Boeing Awarded Contract For Next-Generation Harpoon Block III Missile
Old February 2nd 08, 05:54 AM posted to sci.military.naval, rec.aviation.military.naval
Default Boeing Awarded Contract For Next-Generation Harpoon Block III Missile
See:
http://www.spacewar.com/reports/Boei...ssile_999.html
How much longer will the Navy keep upgrading Harpoon before
switching to a newer, possibly supersonic, weapon?
Old February 2nd 08, 08:24 AM posted to sci.military.naval,rec.aviation.military.naval
Fred J. McCall
:See:
:How much longer will the Navy keep upgrading Harpoon before
:switching to a newer, possibly supersonic, weapon?
This one seems to fall into the "if it works, don't **** with it"
category.
What do you want a newer weapon to do that would work better than
what's already there and in the development plan?
"Millions for defense, but not one cent for tribute."
-- Charles Pinckney
Old February 2nd 08, 09:53 AM posted to sci.military.naval,rec.aviation.military.naval
Kerryn Offord
Default Boeing Awarded Contract For Next-Generation Harpoon Block IIIMissile
Fred J. McCall wrote:
:See:
category.
I thought you said you worked for a military contractor? (Or do your lot
make the Harpoon?)
Old February 2nd 08, 12:00 PM posted to sci.military.naval,rec.aviation.military.naval
Paul J. Adam
In message
writes
See:
http://www.spacewar.com/reports/Boei...r_Next_Generat
ion_Harpoon_Block_III_Missile_999.html
For as long as Harpoon keeps doing the job. You hit tradeoff territory
on missile speed: flying faster means you can't come in so low,
increases your radar and thermal signature, and gets you some other
drawbacks.
The nation that makes a great distinction between its scholars and its
warriors, will have its thinking done by cowards and its fighting done
by fools.
-Thucydides
pauldotjdotadam[at]googlemail{dot}.com
Old February 2nd 08, 02:04 PM posted to sci.military.naval, rec.aviation.military.naval
Jack Linthicum
:See:
:http://www.spacewar.com/reports/Boei..._For_Next_Gene...
category.
make the Harpoon?)
Yes
Old February 2nd 08, 03:42 PM posted to sci.military.naval,rec.aviation.military.naval
dott.Piergiorgio
make the Harpoon?)
Yes
Jack, the question are for Fred....
Best regards from Italy,
Dott. Piergiorgio.
Old February 2nd 08, 05:41 PM posted to sci.military.naval,rec.aviation.military.naval
Fred J. McCall
:Fred J. McCall wrote:
: wrote:
: :See:
: :How much longer will the Navy keep upgrading Harpoon before
: :switching to a newer, possibly supersonic, weapon?
: This one seems to fall into the "if it works, don't **** with it"
: category.
: What do you want a newer weapon to do that would work better than
: what's already there and in the development plan?
:I thought you said you worked for a military contractor?
I do, but what does that have to do with anything?
Or do your lot make the Harpoon?)
Nope.
"The reasonable man adapts himself to the world; the unreasonable
man persists in trying to adapt the world to himself. Therefore,
all progress depends on the unreasonable man."
--George Bernard Shaw
Old February 2nd 08, 05:50 PM posted to sci.military.naval,rec.aviation.military.naval
Fred J. McCall
"dott.Piergiorgio" wrote:
:Jack Linthicum ha scritto:
: I thought you said you worked for a military contractor? (Or do your lot
: make the Harpoon?)
: Yes
:Jack, the question are for Fred....
And, as usual, Jack doesn't know what he's talking about.
"False words are not only evil in themselves, but they infect the
soul with evil."
-- Socrates
Old February 2nd 08, 06:09 PM posted to sci.military.naval, rec.aviation.military.naval
Jack Linthicum
: Yes
soul with evil."
-- Socrates
Not necessarily true, truth Raytheon doesn't make the Harpoon missile,
another truth they do make the guidance on several versions. It's
called evading the truth.
http://www.astronautix.com/lvs/harpoon.htm
Model: UGM-84C. Short range cruise missile. Country: USA. Department
of Defence Designation: UGM-84C. Popular Name: Harpoon.
Sub-launched version.
Manufacturer: The Boeing Co., Military Aircraft & Missile Systems
Group. Location: St. Louis, MO, USA. Guidance contractor: Raytheon,
Loral, Northrop Grumman. Total Mass: 694 kg (1,530 lb). Core Diameter:
0.34 m (1.10 ft). Total Length: 4.79 m (15.71 ft). Span: 0.92 m (3.00
ft). Maximum range: 120 km (70 mi). Boost Propulsion: Turbojet. Boost
engine: J402-CA-400. Guidance: Active Radar Homing.
Model: AGM-84A. Anti-ship missile. Country: USA. Department of
Defence Designation: AGM-84A. Popular Name: Harpoon.
Air launched anti-ship version.
Manufacturer: McDonnel Douglas. Location: St. Louis, MO, USA. Guidance
contractor: Raytheon, Loral, Northrop Grumman. Total Mass: 521 kg
(1,148 lb). Core Diameter: 0.34 m (1.11 ft). Total Length: 3.84 m
(12.59 ft). Span: 0.91 m (2.98 ft). Standard warhead mass: 226 kg (498
lb). Maximum range: 285 km (177 mi). Boost Propulsion: Turbojet. Boost
engine: J402-CA-400. Guidance: Active Radar Homing. Maximum speed: 960
kph (590 mph).
Model: AGM-84E. Short range cruise missile. Country: USA. Department
of Defence Designation: AGM-84E. Popular Name: SLAM.
Standoff air launched land attack missile.
Group. Location: St. Louis, MO, USA. Guidance contractor: Boeing,
Raytheon. Total Mass: 628 kg (1,384 lb). Core Diameter: 0.34 m (1.10
ft). Total Length: 4.45 m (14.60 ft). Span: 0.92 m (3.00 ft). Standard
warhead mass: 226 kg (498 lb). Maximum range: 260 km (160 mi). Boost
Propulsion: Turbojet. Boost engine: J402-CA-400. Guidance: Imaging
Infra-Red Homing/GPS/datalink.
Old February 2nd 08, 06:44 PM posted to sci.military.naval, rec.aviation.military.naval
eatfastnoodle
On Feb 2, 2:24*am, Fred J. McCall wrote:
:See:
category.
* * * * * * * * * * * * * *-- Charles Pinckney
F14/F15/F16/F18 certainly work, so why do we spend tens of billions of
dollars on F22/F35? Why not just buy newer upgraded version of Eagle
and Falcon? Cause the enemies aren't sitting still, what works today
might not work tomorrow, you must plan for the future.
AeroVironment Awarded Contract for Development of Global Observer Stratospheric Unmanned Aircraft System Larry Dighera Piloting 4 May 21st 09 01:57 AM
ITT awarded ADS-B contract Doug Vetter Piloting 7 August 31st 07 07:32 PM
Boeing $241.8 million contract ballistic missile-hunting Airborne Laser Larry Dighera Military Aviation 1 May 29th 04 12:05 PM
Next Generation Aircraft Carrier Contract Awarded Otis Willie Naval Aviation 6 May 23rd 04 02:53 PM
The U.S. Air Force awarded BOEING CO. a $188.3 million new small-diameter precision-guided bomb contract Larry Dighera Military Aviation 3 October 28th 03 12:07 PM
