#21
On Feb 15, 3:53 pm, Doug Vetter wrote:
On Fri, 15 Feb 2008 10:02:19 -0800, Robert M. Gary wrote: We also have an AD requiring mandatory overhaul of blades that are 30 years old (just came out this month). News to me and I've been following this fairly closely since our prop was affected by the hub AD issued last year. Care to provide the AD number or a link to it? I looked on Hartzell's site and didn't find any such AD. -Doughttp://www.dvatp.com/ If you are in the FAA's DB of having a plane in which a Hartzell prop is applicable you should have gotten this in the mail... Blades before D47534 are affected. Expect this to grow in the future. AD 2007-26-09 Unsafe Condition (e) This AD results from operators requesting clarification of certain portions of AD 2002-09-08. We are issuing this AD to prevent failure of the propeller blade from fatigue cracks in the aluminum blade shank radius, which can result in damage to the airplane and loss of airplane control. -Robert |
On Fri, 15 Feb 2008 20:52:19 -0800, Robert M. Gary wrote:
If you are in the FAA's DB of having a plane in which a Hartzell prop is applicable you should have gotten this in the mail... Blades before D47534 are affected. Expect this to grow in the future. The little problem with the FAA's db is that it doesn't apparently take into account airplanes upgraded with STCs like our 172 with the Avcon 180HP conversion. We haven't received any such notice. I reviewed the AD you mention and it turns out that it is more or less a revision and reissuance of AD 77-12-06(R2). Neither AD applies to blades D47534 and above (production from 1977 on) because that's when they figured out there was a problem and issued the original AD. Both ADs require cold-rolling the blade shanks to prevent fractures and I believe most if not all blades in service today have already been "hit" by this AD. Our blades are older than the specified serial number but the shanks were cold-rolled at overhaul in 1980. If I've read the AD correctly, that means we're in compliance. My prop shop told me Hartzell has indeed been "AD happy" the past few years, but before people start freaking out at this it's important to note that this AD does not require older blades to be retired by default. It only requires them to undergo the cold rolling procedure and thus be overhauled. In the unlikely case your blade serial numbers are below D47534 AND they have been overhauled so many times that they will not survive another overhaul AND the shanks were not cold rolled at one of the prior overhauls, then you'll need to buy new blades. Otherwise, you just need to have them overhauled one more time to accomplish the cold rolling procedure. -Doug http://www.dvatp.com/ |
On 16 Feb 2008 13:30:16 GMT, Doug Vetter wrote:
AND the shanks were not cold rolled at one of the prior overhauls Which would be pretty unlikely if they were overhauled at a reputable shop sometime since the original AD was issued. I've never had an engine/prop/accessory overhaul that did not include compliance with all AD's existing at the time. --ron |
Well, ya just never know what little surprise you will find...
My Hartzell props are non-AD replacements to get the annual prop AD off my back... Blades never nicked, never filed, etc.. Have under a thousand hours on them... We weren't even looking at them as needing service... But, I wanted to change out the front seal on the right crank as it has a slight drip that keeps me busy cleaning things off... So, the little surprises began to happen... When we pulled the right prop to do change the seal we found the studs had been over tightened. Two nuts were slightly rounded off in breaking them loose... Oh well, stuff happens and The Kid added new nuts to the parts list... So, the seal is replaced, we hung the new cylinders finally, and The Kid went to put the prop back on the next day... I get this call at the office... "you ain't gonna believe this."?", my wallet started to itch immediately... "Believe what?" "The flywheel is cracked." "Steve, in 50 years of owning airplanes and longer than that messing with engines I have never seen a cracked flywheel on an airplane engine." "Neither have I, but it is cracked. I had just hung it on the crank and lifted the prop up and as I was lining up the bolt holes the light hit it just right and I saw the crack" "Ah jeez... OK, leave it till I get there this afternoon." So, I get there and sure enough, with the light "just right" you can see the crack $$ So, I stare at the other prop and say, do you know what I'm thinking... He says, yup, and we push the tool box around to the left engine... Well, now I'm here to tell you the gorilla that mounted the left prop must have used a 4 foot wrench to tighten the studs... It took the better part of an hour of finesse and finally resorting to a big drift and an even bigger hammer to get two of those nuts broke loose... But the good part of that is after dye penetrant the flywheel is not cracked... So now we have a new set of studs and nuts for both engines on the parts list, and a flywheel - hoping to find a used one for half the new price... Keeping old airplanes flying is a full time job... denny |
