#121
Angelo Campanella wrote:
By that I mean for laminar flow wings without stall strips, the stall occurs at a low speed is not reversable; it really requires an increase of speed to start flying again. Not trying to be confrontational here, but I would rethink the way you phrase this issue. First of all, the stall can occur at ANY speed, and it absolutely reversible, and it's reversible by decreasing the angle of attack below stall. THIS is what "starts" the wing flying again...not an increase in speed...although an increase in speed is coincident with the stall recovery. For example, the P51 I flew had a laminar wing without stall strips and I can assure you that just like any other airplane, the stall characteristics of the wing were normal in every way. -- Dudley Henriques |
#122
On Fri, 15 Feb 2008 02:44:25 -0800 (PST), D Ramapriya
wrote: On Feb 14, 5:57 am, "Blueskies" wrote: Every flight in a light GA single should end in a full stall...right as the wheels roll on to the runway... Interesting... is the nosewheel strut generally designed to bear the impact of a full-stalled landing? Why would it need to? The nose shouldn't drop unless the pilot screws up. Ramapriya Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#123
Ol Shy & Bashful wrote:
Why is it so many pilots are afraid of stalls? I see it over an over when doing flight reviews and checks. Why are pilots so afraid of flying in the low end of the speed envelope? Isn't that where the nasty things can happen? Isn't that where a pilot should be comfortable and competent? What do you think? I think that to consider stalls within the confines of the low-speed end of the envelope is naive at best and dangerous at worst. With 24,000+ hours you obviously know that, but after skimming through the many (many) replies to this thread I see scant little, if any, acknowledgement that the stall occurs at a given angle of attack (AoA), not a SPEED! You can safely (as in not over-stress the airframe) use full control deflection from the bottom of the green arc (usually Vs) to Vmo. At Vmo, full elevator deflection will result in the airframe's maximum certified G load, right before the stall. IOW, max-G and stall occur simultaneously. Below Vmo, the wing will stall before max-G. At 1G, the wing stalls at Vs. Here's something to really fry your noodle: at zero-G, the wing wont stall (think about it). My point is, stalls are an aerodynamic phenomena that is tied to the AoA, not the ASI. I have a CFI, ATPL, aerobatics endorsements, etc, and several thousand hours too...but all this is basic aeronautical knowledge that is taught at ab-initio stage. Stalls shouldn't be feared, just understood, then practised until they are as familiar as any other phase of flight - right across the speed envelope. BTW, you haven't lived until you've done accelerated stalls that transition into accelerated spins! Hoo-har!! ![]() James -- Write yourself a threatening letter and pen a defiant reply. |
#124
![]() "Centurion" wrote in message ... BTW, you haven't lived until you've done accelerated stalls that transition into accelerated spins! Hoo-har!! ![]() James -- Write yourself a threatening letter and pen a defiant reply. About 1978, in a C-150 @ ~2500 agl under a cloud bank, student practicing steep turns, and I notice he is trying to hold the nose up using top rudder, with the ball off to the left. I also notice the speed decaying, but I figure I'll let him get a little deeper in to it. The buzzer chipped and over we go into a right snap roll and down into a spin. Piece of cake, except this guy is bigger than I am and he froze up on the controls, yoke back and spinning. I finally busted it loose from him and effected a recovery, and when I checked the altimeter we were at about 800'. I decided that I would not let students get that far out of shape anymore... |
#125
Centurion wrote:
Ol Shy & Bashful wrote: Why is it so many pilots are afraid of stalls? I see it over an over when doing flight reviews and checks. Why are pilots so afraid of flying in the low end of the speed envelope? Isn't that where the nasty things can happen? Isn't that where a pilot should be comfortable and competent? What do you think? I think that to consider stalls within the confines of the low-speed end of the envelope is naive at best and dangerous at worst. With 24,000+ hours you obviously know that, but after skimming through the many (many) replies to this thread I see scant little, if any, acknowledgement that the stall occurs at a given angle of attack (AoA), not a SPEED! You can safely (as in not over-stress the airframe) use full control deflection from the bottom of the green arc (usually Vs) to Vmo. At Vmo, full elevator deflection will result in the airframe's maximum certified G load, right before the stall. IOW, max-G and stall occur simultaneously. Below Vmo, the wing will stall before max-G. At 1G, the wing stalls at Vs. Here's something to really fry your noodle: at zero-G, the wing wont stall (think about it). My point is, stalls are an aerodynamic phenomena that is tied to the AoA, not the ASI. I have a CFI, ATPL, aerobatics endorsements, etc, and several thousand hours too...but all this is basic aeronautical knowledge that is taught at ab-initio stage. Stalls shouldn't be feared, just understood, then practised until they are as familiar as any other phase of flight - right across the speed envelope. BTW, you haven't lived until you've done accelerated stalls that transition into accelerated spins! Hoo-har!! ![]() James Correct me if I'm mistaken as it's been a long long time since I've been in a Cessna 182, ( and I'm just using a 182 as an example here out of the inventory of everything that flies since the Vmo for the Skylane pops into my rather feeble brain :-)) but if I remember right, the Vmo on the Skylane was 160 KIAS. The Va or maneuvering speed on the Skylane at GW was 111. It's just a suggestion mind you, but I wouldn't be in all that much in a hurry to apply full back elevator on the airplane at 160knots or Vmo unless I wanted to crack the world record for a Cessna 182 making it sans a few misc parts from where ever it was in the sky when I did this to impact on the ground :-)) -- Dudley Henriques |
