) with a maintenance rating, an appropriately rated mechanic, or an appropriately rated repair station in accordance with inspection procedures developed by the aircraft manufacturer or a person acceptable to the FAA; or (2) Received an inspection for the issuance of an airworthiness certificate in accordance with part 21 of this chapter. (h) The FAA may issue deviation authority providing relief from the provisions of paragraph (a) of this section for the purpose of conducting flight training. The FAA will issue this deviation authority as a letter of deviation authority. (1) The FAA may cancel or amend a letter of deviation authority at any time. (2) An applicant must submit a request for deviation authority to the FAA at least 60 days before the date of intended operations. A request for deviation authority must contain a complete description of the proposed operation and justification that establishes a level of safety equivalent to that provided under the regulations for the deviation requested. (i) The Administrator may prescribe additional limitations that the Administrator considers necessary, including limitations on the persons that may be carried in the aircraft.] |
cavalamb himself wrote:
Larry Dighera wrote: Is Branson going to certify White Knight Two and SpaceShipTwo? When has FAA ever been involved space craft systems? Damn now I have to back up Larry. http://www.faa.gov/about/office_org/...e_flight_reqs/ |
![]() "cavalamb himself" wrote in message ... When has FAA ever been involved space craft systems? From the start. |
On Mon, 28 Jan 2008 11:31:55 -0600, Gig 601XL Builder
wrote in : cavalamb himself wrote: Larry Dighera wrote: Is Branson going to certify White Knight Two and SpaceShipTwo? When has FAA ever been involved space craft systems? Damn now I have to back up Larry. http://www.faa.gov/about/office_org/...e_flight_reqs/ The regulations also establish requirements for crew notification, medical qualifications and training, as well as requirements governing environmental control and life support systems. They also require a launch vehicle operator to verify the integrated performance of a vehicles hardware and any software in an operational environment. An operator must successfully verify the integrated performance of a vehicle's hardware and any software in an operational flight environment before allowing any space flight participant on board. Verificatioin [sic] must include flight testing. So it would seem that the operator of an ostensibly uncertified aircraft, that can truly be considered experimental in my opinion, is authorized by the FAA to "verify" the spacecraft is safe for flight. But that doesn't address Sec. 91.319's prohibition against flying paying passengers in experimental aircraft, does it? |
... "cavalamb himself" wrote in message ... When has FAA ever been involved space craft systems? From the start. Did the Soviets check with the FAA when they launched Sputnik? |
On Jan 28, 9:04*am, Larry Dighera wrote:
Is Branson going to certify White Knight Two and SpaceShipTwo? I didn't see anything in the article that suggested the vehicle would be certified as experimental when passengers were riding. I would assume he would have the certificate before the paying pax arrived. -Robert |
![]() "Steve Foley" wrote in message news:tHonj.10$9g.9@trndny07... Did the Soviets check with the FAA when they launched Sputnik? Doubtful. Why do you ask? |
... "Steve Foley" wrote in message news:tHonj.10$9g.9@trndny07... Did the Soviets check with the FAA when they launched Sputnik? Doubtful. Why do you ask? You stated the FAA has been involved 'since the start'. The Start was in 1957. |
![]() "Steve Foley" wrote in message news:5Vonj.9$4f.8@trndny06... You stated the FAA has been involved 'since the start'. The Start was in 1957. There was no US space program prior to the launch of Sputnik I? Is that what you're saying? |
Larry Dighera wrote in
: Is Branson going to certify White Knight Two and SpaceShipTwo? You are dead inside, Larry. Dead Bertie |
Experimental aircraft and towing | Marc Ramsey | Soaring | 8 | January 28th 17 08:23 AM |
Experimental, Classic and Warbird aircraft | [email protected] | Owning | 0 | July 1st 06 05:41 AM |
FS: Wood prop for experimental aircraft | Glasair | Aviation Marketplace | 0 | September 29th 05 06:06 PM |
Financing for Experimental Aircraft | James Keane | Owning | 2 | September 1st 04 02:18 AM |
Experimental Aircraft Pictures | Jay Honeck | Piloting | 0 | December 5th 03 10:12 PM |
