#141
On Tue, 05 Feb 2008 13:32:23 -0500, Dudley Henriques
wrote: snip I'd be curious to know how many actually carry around the checklist outside while preflighting? Ricky [rec.aviation.student added] There is absolutely no reason why a written checklist has to deviate from a flow pattern, and indeed, a well written checklist will follow a flow pattern. If it doesn't, I suggest re-writing it so it does. I recommend using a written checklist all the time; the exterior inspection included. For many years I simply followed the "flow" *until* I was interrupted in one preflight, three times. I had developed the habit of starting over, but after three times I started in where I left off. All went well until I brought the nose up on rotation. Strange thing, the left cowl stood up about the same time. I'll swear more local pilots saw that than we have room for parking at the airport.. I've always used a written check list since then. If I could be interrupted once and make a mistake, it could happen again. Roger (K8RI) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#142
Roger wrote:
On Tue, 05 Feb 2008 13:32:23 -0500, Dudley Henriques wrote: snip I'd be curious to know how many actually carry around the checklist outside while preflighting? Ricky [rec.aviation.student added] There is absolutely no reason why a written checklist has to deviate from a flow pattern, and indeed, a well written checklist will follow a flow pattern. If it doesn't, I suggest re-writing it so it does. I recommend using a written checklist all the time; the exterior inspection included. For many years I simply followed the "flow" *until* I was interrupted in one preflight, three times. I had developed the habit of starting over, but after three times I started in where I left off. All went well until I brought the nose up on rotation. Strange thing, the left cowl stood up about the same time. I'll swear more local pilots saw that than we have room for parking at the airport.. I've always used a written check list since then. If I could be interrupted once and make a mistake, it could happen again. Roger (K8RI) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Perfect example, and the exact reason why we should teach flow interruption as a prime source of accidents. Checklists rule! -- Dudley Henriques |
#143
In rec.aviation.student Dudley Henriques wrote:
Michael Ash wrote: * http://en.wikipedia.org/wiki/Hans_Guido_Mutke is the German guy, but apparently it's unlikely that he actually did it, and in any case it will probably never be known for sure. Actually it is known. Mutke honestly believed he had gone supersonic in a dive with the 262. Post war investigation with the 262 firmly established that the basic airframe was incapable of transitioning the transonic region through Mach 1. The drag curves were too high as the shock waves formed on the aircraft shape. Investigation also established that the PROBABLE CAUSE of Mutke thinking he had gone supersonic involved issues with his airspeed indicator vs the pressure changes involved in his dive. You learn something every day. The article I posted seems reluctant to come to any sort of conclusion, but you're more trustworthy so I'll take yours. Thanks! -- Michael Ash Rogue Amoeba Software |
#144
Roger wrote:
For many years I simply followed the "flow" *until* I was interrupted in one preflight, three times. I had developed the habit of starting over, but after three times I started in where I left off. All went well until I brought the nose up on rotation. Strange thing, the left cowl stood up about the same time. I'll swear more local pilots saw that than we have room for parking at the airport.. I've always used a written check list since then. If I could be interrupted once and make a mistake, it could happen again. Roger (K8RI) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com A similar experience for me. I was once interrupted during my run-up by a radio call. I then started my take-off run, but had to abort because of a noticeable lack of power. Turned out the engine was running on one mag. The radio call had caught me in the middle of my mag check. |
#145
Michael Ash wrote:
In rec.aviation.student Dudley Henriques wrote: Michael Ash wrote: * http://en.wikipedia.org/wiki/Hans_Guido_Mutke is the German guy, but apparently it's unlikely that he actually did it, and in any case it will probably never be known for sure. Actually it is known. Mutke honestly believed he had gone supersonic in a dive with the 262. Post war investigation with the 262 firmly established that the basic airframe was incapable of transitioning the transonic region through Mach 1. The drag curves were too high as the shock waves formed on the aircraft shape. Investigation also established that the PROBABLE CAUSE of Mutke thinking he had gone supersonic involved issues with his airspeed indicator vs the pressure changes involved in his dive. You learn something every day. The article I posted seems reluctant to come to any sort of conclusion, but you're more trustworthy so I'll take yours. Thanks! Well, as for "trustworthy" :-)))) just be advised that like you, I depend on outside sources for this kind of information. Mine came through the Naval Test Pilot School, but they in turn have history sources relying on their data. The bottom line on these things is that the chances are what I've related to you is factual and correct, but I wasn't there to verify in person. Hope this helps a bit -- Dudley Henriques |
#146
