#31
#32
#33
Judah,
However, in a vaccuum, there would be no air to travel past the wings to generate lift, and therefore it would not fly. Ah, but what if it is ground vacuum? -- Thomas Borchert (EDDH) |
#34
Thomas Borchert wrote in
: Judah, However, in a vaccuum, there would be no air to travel past the wings to generate lift, and therefore it would not fly. Ah, but what if it is ground vacuum? You mean like a hoover? Then it will get sucked in regardless of the wheels or conveyor... |
#35
On Feb 4, 5:00*pm, (Edward A. Falk) wrote:
To solve this puzzle, you need to ask how the control system works. Method #1: *A device attached to the vehicle monitors the speed of the wheels and transmits this to the conveyor belt's control system which runs the belt in the opposite direction at the same speed. Method #2: *Some sort of position-detecting system observes the vehicle's position on the belt, and feeds back to a servo system that increases the belt's backwards speed if the vehicle starts making forward progress, or decreases it if the vehicle starts sliding backwards. (Someone want to propose a different control system?) Both systems are actually equivalent in their effects on automobiles and airplanes. An automobile is held in position no matter what the driver attempts to do. With airplanes, the situation is different. *Because the plane has free-wheeling wheels, and doesn't depend on pushing against the belt in order to move forward, it begins to make progress. At this point, the belt -- which is a perfect conveyor belt -- instantly speeds up to infinite speed. *The airplane's wheels -- which are perfect wheels -- likewise instantly spin up to infinite speed. *Since the wheels are perfect and have no friction, the airplane is not affected and takes off anyway. If you don't assume perfect abstractions, then the answer depends on what happens first: *Either a) the belt reaches its upper speed limit and the plane takes off, b) the plane's bearing seize and the plane is flung backwards off the belt, or c) the breeze caused by friction between the belt and the atmosphere is sufficient for the plane to take off before a) or b) happens. -- * * * * -Ed Falk, * * * *http://thespamdiaries.blogspot.com/ Well, if you are going to start inserting idealized and impossible conditions, then lets say that the wheels are also ideal and generate no friction. In that case, the plane will still take off because the wheels impart no force whatsoever on the airplane... |
MythBusters airplane on a conveyor belt | Peter Clark | Piloting | 56 | February 3rd 08 10:05 PM |
Mythbusters/airplane/treadmill | Harry K | Home Built | 0 | January 25th 08 03:42 AM |
FYI: Dec 12 MythBusters: Airplane Hour | Jim Logajan | Piloting | 217 | December 21st 07 11:33 AM |
FYI: Dec 12 MythBusters: Airplane Hour | Jim Logajan | Home Built | 113 | December 16th 07 07:29 PM |
Airplane Taxies Into Car: Video Footage | Hans | Piloting | 10 | June 26th 06 02:06 AM |