On Mon, 18 Feb 2008 03:35:40 -0800 (PST), Denny
wrote: Keeping old airplanes flying is a full time job... Oh yeah, especially when we try to do it with old parts. Went years trying to get my airplane to have its annuals in the winter -- bringing it in the end of the month due, so it could be signed off the following month. Finally worked my way around to January. Annual -- "you've got a cracked case". After investigating options, I decided for a Lycoming factory overhaul. Engine availability there (and elsewhere) was nil for a while. I wasn't flying again until May sigh. This year I finally got back to a January annual. --ron |
Ah, crap. This kind of stuff scares me. Sorry to hear it, Denny. I'm hoping (IF my tires actually come in -- Desser must use the Pony Express to ship) to wrap up our annual today. Other than fishing the fuel gauge float out of the right main fuel tank (which required removing and reinstalling the tank, twice. Don't ask.) and reattaching it to the sending unit, replacing a brake rotor and tires, and the usual myriad of brittle plastic repairs, this one looks like it'll be a good one. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
"The flywheel is cracked." Ah, crap. This kind of stuff scares me. Sorry to hear it, Denny. I'm hoping (IF my tires actually come in -- Desser must use the Pony Express to ship) to wrap up our annual today. Other than fishing the fuel gauge float out of the right main fuel tank (which required removing and reinstalling the tank, twice. Don't ask.) and reattaching it to the sending unit, replacing a brake rotor and tires, and the usual myriad of brittle plastic repairs, this one looks like it'll be a good one. I am assisting a friend of mine with the annual on his -235. It is becoming more of a restoration project than an annual. We removed the right wing tank thinking that it would give us easier access to the landing gear bolts on the wing. It didn't. But I do believe Piper could have used a few more inspection covers thoughout the plane to make life easier for maintainence. We had to replace the two little brackets that hold the landing gear fairing on. They were broke on both wings. Now, Piper uses two of the landing gear bolts to also hold on these little brackets. What were they thinking? -- Regards, Ross C-172F 180HP KSWI |
#28
Denny writes:
So, the little surprises began to happen... When we pulled the right prop to do change the seal we found the studs had been over tightened. Two nuts were slightly rounded off in breaking them loose... Oh well, stuff happens and The Kid added new nuts to the parts list... So, the seal is replaced, we hung the new cylinders finally, and The Kid went to put the prop back on the next day... I get this call at the office... One wonders what the Last Guy used for a torque wrench... Chicago Pneumatic, maybe? -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
#29
thoughout the plane to make life easier for maintainence. I feel your pain -- but having just removed and reinstalled all 8 gazillion screws that hold on the 3 gazillion inspection covers (and wheel pants, and fairings, and gas tanks) -- I do NOT want any damned more inspection covers! ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#30
![]() "Jay Honeck" wrote in message news:y7suj.39938$9j6.24450@attbi_s22... But I do believe Piper could have used a few more inspection covers thoughout the plane to make life easier for maintainence. I feel your pain -- but having just removed and reinstalled all 8 gazillion screws that hold on the 3 gazillion inspection covers (and wheel pants, and fairings, and gas tanks) -- I do NOT want any damned more inspection covers! No, they need to start putting the inspection covers on with Velcro! g -- Jim in NC |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
IFR GPS replace DME / ADF? | [email protected] | Instrument Flight Rules | 21 | May 15th 06 03:13 PM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Military Aviation | 265 | March 7th 04 09:28 AM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Naval Aviation | 2 | February 22nd 04 06:22 AM |
Replace (Fix) ADF? | Tom Nery | Owning | 32 | November 3rd 03 03:30 PM |
