Compass
Old February 17th 08, 10:48 PM posted to rec.aviation.soaring
Default Compass
Does an experimental ASW20B require a compass to be legal. The
minimum equipment list in the amnual does not specify a compass?
Old February 18th 08, 04:48 PM posted to rec.aviation.soaring
Todd
Default Compass
As best I can tell, the answer appears to be no. My ASW20 has one but
I don't think I have ever looked at it.
A review of the FAR's turns up the following "compass" or "direction
indicator" citations:
91.205 Powered civil aircraft with standard category U.S.
airworthiness certificates: Instrument and equipment requirements.
(a) General. Except as provided in paragraphs (c)(3) and (e) of this
section, no person may operate a powered civil aircraft with a
standard category U.S. airworthiness certificate in any operation
described in paragraphs (b) through (f) of this section unless that
aircraft contains the instruments and equipment specified in those
paragraphs (or FAA-approved equivalents) for that type of operation,
and those instruments and items of equipment are in operable
condition.
(b) Visual-flight rules (day). For VFR flight during the day, the
following instruments and equipment are required:
(1) Airspeed indicator.
(2) Altimeter.
(3) Magnetic direction indicator.
But this section applies to POWERED AIRCRAFT
---OR---
PART 23--AIRWORTHINESS STANDARDS: NORMAL, UTILITY, ACROBATIC, AND
COMMUTER CATEGORY AIRPLANES
Subpart F--Equipment
§ 23.1303 Flight and navigation instruments.
The following are the minimum required flight and navigation
instruments:
(a) An airspeed indicator.
(b) An altimeter.
(c) A direction indicator (nonstabilized magnetic compass).
But this will not apply you are not an AIRPLANE
So unless someone can come up with a reference to gliders or aircraft,
my vote is that the "direction indicator" is not required, unless
otherwise required by the manufacturer certification.
The FAR's are searchable online he
http://ecfr.gpoaccess.gov/cgi/t/text...4/14tab_02.tpl
Old February 18th 08, 05:25 PM posted to rec.aviation.soaring
Greg Arnold
Default Compass
In Bob Carlton's Convention talk about ramp checks, he said that gliders
are not required to have a compass. However, sometimes the
airworthiness document requires one. See, for example, the type
certificate data sheet for the ASW-27 at http://tinyurl.com/2qpqhr.
condition.
(2) Altimeter.
---OR---
instruments:
(b) An altimeter.
Old February 18th 08, 05:30 PM posted to rec.aviation.soaring
thermalrider
Default Compass
On Feb 17, 5:48*pm, wrote:
Does an experimental ASW20B require a compass to be legal. *The
What does the POH say is the required minimum equipment?
What does the Type Certificate say?
Old February 18th 08, 06:55 PM posted to rec.aviation.soaring
Andy[_1_]
Default Compass
On Feb 18, 11:33*am, Bullwinkle wrote:
Why would someone not want a compass?
Because, except in the case of total GPS failure, or the rare case
that a glider is given an ATC heading vector, they are a waste of
panel space?
Andy
Old February 18th 08, 07:03 PM posted to rec.aviation.soaring
Andy[_1_]
Default Compass
On Feb 18, 10:25*am, Greg Arnold wrote:
*However, sometimes the
airworthiness document requires one. *See, for example, the type
certificate data sheet for the ASW-27 athttp://tinyurl.com/2qpqhr.
Interestingly the ASW-28 TCDS issued later does not list a compass in
the equipment list.
For an experimental glider, even if here is a standard type
certificate and associated TCDS, I don't think the TCDS applies.
Minimum equipment may be listed in the experimental certification docs
(operational limitations) but that may depend the date of the
airworthiness inspection and the region in which it was conducted.
Recent experimental glider cert docs seem to be more standardized than
they were when the ASW-20 was new.
Andy
Old February 18th 08, 08:11 PM posted to rec.aviation.soaring
John Smith
Default Compass
Bill Daniels wrote:
Because, at least in my case, heading is less interesting than ground track
displayed by a GPS. I carry a handheld GPS as a backup. I have no compass.
In my case, I do not carry a handheld backup GPS. I was happy to have a
working compass available twice so far.
WTB: PZL KI-13 Compass Romeo Delta Soaring 1 October 30th 17 07:47 AM
Compass for SZD-55 Steve Freeman Soaring 3 July 24th 07 02:13 AM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 07:39 AM
Looking for a PZL compass Kirk Stant Soaring 8 February 12th 04 09:27 PM
mag-compass for a B55 JerryK Owning 3 July 11th 03 06:18 AM
