Question for floatplane pilots or those familiar with the rules
Old January 31st 08, 02:24 PM posted to rec.aviation.piloting
es330td
Default Question for floatplane pilots or those familiar with the rules
Can a float plane land on a body of water inside a city, more
specifically, could one land he
http://maps.google.com/?ie=UTF8&ll=3...&t=h&z=16&om=0
Note: the body of water is privately owned and in case you were
wondering, that is the building in which I work. The land on the NW
end of the lake is covered with bushes that are only 3-4 feet tall.
Old January 31st 08, 02:34 PM posted to rec.aviation.piloting
Gig 601XL Builder[_2_]
As far as the FAA is concerned yes. Local, county or state laws may not
allow it though.
Old January 31st 08, 03:34 PM posted to rec.aviation.piloting
Frank Stutzman[_2_]
allow it though.
And I am guessing that you don't own the building in which you work.
If thats the case I think your employer might take a dim view of this.
Or more correctly, your employers insurance carrier might take a very
dim view of this.
Frank Stutzman
Bonanza N494B "Hula Girl"
Boise, ID
Old January 31st 08, 04:20 PM posted to rec.aviation.piloting
es330td
On Jan 31, 10:34*am, Frank Stutzman
dim view of this.
You are correct; I don't own the building though the building owner
does own the land (and body of water.) I figured I probably couldn't
land there, but if there was any possibility I could fly to work I
should at least find out.
Old January 31st 08, 05:59 PM posted to rec.aviation.piloting
xyzzy
On Jan 31, 12:20 pm, es330td wrote:
On Jan 31, 10:34 am, Frank Stutzman
dim view of this.
that pond looks awfully small. Looks like less than 1000 feet long and
curved. You'd need to be a pretty skilled floatplane pilot to land
and takeoff there.
Old January 31st 08, 07:14 PM posted to rec.aviation.piloting
es330td
dim view of this.
does own the land (and body of water.) *I figured I probably couldn't
curved. *You'd need to be a pretty skilled floatplane pilot to land
and takeoff there.
I have no idea how much space it takes to land or take off in a
floatplane. It would only be me in the plane and it would be some
kind of lightweight kitplane so in the event it were permissable to
land a plane there I would find the perfect plane to get me in and
out. I didn't even know if this is something worth pursuing. It
sounds like it isn't.
As an aside, I ran into the facilities manager in the hallway this
morning. He told me the pond is actually filling in and the owner has
no plans to dredge it because someday after it fills in it will be
usable land. Flying in there would be a temporary solution anyway.
Old January 31st 08, 10:17 PM posted to rec.aviation.piloting
Bob Gardner
A truism applicable to both land and seaplanes: You can get into a place
that you can't get out of.
Bob Gardner
"es330td" wrote in message
dim view of this.
and takeoff there.
Old February 1st 08, 12:23 AM posted to rec.aviation.piloting
Robert M. Gary
In a sea plane is kind off cool in that if you set it down right on
the water and pull the power it comes off the step pretty quick. Once
off the step its like speed brakes. Taking off almost has a bit of a
safety factor built in. It takes more power to get on the step than to
take off. So if you find yourself nearing the end of the water and
you're not on the step you know you aren't going to take off. Pulling
back power results in a very quick near-stop.
-Robert
Old February 3rd 08, 05:16 PM posted to rec.aviation.piloting
xxx
specifically, could one land hehttp://maps.google.com/?ie=UTF8&ll=3...9&spn=0.012551,...
The rule of thumb is that you can land a seaplane anywhere you can
legally put a power boat. This rules out a few reservoirs but most
bodies of water are OK. Some parts of some lakes are off-limits due to
safety concerns for swimmers, etc.
The Seaplane Pilots Organization http://www.seaplanes.org publishes a
national directory with a lot of detail on landing sites all over the
country.
On private land, you'd just need permission from the landowner,
assuming you can get there from the air without violating any FARs.
What some ignorant, fearful local law enforcement type would think is
another story.
I wouldn't try it if the pond is much less than 3,000 ft.
Old February 6th 08, 09:14 PM posted to rec.aviation.piloting
es330td
I think it's only about 1000 feet. Funny how things that look big on
the ground look really small when you think about putting a plane down
on it.
Rules for interior modifications of Certified Aircraft (question). EridanMan Home Built 1 March 30th 06 11:34 PM
State Record Rules Question Gary Emerson Soaring 2 February 22nd 05 03:30 AM
Rules Question... Gary Emerson Soaring 1 February 8th 05 01:20 PM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
Question for any commericial airline rules experts out there Ted Wagner Soaring 6 February 7th 04 11:40 PM
