Palm PDA Field experience?
Old February 9th 08, 03:25 AM posted to rec.aviation.soaring
Frank[_1_]
Default Palm PDA Field experience?
Hi,
I'm looking for a replacement Palm PDA to run SoaringPilot software.
I have a Tungsten T and I'm very happy with it's display clarity even
in bright sunlight, but it has a problem with touchscreen registration
when it gets hot, and this often makes the software unusable.
Anyone currently using other Palm devices, like the Tungsten E2 or
TX? If so, have you had any problems with touch-screen registration
and/or display glare/contrast?
TIA,
Frank(TA)
Old February 9th 08, 07:08 AM posted to rec.aviation.soaring
Clint
I went for a monochrome display - found the colour screens not great
for soaringpilot. found a IBM PDA similar to a PALM VX which I have
dedicated to soaring. It was cheap at about $100 eventhough new at the
time - sure they can be found really cheap on e-bay. No problems
running soaringpilot which has always been written with lower
processing power in mind and is not very graphic. Have tried a few
other solutions using my IPAQ but always go back to the trusty palm
running soaringpilot with its monochrome screen - its just so easy to
see and use.
Clinton
LAK 12
Old February 10th 08, 11:07 PM posted to rec.aviation.soaring
Markus Gayda
Hi Frank,
Frank schrieb:
Hi,
Try disassembling the T and cleaning the flat-cable connectors.
That did the trick for the 3 Tungsten-T models in our club.
The "T" is still the Palm to go for.
Cheap, really good display in the sun and fast.
CU
Markus
Old February 11th 08, 02:44 AM posted to rec.aviation.soaring
Dave Rolley[_2_]
Have you tried this?
http://www.palm.com/us/support/downl...digitizer.html
Dave
Markus Gayda wrote:
Hi Frank,
Frank schrieb:
Hi,
CU
Markus
Old February 11th 08, 06:05 PM posted to rec.aviation.soaring
Frank[_1_]
Dave
Thanks for the pointer, but yes, I have already tried this, and the
connector cleaning also
Frank
Old February 12th 08, 12:57 AM posted to rec.aviation.soaring
Dave Rolley[_2_]
OK, here is something else to try:
http://www.palmpowerups.com/news.php
Look for PowerDiGi. Supposedly it can address some of the digitizer
registration problems.
Dave
Dave
Frank
Old February 17th 08, 07:11 PM posted to rec.aviation.soaring
Paul[_5_]
On Fri, 8 Feb 2008 19:25:25 -0800 (PST), Frank
Hi,
TIA,
Frank(TA)
I used a Tungsten W last year but haven't given it as much exercise as
I'd like since then. The "W" has a cellphone in it (which you can turn
off and ignore) and a small keyboard like a Blackberry. The screen was
very clear in sunlight and I like the ability to use the keyboard to
access the different screens directly.
The "W" runs the older Palm v4 operating system (see the Wikipedia
article on the subject) but runs SoaringPilot just fine.
They appear on eBay quite often and dismantling to insert a new
battery isn't too scary.
Paul
How to charge a Palm in C-172? Marc Piloting 4 June 28th 04 05:49 PM
Nexrad for Palm PaulH Owning 3 May 15th 04 06:25 PM
FS: PALM ® M105 $40 Jaysen Underhill General Aviation 0 December 11th 03 09:39 PM
FS: PALM ® M105 $40 Jaysen Underhill Aviation Marketplace 0 December 11th 03 09:38 PM
FS: PALM ® M105 $45 Jaysen Underhill Aviation Marketplace 0 October 17th 03 01:26 AM
