#41
John Smith wrote:
The float detached from the sender in the right main tank on the PA32-300 I flew to Florida a year ago. The gauge was therefore inop. The aircraft is equipped with a FS-450 fuel flow monitor. I used this in place of the specific fuel gauge. The FS-450 is accurately calibrated to within 0.2 gallons, much better accurate than the manufacturer's fuel gauge. Was I legal? No. The FS-450 installation instructions, which are a part of the STC, specifically say "a placard stating 'Do Not Rely on Fuel Flow Instrument to Determine Fuel Levels in Tanks' must be mounted on the aircraft instrument panel near the FS-450." Of course, the float didn't fall off until right before someone important noticed it fell off, so until it fell off you were legal ;-). Does a tree that falls in a forest make a sound? |
#42
#43
#44
On Feb 21, 8:49*pm, Peter Clark
wrote: On Thu, 21 Feb 2008 17:38:38 -0800 (PST), wrote: On Feb 21, 8:29*pm, John Smith wrote: Was I legal? Offhand, I don't see why not. FAR 91.205b9 only requires a working fuel gauge for each tank. It doesn't prohibit an additional, non- working gauge. Since the FS-450 isn't TSO'd as a replacement for the facotry installed and required fuel guage, and carries a "Do not rely on fuel flow instruments to determine fuel levels in tanks. Refer to original fuel flow instrumentation for primary information." warning in the pilot's guide, I do not belive your answer is correct. Well, my answer was just "Offhand, I don't see why not". Now I do see why not. ![]() (The part about not prohibiting an additional, nonworking gauge is correct, I believe, provided that a working legal gauge is also present--which, from what you say, was not the case.) |
#45
#46
On Feb 21, 9:10*pm, Peter Clark
wrote: Not neccessarily. *You'd have to check the equipment list - if only 1 were required operational it would say 1, if both were required (I don't see why in the case of redundant fuel guages in the same tank but anyway) it would say 2. *Example, the KOEL for the Piper Malibu Mirage which has 2 alternators installed lists 1 as required operational for IFR and 2 are required if flight into known icing is anticipated (one will run things fine unless you need the heated windshield, lift transducer, etc). Yup, no disagreement. I just meant that an inop gauge (in addition to a legal, working one for the same tank) doesn't automatically violate 91.205b9. |
#47
On Feb 21, 8:36*pm, Ray Andraka wrote:
I didn't say that the gauge could be inoperative. * Sorry, I didn't mean to suggest that you yourself were promulgating the full-blown legend. All I said was that there was nothing in the FAR that says it must be calibrated to a certain tolerance. * Yup, that's certainly true. The only requirement for calibration is that it indicate empty when there is no usable fuel left in the tank. * But the tolerance for THAT isn't specified, either! Whether the fuel quantity is zero or nonzero, the only requirement is for an "indication" of that quantity. By common sense, the indication has to be CORRECT, within some reasonable (but unspecified) tolerance. There's nothing in the regs to suggest that the indication for an empty tank has a more stringent accuracy requirement than the indication for any other level has. If the gauges are operative, indicate empty when on an empty tank, and increase monotonically when fuel is added, I think the letter of the reg is met. I disagree. I don't see why you substitute an implicit monotonicity requirement for an implicit accuracy requirement. Surely it's fine to have a gauge that is highly accurate, but has regions of negligible nonmonotonicity; and surely it's not ok to have a gauge that's wildly inaccurate (say, reporting 50 gallons when there are really just 5) but monotonic without exception. |
#48
Mine bounce around so much they are useless. Only time I look at them is
when the plane is sitting in the hangar. Often times book learnin doesn't transulate to real life. wrote in message ... On Feb 21, 3:51 pm, Jay Maynard wrote: On 2008-02-21, wrote: But what matters isn't what you or I happened to be taught, but rather what makes sense. Having and using working fuel gauges makes a great deal of sense, for the reasons just given. I won't argue with that statement. I was simply taught that aircraft fuel gauges are chronically unreliable to the point that they should be ignored, and that they should never be considered "working". I think that's half-right, and the half that's right is very important: you should never trust fuel gauges when they say you've got MORE fuel than you calculate. But if the gauges say you've got very much LESS than you expect, you should be concerned. And you need to be checking the gauges frequently, so you can notice if that occurs. (And of course, you can only do that if the gauges are operable, as they're required to be.) |
#49
On Feb 21, 10:36 pm, "Dave Stadt" wrote:
Mine bounce around so much they are useless. Then your plane isn't airworthy. Often times book learnin doesn't transulate to real life. Perhaps not. But flying without basic required equipment often translates to real death. |
#50
PA32-300 I flew to Florida a year ago. The gauge was therefore inop. The aircraft is equipped with a FS-450 fuel flow monitor. I used this in place of the specific fuel gauge. The FS-450 is accurately calibrated to within 0.2 gallons, much better accurate than the manufacturer's fuel gauge. Was I legal? I also have the JPI FS-450 digital fuel flow gauge in our plane, which is a hundred times more accurate than the Piper fuel tank gauges. Even with this very powerful tool in our arsenal, we STILL rely on only the timer, and visual verification of fuel levels. Bottom line: If you rely on a fuel gauge (instead of physically looking in the tank) you are taking a risk. We did not feel that flying with an inoperative gauge that is "normally" horribly inaccurate was taking any kind of risk whatsoever. Mary and I would not have flown the plane if we had not considered doing so to be utterly, 100% safe. It appears that the regulation we may have violated (and I'm still not convinced that we did) had little connection to practical reality. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Post-Annual Flight | Jay Honeck[_2_] | Piloting | 114 | March 2nd 08 10:55 PM |
Post Annual Report | Jack Allison | Owning | 7 | July 7th 07 04:37 AM |
Annual Xmas Post - HawkSanta.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | December 21st 06 02:54 AM |
Annual Xmas Post - Flight Line Santa.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | December 21st 06 02:54 AM |
Annual Xmas Post - 001index.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | December 21st 06 02:54 AM |