Michael Ash wrote: In rec.aviation.student Dudley Henriques wrote: Michael Ash wrote: * http://en.wikipedia.org/wiki/Hans_Guido_Mutke is the German guy, but apparently it's unlikely that he actually did it, and in any case it will probably never be known for sure. Actually it is known. Mutke honestly believed he had gone supersonic in a dive with the 262. Post war investigation with the 262 firmly established that the basic airframe was incapable of transitioning the transonic region through Mach 1. The drag curves were too high as the shock waves formed on the aircraft shape. Investigation also established that the PROBABLE CAUSE of Mutke thinking he had gone supersonic involved issues with his airspeed indicator vs the pressure changes involved in his dive. You learn something every day. The article I posted seems reluctant to come to any sort of conclusion, but you're more trustworthy so I'll take yours. Thanks! Well, as for "trustworthy" :-)))) just be advised that like you, I depend on outside sources for this kind of information. Mine came through the Naval Test Pilot School, but they in turn have history sources relying on their data. The bottom line on these things is that the chances are what I've related to you is factual and correct, but I wasn't there to verify in person. All good points, but you have two key advantages. First, you tend to have better sources (Naval Test Pilot School instead of random internet web pages), and second, you have a better ability to judge the source. Hope this helps a bit Always good food for thought around here. -- Michael Ash Rogue Amoeba Software |
#147
Michael Ash wrote:
In rec.aviation.student Dudley Henriques wrote: Michael Ash wrote: In rec.aviation.student Dudley Henriques wrote: Michael Ash wrote: * http://en.wikipedia.org/wiki/Hans_Guido_Mutke is the German guy, but apparently it's unlikely that he actually did it, and in any case it will probably never be known for sure. Actually it is known. Mutke honestly believed he had gone supersonic in a dive with the 262. Post war investigation with the 262 firmly established that the basic airframe was incapable of transitioning the transonic region through Mach 1. The drag curves were too high as the shock waves formed on the aircraft shape. Investigation also established that the PROBABLE CAUSE of Mutke thinking he had gone supersonic involved issues with his airspeed indicator vs the pressure changes involved in his dive. You learn something every day. The article I posted seems reluctant to come to any sort of conclusion, but you're more trustworthy so I'll take yours. Thanks! Well, as for "trustworthy" :-)))) just be advised that like you, I depend on outside sources for this kind of information. Mine came through the Naval Test Pilot School, but they in turn have history sources relying on their data. The bottom line on these things is that the chances are what I've related to you is factual and correct, but I wasn't there to verify in person. All good points, but you have two key advantages. First, you tend to have better sources (Naval Test Pilot School instead of random internet web pages), and second, you have a better ability to judge the source. Hope this helps a bit Always good food for thought around here. Well..I'm getting older for sure, but still managing to hang in there :-) -- Dudley Henriques |
#148
"Ken S. Tucker" wrote in
: Hmm.... On Feb 11, 2:33 pm, Dudley Henriques wrote: Michael Ash wrote: This has not been my experience at all. Pilots, from what I have seen, are extreme pessimists. They tend to assume that any problem they find with the aircraft or see in the air will kill them, even though 99% of the time it will not. This is, of course, because the other 1% of the time it will. It's paranoid, but it's justified. You are absolutely correct. Good pilots treat anything and everything connected with flying as something that can kill them...until either it's proved not capable of doing that or they themselves have eliminated it as a risk factor. Nope, pilots aren't qualified to make those decisions, an exceptional pilot might have a Ph.d in Aerodynamics, electronics, mechanics and physics, but that's like .01%, a fella like Yeager has the equivalent, but he's a genius. By and large, pilots are licensed by govmonk workers, and the majority of accidents are caused by licensed pilot error, that's a fact Not that you'd need a licence to wreck an airpklane, Kenny. O toucgh luck with the Looney Maroon award for January, but never fear, I'm sure you'll win it eventualy. Bertie |
#149
Dudley Henriques wrote in
: Actually it is known. Mutke honestly believed he had gone supersonic in a dive with the 262. Post war investigation with the 262 firmly established that the basic airframe was incapable of transitioning the transonic region through Mach 1. The drag curves were too high as the shock waves formed on the aircraft shape. Investigation also established that the PROBABLE CAUSE of Mutke thinking he had gone supersonic involved issues with his airspeed indicator vs the pressure changes involved in his dive. That's right. Compressibility can cause airspeed indicators to jump at around critical mach depending on where they are mounted. Bertie |
#150
Euan Kilgour wrote in
: On Feb 13, 4:40 am, "Ken S. Tucker" wrote: Hmm.... On Feb 11, 2:33 pm, Dudley Henriques wrote: The way I was instructed to fly included me building and maintaining a working knowledge of aerodynamics, navigation, meteorology, aircraft technical specs, and human physiology in the aviation environment. Do I require a PhD in those aviation subjects in order to make decisions that will keep the plane flying and me and my passengers safe? Hell no! And why bother twisting facts to make a truly daft point of view seem justified? You can never remove human error from any flight where a pilot is involved, no matter how many degrees they have. Its a matter of accepting that human error exists and utilizing procedures designed to manage it as best you can. Well, you simply don't need one. Test pilots all got them by and by so they could talk to the guys who were buildng the things in their language, basically. And like any sort of math, it gives a more thorough understanding of of performance which allowsa pilto to sial closer to the "edge" Bertie |
| I learned about flying from this | Ricky | Piloting | 7 | January 26th 08 06:50 PM |
| Always something to be learned | [email protected] | Owning | 7 | December 19th 07 06:22 PM |
| [OT] Nothing Learned From History | stop spam | Military Aviation | 48 | September 26th 04 11:43 PM |
| [OT] Nothing Learned From History | Chris Mark | Military Aviation | 4 | September 14th 04 08:27 PM |
| How many of you learned to fly from relatives? | lardsoup | Piloting | 0 | October 15th 03 12:40 AM |