#127
#128
Angelo Campanella wrote in
: By that I mean for laminar flow wings without stall strips, the stall occurs at a low speed is not reversable; it really requires an increase of speed to start flying again. With stall strips, loss of lift occurs at a slightly higher speed where just dropping the nose to reduce the angle of attack will resume flying status. I suspect that of one could fly the same plane with and without stall strips, the bare wing would be flying all the time at the speed where the plane with stall strips would experience the mushing... I really can't say which plane would do which... I'm just reierating some basic aerodynamics. No. this just isn't so. Laminar airfoils are just like any other except they tend to break a little more briskly. Bertie |
#129
Dudley Henriques wrote:
Centurion wrote: Ol Shy & Bashful wrote: Why is it so many pilots are afraid of stalls? I see it over an over when doing flight reviews and checks. Why are pilots so afraid of flying in the low end of the speed envelope? Isn't that where the nasty things can happen? Isn't that where a pilot should be comfortable and competent? What do you think? I think that to consider stalls within the confines of the low-speed end of the envelope is naive at best and dangerous at worst. With 24,000+ hours you obviously know that, but after skimming through the many (many) replies to this thread I see scant little, if any, acknowledgement that the stall occurs at a given angle of attack (AoA), not a SPEED! You can safely (as in not over-stress the airframe) use full control deflection from the bottom of the green arc (usually Vs) to Vmo. At Vmo, full elevator deflection will result in the airframe's maximum certified G load, right before the stall. IOW, max-G and stall occur simultaneously. Below Vmo, the wing will stall before max-G. At 1G, the wing stalls at Vs. Here's something to really fry your noodle: at zero-G, the wing wont stall (think about it). My point is, stalls are an aerodynamic phenomena that is tied to the AoA, not the ASI. I have a CFI, ATPL, aerobatics endorsements, etc, and several thousand hours too...but all this is basic aeronautical knowledge that is taught at ab-initio stage. Stalls shouldn't be feared, just understood, then practised until they are as familiar as any other phase of flight - right across the speed envelope. BTW, you haven't lived until you've done accelerated stalls that transition into accelerated spins! Hoo-har!! ![]() James Correct me if I'm mistaken as it's been a long long time since I've been in a Cessna 182, ( and I'm just using a 182 as an example here out of the inventory of everything that flies since the Vmo for the Skylane pops into my rather feeble brain :-)) but if I remember right, the Vmo on the Skylane was 160 KIAS. The Va or maneuvering speed on the Skylane at GW was 111. Ooops. You're 100% correct - I mean't Va NOT Vmo! Serves me right for not proof-reading my post :P It's just a suggestion mind you, but I wouldn't be in all that much in a hurry to apply full back elevator on the airplane at 160knots or Vmo unless I wanted to crack the world record for a Cessna 182 making it sans a few misc parts from where ever it was in the sky when I did this to impact on the ground :-)) Indeed. That's a quite possible outcome. IIRC ultimate load for normal category aircraft is 150% rated G (as in 1.5 times). The following thread will be of interest to those interested in the high-speed end of the flight envelope and how that is determined based on component failure probabilities: http://tinyurl.com/yrqz4f (links to http://www.eng-tips.com/) Thanks for highlighting my misinformation ![]() James -- Are you making all this up as you go along? |
#130
Blueskies wrote:
"Centurion" wrote in message ... BTW, you haven't lived until you've done accelerated stalls that transition into accelerated spins! Hoo-har!! ![]() James About 1978, in a C-150 @ ~2500 agl under a cloud bank, student practicing steep turns, and I notice he is trying to hold the nose up using top rudder, with the ball off to the left. I also notice the speed decaying, but I figure I'll let him get a little deeper in to it. The buzzer chipped and over we go into a right snap roll and down into a spin. Piece of cake, except this guy is bigger than I am and he froze up on the controls, yoke back and spinning. I finally busted it loose from him and effected a recovery, and when I checked the altimeter we were at about 800'. I decided that I would not let students get that far out of shape anymore... Yep - similar story for me, only student was climbing and trimming for "constant back-pressure" instead of trimming out the control force. I'd corrected him on a few flights, so thought I'd let it go and let him see what happens. End up with the nose about 55-60deg pitch up, full power and over it went. Student lets go of the controls and grabs me! So there we are going round and round, down, down, down with full power. Shook him off and recovered, but decided that accelerated spin training is probably best left for later phases :P You live and learn. If you do neither, you're dead. James -- You will triumph over your enemy. |
A dumb doubt on stalls | [email protected] | Piloting | 120 | June 30th 06 11:12 PM |
why my plane stalls | Grandss | Piloting | 22 | August 14th 05 07:48 AM |
Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 05:23 PM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 05:07 PM |
