Awesome sportplane
Old February 17th 08, 08:21 PM posted to rec.aviation.piloting
WingFlaps
Default Awesome sportplane
On Feb 18, 6:31*am, Phil J wrote:
On Feb 16, 7:44*pm, "Mike Isaksen" wrote:
"WingFlaps" *wrote in message ...
I recently had a chance to try a Dynaero *MCR01. (snip...)
I'd like to see what the 4 seat version can do too.
What country are you flying in?
Also, nice numbers, but are wings filled with helium?
Min speed: * * *47 kt
Cruise speed: *159 kt
Vne: * * * * * * 173 kt
Climb ratio: 1750 ft/min
Max. takeoff weight: *1080 lbs
Empty weight: * * * * *573 lbs
Engine: ROTAX 912, 912 S or 914, Jabiru
Besides the _very_ light weight and very slippery design, the airplane
uses a variable-pitch prop and double-slotted flaps to achieve those
numbers. *That is one sexy little airplane.
Yes, it makes a mockery of the US sport plane limitations.
Cheers
Old February 17th 08, 08:52 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
WingFlaps wrote in news:89ce5c71-3a34-4764-a433-
On Feb 17, 12:51*pm, Bertie the Bunyip wrote:
WingFlaps wrote in news:d4dde7ab-0042-46fd-85fb-
I recently had a chance to try a Dynaero *MCR01. It looked tiny but I
was able to fit in (I'm over 6' 2") *OK. It climbed out at 1500'/min
and had an airspeed ~140k in level flight. It felt so strange compared
to the C's I've flown. The stiffness of the wings/air frame was very
apparent as was the light weight (it's all CF). The stick forces were
light and I had only to think about a turn and it
would do it. It seemed very neutral in roll (up to 40 degrees) with
almost no rudder needed. Over 40 a slight overbank tendency appeared
but that may have been related to my coordination being a bit off. A
hard climb near Vx needed a lot of rudder compared to level flight. If
you get the chance I'd urge you to check it out -I'm amazed at what
100HP can achieve in a modern airframe!
That's Michael Columban's airplane, isn't it? Yes, the figures are
unbeleivable, but he does do the unbeleivable!
I saw a cri-cri on the ground and doing some aerobatics last year. It
was really hard to believe it could fly at all, let alone so well!
Mind, you I would not have been able to get in it (and even if I could
I don't know that I would want to).
I'd love to fly one. A set of drawings just changed hands on ebay last week
for 1600 bucks!
Bertie
Old February 17th 08, 10:07 PM posted to rec.aviation.piloting
WingFlaps
for 1600 bucks!
I don't think you should start drooling over a new plane 'til you
finish the old one. Mrs. Bunyip won't tolerate it. But if you want to
fly one come visit me.
Cheers
Old February 17th 08, 10:58 PM posted to rec.aviation.piloting
William Hung[_2_]
for 1600 bucks!
Cheers- Hide quoted text -
- Show quoted text -
Shweeeeeeet! Where are you WingFlaps? Is the plane yours, or is it
one that you have access to?
Wil
Old February 18th 08, 12:30 AM posted to rec.aviation.piloting
WingFlaps
but that may have been related to my coordination being a bit off.. A
for 1600 bucks!
Shweeeeeeet! *Where are you WingFlaps? *Is the plane yours, or is it
I have access to it. You will need to contact me off group for other
details.
Cheers
Old February 18th 08, 02:23 AM posted to rec.aviation.piloting
WingFlaps wrote in
WingFlaps wrote in
WingFlaps wrote in
but
I
1500'/mi
n
compare
d
very apparent as was the light weight (it's all CF). The stick
forces were
with almost no rudder needed. Over 40 a slight overbank tendency
appeared but that may have been related to my coordination being
a bit off. A hard climb near Vx needed a lot of rudder compared
to level flight. I
f
what 100HP can achieve in a modern airframe!
It was really hard to believe it could fly at all, let alone so
well! Mind, you I would not have been able to get in it (and even
if I could I don't know that I would want to).
last wee
k
for 1600 bucks!
You have a Cri Cri? I'm there.
Bertie
Old February 18th 08, 02:46 AM posted to rec.aviation.piloting
WingFlaps
On Feb 18, 3:23*pm, Bertie the Bunyip wrote:
WingFlaps wrote in
WingFlaps wrote in
but
*I
1500'/mi
n
compare
d
forces were
to level flight. I
f
last wee
k
for 1600 bucks!
No, I don't have one. I know where one is tho. Single seat plane,
Doubt the owner would let you loose but you never know.
Cheers
Old February 18th 08, 02:52 AM posted to rec.aviation.piloting
WingFlaps wrote in
WingFlaps wrote
innews:47265d36-7bc4-4657-b552-7e2e5
WingFlaps wrote in
WingFlaps wrote in
tiny but
*I
1500'/mi
n
compare
d
was very apparent as was the light weight (it's all CF). The
stick forces were
degrees) with almost no rudder needed. Over 40 a slight
overbank tendency appeared but that may have been related to
my coordination being a bit off. A hard climb near Vx needed
f
at what 100HP can achieve in a modern airframe!
are unbeleivable, but he does do the unbeleivable!
year. It was really hard to believe it could fly at all, let
alone so well! Mind, you I would not have been able to get in it
(and even if I could I don't know that I would want to).
last wee
k
for 1600 bucks!
to fly one come visit me.
Well, I wouldn't if it were mine!
Nifty machine.. Someone put a pair of model airplane jets on one..///
Bertie
Old February 18th 08, 02:36 PM posted to rec.aviation.piloting
Gig 601XL Builder[_2_]
numbers. That is one sexy little airplane.
Cheers
Not a mockery it just doesn't qualify under the LSA rules.
Old February 18th 08, 08:30 PM posted to rec.aviation.piloting
WingFlaps
On Feb 19, 3:36*am, Gig 601XL Builder
Then may I suggest those rules are too restrictive? Why have an upper
speed limit when you are already limited on power? The power, Vso and
MAUW alone should be enough. IMHO if better design can give both the
desired low stall speed and high speed perf. it should be encouraged,
not prevented by restrictive legislation. I can't help wonder if one
purpose of that legislation is to protect established, but inferior,
designs.
Cheers
Wanted: RTF or builder-assist Rotax sportplane Office 2004 Test Drive User Home Built 6 August 1st 07 11:43 PM
MONI motorglider / sportplane for sale Bill Berle Home Built 10 August 2nd 03 12:05 AM
MONI motorglider / sportplane for sale Bill Berle Aviation Marketplace 7 August 2nd 03 12:05 AM
MONI motorglider / sportplane for sale Bill Berle Soaring 7 August 2nd 03 12:05 AM
Monnett MONI motorglider/sportplane for sale Bill Berle Home Built 0 July 26th 03 10:59 PM
