CB SWR meter on 122Mhz?
Old February 13th 08, 04:04 PM posted to rec.aviation.homebuilt
noman
Default CB SWR meter on 122Mhz?
How well do you think a CB SWR meter will work for testing the antenna
installation in an airplane?
thanks,
tom
Old February 13th 08, 04:11 PM posted to rec.aviation.homebuilt
Jay Maynard
Not worth a damn. The sensing circuitry is almost certainly not going to work
properly at VHF. A meter designed for the 2-meter ham radio band would work,
though.
What are you trying to find out? Unless something is corroded or broken,
whatever problem you have is probably not your antenna.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
http://www.hercules-390.org (Yes, that's me!)
Buy Hercules stuff at http://www.cafepress.com/hercules-390
Old February 13th 08, 04:19 PM posted to rec.aviation.homebuilt
noman
My radio seems to be overloaded by strong local commercial stations.
Otherwise, range and clarity are fine. I just got to wondering if my
homemade antenna or cable are a problem. To do the original install,
I used an rf field strength meter and simply adjusted the antenna
length for highest reading. It all seems to work fine, I can talk to
aircraft 40 miles away when we are both at 1000agl, but when I get
near some commercial antennas the station bleeds in and breaks the
squelch, even with it turned all the way up. I have seen this on
other rental planes, too.
tom
Jay Maynard, K5ZC
Old February 13th 08, 04:28 PM posted to rec.aviation.homebuilt
RST Engineering
As stated, the odds of a 27 MHz. SWR meter giving useable results on the VHF
aircraft band are slim to zero.
"If you think you can, or think you can't, you're right."
--Henry Ford
"noman" wrote in message
Not an unusual situation with inexpensive radios with poor front end
filtering, especially for high power FM stations at the top of the band and
at the image frequency of the radio (plus the various harmonic, crossmod,
and intermod combinations of the FM stations and your radio's
superheterodyne configuration).
That probably wasn't the cleverest way of doing it. Describe your
installation a little more, but I think I can guarantee you that it isn't
the antenna.
Then why in heaven's name would you suspect YOUR antenna if the same thing
happens to OTHER aircraft and their radios? Their antennas couldn't have
ALL failed in the same way.
Old February 13th 08, 04:36 PM posted to rec.aviation.homebuilt
Jay Maynard
Maybe not the cleverest way, but it's probably good enough that it's working
fine.
Describe your installation a little more, but I think I can guarantee you
that it isn't the antenna.
I agree. This sounds like a front end overload problem. No antenna in the
world will fix that. (Well, at least not and still work for the intended
purpose.)
Old February 13th 08, 04:37 PM posted to rec.aviation.homebuilt
Tom,
I concur with Jay. You need a unit designed for the frequency being tested.
MFJ Enterprises has as series of suitable VHF SWR/Watt Meters starting at
about $40.
http://www.mfjenterprises.com/Caterg...45fc51f462651f
or
http://tinyurl.com/yo26k6
I personally use the SWR in my old RST-721 test set.
W7ADK
http://www.soaridaho.com/
"Jay Maynard" wrote in message
work
work,
though.
Old February 13th 08, 04:52 PM posted to rec.aviation.homebuilt
RST Engineering
W7ADK
Old February 13th 08, 05:28 PM posted to rec.aviation.homebuilt
Jim,
The RST-721 is a great little unit. In addition to tuning the antennas on
the local experimental sailplanes, I use it for my 2 meter equipment.
I didn't build one of your transceivers. I inherited the unit from a friend
who retired from soaring in his 80s.
(http://www.soaridaho.com/photogaller...k_is_Ready.jpg)
I wish aircraft tranceiver kits were still available. I enjoy building
electronics as much as working on my sailplane.
(http://www.soaridaho.com/Schreder/HP-14/N990/N990.html) I built all my
amateur radion HF equipment. (Heathkit SB-310, SB-200, SB-101 and SB640)
These old tube-based units are still running great.
W7ADK
"RST Engineering" wrote in message
W7ADK
Old February 13th 08, 05:33 PM posted to rec.aviation.homebuilt
Bob Kuykendall
On Feb 13, 8:11*am, Jay Maynard
Not worth a damn....
My experience runs the other way. I've tested and troubleshooted
several VHF radio antenna installations using a cheap SWR meter, and
system performance has seemed pretty uniformly inversely proportional
to the SWR reading. Of course, that's far from scientific, but it
suggests that inaccurate measurements are better than no measurements
at all.
That also runs counter to my experience. Yeah, where we're talking
about classic quarter-wave whips or commercially available blade
antennas, I certainly agree. But when it comes to custom antennas,
internal antennas, copper-tape dipoles, oddly-shaped dipoles, dipole
antennas in fins and rudders, dipoles near metal parts, and carbon
fiber ground planes (all of which are common in sailplanes), radio
problems are way too often caused by the antenna or its installation.
Thanks, Bob K.
http://www.hpaircraft.com
Old February 13th 08, 05:45 PM posted to rec.aviation.homebuilt
Bob,
I played around with this a couple years ago. I trimmed an antenna using a
CB SWR to as close to 1:1 as I could get. I then measured it with my
RST-721. The '721 read 3.5:1. That is quiet a difference.
I did the same test using my quality HF SWR unit and '721 with the same
results.
HP-14 "6F"
"Bob Kuykendall" wrote in message
On Feb 13, 8:11 am, Jay Maynard
at all.
Thanks, Bob K.
For sale: DG-600 17-meter and 15-meter wingtips Lars Peder Hansen Soaring 0 January 21st 07 06:18 PM
FS: G Meter nobody Aviation Marketplace 0 August 6th 05 06:58 PM
G meter Paul Anton Home Built 0 June 4th 05 06:45 PM
SWR meter Paul Lee Home Built 3 May 31st 04 02:47 PM
G-meter G.R. Patterson III Piloting 2 February 29th 04 03:13 PM
