Why airplanes taxi
Old February 6th 08, 07:00 PM posted to rec.aviation.piloting
Mxsmanic
Default Why airplanes taxi
writes:
And to answer your next post before you post it:
What molecules?
http://en.wikipedia.org/wiki/Outer_space
"While not being an actual perfect vacuum, outer space contains such sparse
matter that it can be effectively thought of as one. The pressure of
interstellar space is on the order of 10 pPa (1×10-11 Pa)."
So, no molecules. And no friction.
Even if you don't wish to consider the hard vacuum of space as perfect, with a
pressure that is 10,000,000,000,000,000 times lower than that of Earth at sea
level, the friction should be also that much lower, and thus the speed of a
taxi should be trillions of times faster. The speed of light is only fifteen
million times faster than a 40-knot taxi, so nearly the speed of light might
well be achieved long before any residual friction could have any effect.
Old February 6th 08, 07:02 PM posted to rec.aviation.piloting
Mxsmanic
Robert M. Gary writes:
On Feb 6, 9:24*am, Mxsmanic wrote:
writes:
Fixed-wing aircraft taxi because their wheels reduce friction as they
move forward on the ground.
So, logically, spacecraft in the frictionless environment of outer space
should immediately accelerate to the speed of light.
No, it still takes energy to accelerate a mass, even in a frictionless
environment.
But the original post said that aircraft taxi because their wheels reduce
friction. No mention of energy or force. So if the statement is true,
movement results from a lack of friction alone, so zero friction should
produce infinite speed (or lightspeed if one allows the speed of light as an
absolute upper limit).
However, space (especially near space) is not frictionless.
Nor does friction produce acceleration. QED.
Old February 6th 08, 07:06 PM posted to rec.aviation.piloting
Tina
Gee, where would the energy come from to cause the acceleration?
On Feb 6, 2:00*pm, Mxsmanic wrote:
writes:
What molecules?
So, no molecules. *And no friction.
taxi should be trillions of times faster. *The speed of light is only fifteen
Old February 6th 08, 07:07 PM posted to rec.aviation.piloting
gpaleo[_2_]
"Phil J" wrote
Wrong. Wrong. Wrong.
Fixed-wing aircraft can only achieve a stable taxi by keeping the CG
between the forward and aft wheel points(WPs). This is why it is so
important in aircraft design that the WPs be placed correctly. In
the early days of aviation some designers placed all the wheels to one
side of the CG, with the result that the aircraft was dynamically
unstable in taxi. Sadly, many lives were lost before this phenomenon
was understood.
If the CG is placed correctly in relation to the WPs, the aircraft
establishes taxi by moving the Earth beneath it. Turns are achieved
by rotating the Earth. Flight is achieved by dropping the Earth down,
and a landing is made by lifting it back up. Aerobatics involve
combinations of lifting, dropping, and rotating.
I hope this clears things up for everyone.
Phil
Hah...hah....
This is called the pilot's perspective: (s)he sits in the cockpit and the
earth performs the requisite manoevers.
Old February 6th 08, 07:09 PM posted to rec.aviation.piloting
Tina
Phil, to support your theory, I can tell you the earth weighs 130
pounds in my gravitional field (that's before breakfast. It gains a
little after that.).
On Feb 6, 1:58*pm, Phil J wrote:
move forward
on the ground.
Wrong. *Wrong. *Wrong.
between the forward and aft wheel points(WPs). * This is why it is so
important in aircraft design that the WPs be placed correctly. * In
unstable in taxi. *Sadly, many lives were lost before this phenomenon
was understood.
establishes taxi by moving the Earth beneath it. *Turns are achieved
by rotating the Earth. *Flight is achieved by dropping the Earth down,
and a landing is made by lifting it back up. *Aerobatics involve
Phil
Old February 6th 08, 07:11 PM posted to rec.aviation.piloting
Gene Seibel
On Feb 6, 11:24*am, Mxsmanic wrote:
writes:
http://en.wikipedia.org/wiki/Inertia
Gene Seibel
Gene & Sue's Flying Machine - http://pad39a.com/gene/
Because we fly, we envy no one.
Old February 6th 08, 07:20 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Mxsmanic wrote in
writes:
Space isn't frictionless dummy.
Where does the friction come from?
Klingons, fjukkwit!
Bertie
Old February 6th 08, 07:21 PM posted to rec.aviation.piloting
Mxsmanic wrote in
writes:
What molecules?
sparse matter that it can be effectively thought of as one.
A bit like the inside of your skull.
Bertie
yrb-49-taxi.jpg [email protected] Aviation Photos 2 September 25th 07 09:50 PM
Hanoi Taxi john smith Piloting 0 April 27th 06 03:48 AM
License To Taxi? SteveT Piloting 29 October 16th 05 04:57 PM
Leaning for taxi Jim Rosinski Piloting 28 September 12th 04 03:53 AM
taxi in reverse? [email protected] Owning 20 February 21st 04 12:26 AM
