New (old) bird
Old February 21st 08, 11:14 PM posted to rec.aviation.owning
Matt Whiting
Default New (old) bird
Ray Andraka wrote:
Jay Honeck wrote:
See Jay, Size DOES matter. :-) Mary telling you any different
doesn't count!
P.S. It's not just the girth...the length (of the cabin) is also
something to envy. As is the second door (which passengers don't
have to climb up on the wing to get into) and the front baggage
compartment. Admit it Jay, you have Piper envy.
No, no, no, Ray. Only Cezzzna drivers have Piper envy!
About twice a year I would really, really like a Six. Oshkosh and Sun
N Fun, basically.
The other 98 flights, hauling that pig around would truly be wasted on
our little family.
Jay, probably 2/3rds of my flights are solo in the Six. Yeah, it is
pulling around a lot of airframe to do that, but still cheaper than
owning another airplane. Yup, I'm spoiled. Worth the 15% extra fuel
burn to me.
One could always fly slower to get the fuel burn closer to a 4-pax
airplane, but does anyone every really do this?
Matt
Old February 22nd 08, 04:17 AM posted to rec.aviation.owning
Jay Honeck[_2_]
I always *say* I can do this, with our 6-cylinder O-540, and technically I
can. Shoot, I can lean it all the way back to 8 gph, and fly at C-150
speeds.
Do I? Hell, no! I cruise at 140 knots, at 15 gph. The only time I
throttle back to 10 gph is when I'm flying with friends in their 172s or
Warriors as a flight of 2 or 3. The rest of the time, I like to go
faster -- even though it makes little sense to do so.
Human nature, I guess. Or, just plain dumb...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 23rd 08, 12:58 AM posted to rec.aviation.owning
Newps
Ouch.
Old February 23rd 08, 01:06 AM posted to rec.aviation.owning
Ray Andraka
Newps wrote:
Ouch.
Jay, I thought book cruise fuel burn for a 235 was about 12 GPH. Why
are you burning 15? Book for my Six is 14 GPH, and I would be getting
that if I wasn't fighting the front two cylinders running so lean with
WOT. Sounds to me like a move up to a Six wouldn't be as painful as you
made it out to be the other day. So are we going to see you show up at
OSH in a six this year then?
Old February 23rd 08, 01:09 AM posted to rec.aviation.owning
Steven Barnes
Sure. I'll pick him up on my way... :-D
"Ray Andraka" wrote in message
Newps wrote:
Ouch.
Old February 23rd 08, 04:26 AM posted to rec.aviation.owning
Newps
Ray Andraka wrote:
Newps wrote:
Ouch.
Running 15 gph for a 235 hp engine is a colossal waste of gas at cruise
speed. My 285 hp engine(IO-520) gets 75% at 14 gph.
Old February 23rd 08, 04:46 AM posted to rec.aviation.owning
Ray Andraka
Newps wrote:
Ray Andraka wrote:
Newps wrote:
Ouch.
you made it out to be the other day. So are we going to see you show
up at OSH in a six this year then?
Book burn for my 260 hp O-540 is 14 gph. Both mine and Jay's are
carbureted, so we end up with a wider spread between cylinders, which in
turn means we lean to the leanest cylinder and accept the fuel burns of
the others. I've currently got an issue I am trying to track down with
mine that is making the front two cylinders reach peak EGT some 270-300
degrees before the others, which in turn is making my fuel burn close to
19gph (no, it isn't an induction leak, we've pressurized the intake and
checked it, plus the problem is most noticible at WOT on cold days. If
it were an intake leak, it would be accentuated at lower throttle
settings rather than higher ones). Previously, I used to get EGT
spreads around 150 deg and was getting fuel burns pretty close to the
14gph book value. I don't know why Jay is burning 25% more than book,
and am curious if he knows why (or maybe it was a typo?).
  #28
Old February 23rd 08, 05:10 AM posted to rec.aviation.owning
Jay Honeck[_2_]
Previously, I used to get EGT spreads around 150 deg and was getting fuel
burns pretty close to the 14gph book value. I don't know why Jay is
burning 25% more than book, and am curious if he knows why (or maybe it
was a typo?).
We normally fly at 23 squared, and lean back in order to keep EGTs within
100 degrees of each other, and under 1600 degrees. We try to keep CHTs
under 350 degrees. We usually cruise between 3500 and 6500 feet. At 3500
feet our FS-450 will indicate 15 gph at these settings.
At 6500 feet it will be closer to 14 gph.
Way back when, we calibrated the FS-450 to read "fat", in order to err on
the side of high fuel burn. I'd bet it's off by close to 1 gph, so we're
probably flying closer to 14 and 13 gph.
Can we lean back further? Sure.
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #29
Old February 23rd 08, 01:36 PM posted to rec.aviation.owning
Matt Whiting
I can. Shoot, I can lean it all the way back to 8 gph, and fly at C-150
speeds.
Lean, grasshopper, lean!
Matt
  #30
Old February 23rd 08, 03:08 PM posted to rec.aviation.owning
Ray Andraka
John Smith wrote:
In article bVNvj.45975$yE1.32607@attbi_s21,
That seems counter productive.
The purposes of having a fuel flow gauge is to accurately
determine/present the fuel that is actually being consumed and exactly
how much fuel remains. If you do not know either, how can you trouble
shoot accurately?
The FS-450 on the Cherokee Six that I fly is calibrated to 0.2 gph. It
only required three cross country flights to get it set properly.
The calibration can in handy when the right main fuel flot abandoned the
rod to the sender unit in that tank.
The return trip from Florida to Ohio was flown with reference to fuel
burn to within one-half gallon remaining in each tank as indicated by
the FS-450.
It works that well.
Ditto, I've got mine calibrated to within a tenth or so as well, and it
only took one adjustment. It consistently is within a half gallon when
I empty the tanks and fill them.
Bird Dog Glenn[_2_] Aviation Photos 0 July 21st 07 12:41 PM
Try this bird man Greg Siemon Home Built 3 January 15th 07 03:17 PM
I Want My Own Bird Yeah_right Owning 72 October 18th 04 02:25 PM
T Bird - ZackGSD Home Built 1 December 15th 03 01:47 PM
