See You Mobile
Old February 24th 08, 10:14 PM posted to rec.aviation.soaring
Default See You Mobile
I am trying to figure out why my AGL nav box is showing the wrong
altitude. On the ground it is showing -4995 feet and it has the same
error throughout the flight. Is there any way that I can adjust that,
or is it my 302 showing it wrong/reading it wrong? All the other
functions are working properly, just AGL that is wrong. Any help would
be greatly appreciated.
Chris
Old February 25th 08, 12:00 AM posted to rec.aviation.soaring
Darryl Ramm
I've seen occasional strange behavior in SeeYou Mobile 2.75 when
switching from simulator mode to GPS input (CF card, I've not tried to
reproduce with my C302). The QNH/Alt settings appears to ends up
whacky, in which case all your altitude related NAV bxes would be
wrong, not just AGL. I've not tried to understand this. But try
switching to the correct data input, reset ground altitude/QNH (on the
Mc. & Alt panel, or at least confirm it is getting this from the C302)
and restart SeeYou Mobile and see if your problem goes away.
A better place to discuss this is the Naviter forums at www.naviter.si.
Mention what version of SeeYou Mobile you are using if you do post
there.
Darryl
Chris
Old February 25th 08, 08:18 AM posted to rec.aviation.soaring
Andrej Kolar
Chris. Let's please discuss this in the Naviter Support forum. That
way we can help several people at once. Not everyone will be looking
for answers on ras.
Thanks.
Andrej Kolar
glider pilots use
http://www.SeeYou.si/
Chris
Old February 26th 08, 04:11 AM posted to rec.aviation.soaring
for answers on ras.
Thanks.
Andrej Kolar
glider pilots usehttp://www.SeeYou.si/
Chris- Hide quoted text -
- Show quoted text -
I did post it in the Naviter Support forum.
Thank you.
Chris Aniol
mobile phones Peter[_4_] Soaring 39 March 14th 07 06:32 AM
Using mobile SeeYou Robert Hart Soaring 3 May 10th 06 09:42 PM
Best mobile Wx Websites Robert M. Gary Piloting 16 March 2nd 05 12:20 PM
SeeYou Mobile Robert Fidler Soaring 0 March 17th 04 04:18 PM
Swidnik PW-6U = MOBILE FUN Charles Yeates Soaring 0 September 22nd 03 08:11 PM
