Why airplanes taxi
Old February 10th 08, 06:31 PM posted to rec.aviation.piloting
WingFlaps
Default Why airplanes taxi
On Feb 11, 5:47*am, Mxsmanic wrote:
WingFlaps writes:
So how do you explain the rather well known lapse rate?
In both cases, the correlation is between temperature and altitude, not
temperature and pressure.
Are you saying the air knows how high it is? That's amazing 'cos I use
a sensitive pressure meter to tell me my altitude!
Sounds like you are BS'ing to cover a mistake to me.
Cheers
  #103
Old February 10th 08, 07:43 PM posted to rec.aviation.piloting
terry
On Feb 11, 3:40*am, Mxsmanic wrote:
terry writes:
You see the fact that the volume of the atmophere or of space is
infinite is quite irrelvant because nobody wants to know what the
average density of the whole atmophere is ( which of course will
approach zero depending on your definition of where the atmsophere
actually ends).
It is very highly relevant. *If you increase the temperature of the
atmosphere, for example, the pressure does not rise, because nothing
constrains the atmosphere--it simply expands. *Atmospheric pressure comes from
gravity, which is a constant, and not from any constraints applied to the
volume of air, of which there are none. *In the highest portions of the
atmosphere, the temperature rises to several thousand degrees, but the
pressure remains extremely low. *At the surface, you might see variations in
absolute temperature of 1/3, but you won't see variations in pressure anywhere
near that magnitude.
Did I say the pressure would rise if you increased the temperature?.
For the last time, if you know the temperature and pressure you know
the density,. for gods sake, gets some help with your attention
problem.... or go away
terry
  #106
Old February 10th 08, 07:55 PM posted to rec.aviation.piloting
Mxsmanic
WingFlaps writes:
No.
  #109
Old February 10th 08, 08:28 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Mxsmanic wrote in
WingFlaps writes:
No.
Wrong/
Bertie
  #110
Old February 10th 08, 10:07 PM posted to rec.aviation.piloting
Mxsmanic
terry writes:
If it follows the combined laws, it will. But in the case of the atmosphere,
it doesn't, because the volume of the atmosphere is not constrained, and the
source of atmospheric pressure is gravity, not the random kinetic energy of
air molecules.
yrb-49-taxi.jpg [email protected] Aviation Photos 2 September 25th 07 09:50 PM
Hanoi Taxi john smith Piloting 0 April 27th 06 03:48 AM
License To Taxi? SteveT Piloting 29 October 16th 05 04:57 PM
Leaning for taxi Jim Rosinski Piloting 28 September 12th 04 03:53 AM
taxi in reverse? [email protected] Owning 20 February 21st 04 12:26 AM
