#41
On Feb 21, 12:10*am, Charles Vincent wrote:
Peter Dohm wrote: "Morgans" wrote in message ... "Peter Dohm" wrote I think that you may mean heater cores, which would have a larger water passage, but I am hoping for a look if I go to SnF this year. No, I'm pretty sure they were AC condensors. The layout that you mention is very similar to one that I have seen used successfully on a Subaru conversion in a KR2--although I don't know who may have done it first. Tricky seems to be an understatement, especially when using airports that demand an estended ground run! I have never understood why a person would not include an electric fan to pull air through the radiator, when necessary ground runs do not provide enough air flow. That would be 5 pounds well spent, I would think. *I will include one if my installation ever takes place, unless someone could come up with a reason not to include it. -- Jim in NC I have wondered about the exact same thing, and am leaning toward the same solution. Peter I would guess because the fan is a liability to flow at speeds over thirty or forty mph and because a twelve inch 1/8 hp fan has little to offer over a 54 inch 40hp fan. Charles- Hide quoted text - - Show quoted text - That would be my guess, and next I would wonder why people don't install louvers controlled from inside the cabin to let the heat just rise out of the engine compartment. I think some military planes of WWII era had them. Wil |
#42
![]() "Charles Vincent" wrote I would guess because the fan is a liability to flow at speeds over thirty or forty mph and because a twelve inch 1/8 hp fan has little to offer over a 54 inch 40hp fan. But that big fan is trying to blow air into a couple 3 inch round holes, and then diffuse that speed of airflow to many times the square inches of radiator. What you end up with is no airflow past the radiator, and overheating. Instead, you put a fan right next to the radiator pulling air directly past the radiator at a decent speed, with no diffusion losses. It works. That's why cars have them. That's why water cooled airplanes overheat if they tai for more than a few minutes. -- Jim in NC |
#43
On Feb 20, 5:10*pm, "Morgans" wrote:
"stol" wrote There is a reason we call these Experimental homebuilt planes... According to the FAA we build them for the "educational and recreational aspect. Hell, *a trained monkey can assemble *any one of the new quick build kits on the market, all it has to do is cleco, rivet and fly.... Jim: - - - Well, at least a dedicated trained monkey, anyway! Ben ( an auto engine junkie) Haaswww.haaspowerair.com N801BH, PS, I just got a video camera and shot some footage this mornin of my beast. If I can figure out how to load it to YouTube or something similar you can view an auto engine powered homebuilt boring holes through -6 f skies here in Jackson Hole.... Jim: - - - Right oN! ! Jim: - - - Do something else, for us auto engine junkie admirers. *Some time when you have the cowl off, give a close up video tour of the installation, and narrate about some of the pitfalls you have had to avoid, what has worked out well, and what you want to improve on. *That kind of thing, you know. *I'm sure you could get creative and make up your own program, but I can never get enough of poking around a good fire wall forward auto engine installation, up close and personal! -- Jim in NC I have a conditional inspection coming up next month so a video walkaround and comments on do's and don't is a great idea. What we learn will benefit the future auto engine powered experimentals and I want to help out where I can. Now if I can get Steven. P McNicolls to narrate it, Bertie to do the comedy act and barnyard BOb to direct it it should get me an Oscar. !! { : - )).... Ben www.haaspowerair.com Lifetime EAA member. |
#44
![]() "Morgans" wrote in message ... Out of all of the styles of PSRU's out there, I tend to like the design of the toothed belt setups. It just looks right, I think, and seems to solve a lot of tricky problems, (like harmonic and torsional vibration) in a simple way. -- How do "toothed belt setups" solve harmonic and torsional vibrations problems in a simple way? |
#45
![]() "Charlie" wrote Actually, they are GM *evaporator* cores, the heat exchanger that's mounted in the dash to cool the air. Yep, I knew that about 2 minutes after sending the post. Condensor would be the little radiator out next to the car radiator. Oh well, at least someone knew what I meant! g I've seen his installation on average about once a year for the last 10 years, & watched it evolve over the years from carbs to injection & from the original 13B to the Renesis engine core. I think that if you ask him, he'd tell you that they were 1. available, 2. affordable, 3. fit in the stock cowl, 4. actually turn out to be fairly close to the right thickness for a relatively high speed homebuilt like an RV-x. All true, but he plain likes rotary engines, too. Maybe goes past like a littke bit, even! His work is sublime pragmatism. A marketing exec would go into cardiac arrest just looking at it, but everything is carefully engineered to be good enough with nothing extra. Yep. Kinda' like the JB Weld around the fitting for the cooling fluid into the _evaporator_ cores. I definitely has a sound to it, screaming by on a low pass, though! -- Jim in NC |
#46
![]() "stol" wrote I have a conditional inspection coming up next month so a video walkaround and comments on do's and don't is a great idea. What we learn will benefit the future auto engine powered experimentals and I want to help out where I can. Now if I can get Steven. P McNicolls to narrate it, Bertie to do the comedy act and barnyard BOb to direct it it should get me an Oscar. !! { : - )).... Throw in Ken Tucker to tell you how to fly it, and if you can get all of that in one place and on film, you should go broker a peace deal in the Middle East. essaesseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeff |
#47
![]() "Morgans" wrote essaesseeeeee (big snip) eeeeeeeeeeeeeeeeeff What the hell was that????????????? Sorrry gang. I have no idea why that happened. -- Jim in NC |
Seattle to So Cal Area | 81mm | General Aviation | 2 | April 14th 06 04:45 AM |
Seattle to So Cal Area | Montblack | Piloting | 0 | April 12th 06 04:45 PM |
Seattle to So Cal Area | 81mm | Owning | 1 | April 12th 06 04:45 PM |
Seattle to So Cal Area | 81mm | Aviation Marketplace | 0 | April 12th 06 02:41 PM |
Seattle to So Cal Area | 81mm | Restoration | 0 | April 12th 06 02:40 PM |
