#111
Jim Logajan wrote in
: Bertie the Bunyip wrote: Almost all fears are born of ignorance. Eh? I thought the line went "Ignorance is bliss," not "Ignornace is fear?" I never said that. Or that if you are in a bad situation and aren't afraid, you're probably ignorant of what's going on? Or that. Or is it "We have nothing to fear, but fear itself?" Or that. All these trite statements can't be right, can they? Dunno. What is it you fear? Bertie |
#112
On Feb 15, 4:36 pm, "Blueskies" wrote:
If you always land full flap the likelyhood of a tail strike in a full stall landing is nil.... Dan D. Wrong. It's regularly done in 172s during soft-field landings. As a mechanic as well as a pilot, I get to replace the bent and broken tail tiedown rings that got banged on the runway. A little power, as used in the soft-field technique, with full flaps, yet, allows the airplane to achieve a higher deck angle in the touchdown and if the piloet uses a little too much power, he'll get the nose really high so that when the thing settles on the runway, the tail strikes first. It can get expensive. The tiedown ring ($40) gets busted, but if the strike was hard enough the whole tail section can sustain damage. We look hard at the entire tailcone, rudder hinges (because the big chunk of lead up top slugs downward on those little hinge brackets and cracks them), the stabilizer spars (more big chunks of lead on the elevator tips that want to keep going down, too, and can bent the spars), and so on. Dan |
#114
On Feb 17, 3:58*pm, Bertie the Bunyip wrote:
True, but having said that, the ASI should e regarded with some suspicion even IMC. Most pilots ( and I did this exercise in the sim the other day) when presented with bad airspeed info will chase it in preference to attitude info. this has caused lots of accidensts over the years. Two I can remember off the top of my head are the 757 off the coast of Peru, I think, and the 727 in upstate new york. I'm sure there have been lots of others in light airplanes. It's amazing to watch. The airspeed sems to run away and the guy just zeroes in on it and pulls or pushes until the whole scene is just such a mess recovery would be a miracle. Yeah, worst case is when the pitot freezes over or otherwise gets sealed off, so the ASI says you're slowing down when you're speeding up, and vice versa (because of the changing static-port pressure as you climb or descend). In theory, the ASI should then be out-voted by the altimeter and the attitude indicator, but I imagine it's tricky (I've never experienced it myself). That's one situation where the mushy response of a slow plane, or the stiff controls and whooshing sound in a diving one, might be especially helpful in augmenting what the instruments are saying (at least for the light planes I fly--dunno how well that applies to airliners). |
#115
I guess I'm going to have to start (and perhaps finish) my primary
training in order to understand this comment completely. I understand that being able to see outside helps the brain make a connection between the behavior of the airplane and what it looks like. However, couldn't you learn to feel the airplane and how it behaves only on instruments ever? Could you complete a PPL without ever looking out the window? At the risk of sounding like a simmer, why is this "feel" so necessary when training the beginning pilot and then relearned for an instrument rating? I know I'm making an error of logic here (otherwise pilot training would be much different), but what is it exactly? I have done enough research to understand the difference between VFR, VMC, IFR, and IMC and who and why you would fly in each one. I would imagine this is part of training when getting a PPL. So how would a pilot mix up these two worlds? -SPCT On Feb 17, 9:34 am, Dudley Henriques wrote: Yes. You are missing something, and it's vitally important you understand it....and understand it completely. Instrument flying is a totally separate issue from the way one learns to fly an airplane during initial training. They are integrated in certain ways. In other ways the two are entirely separate. We are discussing here the initial process of learning to fly, NOT flying in instrument conditions. VFR is one thing IFR is quite another. When an instructor discusses "flying by feel", they are in no way advocating the non-use of instruments and warning sensors available to the pilot in the aircraft. They are simply reducing the available "tools" the pilot relies on to a lower level to help the pilot understand his/her flight evironment more closely without the aid of artificial help. In the IFR scenario, an instructor will do the same thing when they reduce a pilot to flying on the primary panel only. Don't think of flying VFR and IFR in the same breath. This attitude can get a pilot into deep trouble down the line. When you start talking instruments, you're in a whole new ball game when it comes to cues. Everything changes. There are no more visual cues. There is no more "feeling" of the airplane. There are ONLY the instruments. It's a whole different flying world. You learn to fly by "feel" to better understand the aerodynamics and how the airplane interfaces in it's environment. Visual cues are part of this equation. Once these things are learned, you TRANSITION into a whole new world where instruments replace these cues. Don't EVER, as long as you fly, get these two worlds mixed up in your mind. Doing that will kill you in an airplane faster than you can imagine! -- Dudley Henriques |
