On Thu, 31 Jan 2008 05:35:40 +0100, Mxsmanic
wrote in : The new Class B airspace at KPHX http://skyvector.com/#32-25-3-3647-2226 It's a pistol. But I think KSAN is even more difficult to visualize: http://skyvector.com/#32-25-3-3647-2226 . It has VFR tunnels through various Class B sectors. |
Larry Dighera writes:
But I think KSAN is even more difficult to visualize: http://skyvector.com/#32-25-3-3647-2226 . It has VFR tunnels through various Class B sectors. The VFR corridor at least follows the shoreline; conceivably one could navigate through it just by looking at the ground. There aren't any VFR corridors at all in Phoenix that I've noticed. |
Mxsmanic wrote in
: Larry Dighera writes: But I think KSAN is even more difficult to visualize: http://skyvector.com/#32-25-3-3647-2226 . It has VFR tunnels through various Class B sectors. The VFR corridor at least follows the shoreline; conceivably one could navigate through it just by looking at the ground. There aren't any VFR corridors at all in Phoenix that I've noticed. So what, fjukktard? You don't fly. Bertie |
On Thu, 31 Jan 2008 13:47:23 +0100, Mxsmanic
wrote in : Larry Dighera writes: But I think KSAN is even more difficult to visualize: http://skyvector.com/#32-25-3-3647-2226 . It has VFR tunnels through various Class B sectors. The VFR corridor at least follows the shoreline; conceivably one could navigate through it just by looking at the ground. I should have said Class E tunnels instead of VFR tunnels. Take a look at the four sectors with DOUBLE floors and ceilings enclosed in blue boxes he http://skyvector.com/#32-24-2-4904-4560 |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 Mxsmanic wrote: Larry Dighera writes: But I think KSAN is even more difficult to visualize: http://skyvector.com/#32-25-3-3647-2226 . It has VFR tunnels through various Class B sectors. The VFR corridor at least follows the shoreline; conceivably one could navigate through it just by looking at the ground. There aren't any VFR corridors at all in Phoenix that I've noticed. Idiot. But then again, I wouldn't trust any children to learn English from you, let alone French. The answer is on the same site you glorify and probably smoke choads from. I quote from the Phoenix TAC: The *VFR TRANSITION ROUTE* over Phoenix Sky Harbor Int'l Airport is based on Runway in use. 7s/8: use the West route. 25s/26, use the East route. Next to it? details on the transition routes. On top of that, the Canal Transition route. Anthony, shut up. You obviously have no idea what you're talking about. BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.8 (GNU/Linux) iD8DBQFHopZ5yBkZmuMZ8L8RAlkvAJwMy7ZXtV0jchMsN/9EMi/VHHXYqgCeLI6f C1LP88eu+9NZlhC4nf10GdA= =DKEm -----END PGP SIGNATURE----- |
Mxsmanic wrote:
Larry Dighera writes: But I think KSAN is even more difficult to visualize: http://skyvector.com/#32-25-3-3647-2226 . It has VFR tunnels through various Class B sectors. The VFR corridor at least follows the shoreline; conceivably one could navigate through it just by looking at the ground. There aren't any VFR corridors at all in Phoenix that I've noticed. What does it matter since you don't really fly? Clue #1: Because you haven't noticed them doesn't mean they don't exist. Clue #2: Real VFR pilots of real airplanes can go through real class B airspace without using VFR corridors. -- Jim Pennino Remove .spam.sux to reply. |
A Guy Called Tyketto writes:
Idiot. But then again, I wouldn't trust any children to learn English from you, let alone French. The answer is on the same site you glorify and probably smoke choads from. I quote from the Phoenix TAC: The *VFR TRANSITION ROUTE* over Phoenix Sky Harbor Int'l Airport is based on Runway in use. 7s/8: use the West route. 25s/26, use the East route. A transition route isn't a corridor. A corridor is outside the Class B; a transition route goes through it. Look at KSAN to see a true VFR corridor. |
Mxsmanic wrote in
: A Guy Called Tyketto writes: Idiot. But then again, I wouldn't trust any children to learn English from you, let alone French. The answer is on the same site you glorify and probably smoke choads from. I quote from the Phoenix TAC: The *VFR TRANSITION ROUTE* over Phoenix Sky Harbor Int'l Airport is based on Runway in use. 7s/8: use the West route. 25s/26, use the East route. A transition route isn't a corridor. A corridor is outside the Class B; a transition route goes through it. Look at KSAN to see a true VFR corridor. Why? You don't fly... Bertie |
Mxsmanic wrote in
: writes: What does it matter since you don't really fly? I use them in simulation. Clue #2: Real VFR pilots of real airplanes can go through real class B airspace without using VFR corridors. If they are cleared to do so, but they may not be. Why not fjukkwit? go on.. Bertie |
Controller screwed up? | Paul Tomblin | Piloting | 51 | September 14th 07 09:59 PM |
PSS 747 Depature Route from KPHX | Thomas | Simulators | 0 | July 19th 04 11:52 AM |
Don't Want to be Screwed | tompet@peak.org | Home Built | 5 | May 22nd 04 06:58 AM |
Screwed by Helicopter Support Inc. | Becky DeWind | Owning | 3 | May 18th 04 01:14 PM |
Changes At KPHX | Jay Beckman | Piloting | 5 | April 6th 04 03:31 PM |