#116
![]() wrote in message ... On Feb 15, 4:36 pm, "Blueskies" wrote: If you always land full flap the likelyhood of a tail strike in a full stall landing is nil.... Dan D. Wrong. It's regularly done in 172s during soft-field landings. As a mechanic as well as a pilot, I get to replace the bent and broken tail tiedown rings that got banged on the runway. A little power, as used in the soft-field technique, with full flaps, yet, allows the airplane to achieve a higher deck angle in the touchdown and if the piloet uses a little too much power, he'll get the nose really high so that when the thing settles on the runway, the tail strikes first. It can get expensive. The tiedown ring ($40) gets busted, but if the strike was hard enough the whole tail section can sustain damage. We look hard at the entire tailcone, rudder hinges (because the big chunk of lead up top slugs downward on those little hinge brackets and cracks them), the stabilizer spars (more big chunks of lead on the elevator tips that want to keep going down, too, and can bent the spars), and so on. Dan Like I said, the likelihood is nil. I didn't say it couldn't be done... Is this with the 'new' 30° flap limited machines or the older standard 40° flap machines? dČ |
#117
On Feb 17, 5:17*pm, wrote:
I guess I'm going to have to start (and perhaps finish) my primary training in order to understand this comment completely. I understand that being able to see outside helps the brain make a connection between the behavior of the airplane and what it looks like. *However, couldn't you learn to feel the airplane and how it behaves only on instruments ever? * Conceivably (except for landing, of course). But in VMC, you need to be looking out the window almost all the time in order to scan for other traffic (at least with current technology). The more time you spend looking at your instruments, the less time you're devoting to collision avoidance. So it's important to be able to perceive as much as possible without reference to the instruments. There's also the problem that instruments can fail, sometimes unobviously. VFR aircraft aren't required to provide as much rednundant information as IFR instruments. So again, it's important not to rely too much on the instruments. I have done enough research to understand the difference between VFR, VMC, IFR, and IMC and who and why you would fly in each one. *I would imagine this is part of training when getting a PPL. *So how would a pilot mix up these two worlds? If the transition to IMC is unexpected, a pilot may delay switching to instrument flight, clinging instead to fading and inadequate visual cues. Even in established, solid IMC, misleading perceptions of the plane's orientation often conflict with the instruments, creating illusions that can be dangerously hard to ignore. Conversely, in VMC, many pilots spend too much time looking at their instruments, creating an unnecessary collision hazard. |
#118
![]() Big John wrote: -----------------------------clip------------------------- But when they break to a stall, it happens abruptly, at too low a speed. They are totally stalled, and to boot one wing always stalls first, falls of and immediately a spin develops in that direction. One simply has to know that slow flight is always a touchy thing to do and airspeed observation is crucial. The Mooney series has leading edge stall strips about 30% out from the wing root to make the stall beak earlier at a faster airspeed where control effectivenes is better. light and powerful rudder and you have one easily spun airplane. -------------------------clip--------------------- Angelo campanella ************************************************** ************************* Stall strip on inboard portion of wings are to cause the inboard section of wing to stall before the tips, where ailerons are located.. This is to give you some aileron control in early part of a stall. OK, Thanks for reminding me of the more precise function of stall strips. You say "But when they break to a stall, it happens abruptly, at too low a speed". By that I mean for laminar flow wings without stall strips, the stall occurs at a low speed is not reversable; it really requires an increase of speed to start flying again. With stall strips, loss of lift occurs at a slightly higher speed where just dropping the nose to reduce the angle of attack will resume flying status. I suspect that of one could fly the same plane with and without stall strips, the bare wing would be flying all the time at the speed where the plane with stall strips would experience the mushing... I really can't say which plane would do which... I'm just reierating some basic aerodynamics. I've stalled aircraft at 400-500 mph. Not a big deal. I can believe that. Ang. C. |
#119
![]() We don't fly in a one cue world. (Instruments) Pilots have to learn to use any and all cues available to them to be thoroughly proficient at all times, and in all normally anticipated conditions commensurate with the ratings they hold and the aircraft they are flying. This means learning to use the senses such as the visual cues as well as how the aircraft feels physically to them through their hands and feet. The reason we learn to use all available cues is that when one cue fails we have another. Also, the manner in which we use these cues change. For example, when we are VFR, normally a pilot will use visual and audible, as well as physical cuing backed up by instrument cuing. In this case all cues are available so they are used. When we go IFR, we lose the visual cues and we deliberately set aside all the physically felt cues, and the instruments and audible cues become prime. The bottom line on all this is that if a pilot learned to fly using only instruments, that pilot would be denied a properly trained reference set of visual cues and physical cues. In other words, if you're trying to solve a physics problem, don't leave your algebra book at home! :-)) Flying a plane is nothing more than the proper application of a few sound basics. Learning to use all the available cues is simply learning sound basics. Thank you wrote: I guess I'm going to have to start (and perhaps finish) my primary training in order to understand this comment completely. I understand that being able to see outside helps the brain make a connection between the behavior of the airplane and what it looks like. However, couldn't you learn to feel the airplane and how it behaves only on instruments ever? Could you complete a PPL without ever looking out the window? At the risk of sounding like a simmer, why is this "feel" so necessary when training the beginning pilot and then relearned for an instrument rating? I know I'm making an error of logic here (otherwise pilot training would be much different), but what is it exactly? I have done enough research to understand the difference between VFR, VMC, IFR, and IMC and who and why you would fly in each one. I would imagine this is part of training when getting a PPL. So how would a pilot mix up these two worlds? -SPCT On Feb 17, 9:34 am, Dudley Henriques wrote: Yes. You are missing something, and it's vitally important you understand it....and understand it completely. Instrument flying is a totally separate issue from the way one learns to fly an airplane during initial training. They are integrated in certain ways. In other ways the two are entirely separate. We are discussing here the initial process of learning to fly, NOT flying in instrument conditions. VFR is one thing IFR is quite another. When an instructor discusses "flying by feel", they are in no way advocating the non-use of instruments and warning sensors available to the pilot in the aircraft. They are simply reducing the available "tools" the pilot relies on to a lower level to help the pilot understand his/her flight evironment more closely without the aid of artificial help. In the IFR scenario, an instructor will do the same thing when they reduce a pilot to flying on the primary panel only. Don't think of flying VFR and IFR in the same breath. This attitude can get a pilot into deep trouble down the line. When you start talking instruments, you're in a whole new ball game when it comes to cues. Everything changes. There are no more visual cues. There is no more "feeling" of the airplane. There are ONLY the instruments. It's a whole different flying world. You learn to fly by "feel" to better understand the aerodynamics and how the airplane interfaces in it's environment. Visual cues are part of this equation. Once these things are learned, you TRANSITION into a whole new world where instruments replace these cues. Don't EVER, as long as you fly, get these two worlds mixed up in your mind. Doing that will kill you in an airplane faster than you can imagine! -- Dudley Henriques -- Dudley Henriques |
#120
On Feb 17, 3:32 pm, "Blueskies" wrote:
wrote in ... On Feb 15, 4:36 pm, "Blueskies" wrote: If you always land full flap the likelyhood of a tail strike in a full stall landing is nil.... Dan D. Wrong. It's regularly done in 172s during soft-field landings. As a mechanic as well as a pilot, I get to replace the bent and broken tail tiedown rings that got banged on the runway. A little power, as used in the soft-field technique, with full flaps, yet, allows the airplane to achieve a higher deck angle in the touchdown and if the piloet uses a little too much power, he'll get the nose really high so that when the thing settles on the runway, the tail strikes first. It can get expensive. The tiedown ring ($40) gets busted, but if the strike was hard enough the whole tail section can sustain damage. We look hard at the entire tailcone, rudder hinges (because the big chunk of lead up top slugs downward on those little hinge brackets and cracks them), the stabilizer spars (more big chunks of lead on the elevator tips that want to keep going down, too, and can bent the spars), and so on. Dan Like I said, the likelihood is nil. I didn't say it couldn't be done... Is this with the 'new' 30° flap limited machines or the older standard 40° flap machines? dČ 40° flaps. With 30° it would be worse. Dan |
A dumb doubt on stalls | [email protected] | Piloting | 120 | June 30th 06 11:12 PM |
why my plane stalls | Grandss | Piloting | 22 | August 14th 05 07:48 AM |
Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 05:23 PM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 05:07 PM |
