Q: PBY
Old February 19th 08, 02:30 AM posted to rec.aviation.piloting,rec.aviation.military
William Hung[_2_]
Default Q: PBY
http://www.sa-transport.co.za/aircra...by-5a_ra98.JPG
OK, I've seen pictures of PBYs with;
1. All three gears down and the outer potoons down,
2. All gears down, potoons up,
3. Gears up, potoons down,
4. and now the above picture with only the main gears down, but nose
wheel still tucked in and pontoons still up or maybe no pontoons.
My question are; are the gears controlled individually, are the
pontoons controlled separately, are the font and main gears controlled
separately also? If so, why?
Wil
Old February 19th 08, 05:11 PM posted to rec.aviation.piloting,rec.aviation.military
Morgans[_2_]
Default PBY
"William Hung" wrote in message
I would say the above mentioned aircraft is about to have a very noisy
runway landing, if you get my drift. I vote for gear failure.
Jim in NC
Old February 20th 08, 02:03 AM posted to rec.aviation.piloting,rec.aviation.military
Bob Martin
Default PBY
Maybe it's a case of one gear (nose in this case) retracting before the others? I've
noticed many airplanes where each gear retracts at different rates, or one part of the
gear retracts before the others. I think it just has to do with how the hydraulics are
run and all that. Not sure about this case though.
On multiple occasions, I've seen F-15 nosewheels fail to retract; most of the time they
cleared it by cycling the gear, but twice I noticed it not retract even after cycling. I
guess the pilots really had to pull the power off quick so they doesn't overspeed.
Old February 20th 08, 03:25 AM posted to rec.aviation.piloting,rec.aviation.military
Default PBY
separately also? �If so, why?
�I would say the above mentioned aircraft is about to have a very noisy
runway landing, if you get my drift. �I vote for gear failure.
Maybe it's a case of one gear (nose in this case) retracting before the others? �I've
gear retracts before the others. �I think it just has to do with how the hydraulics are
run and all that. �Not sure about this case though.
cleared it by cycling the gear, but twice I noticed it not retract even after cycling. �I
guess the pilots really had to pull the power off quick so they doesn't overspeed.- Hide quoted text -
- Show quoted text -
Some civilian owned PBYs have added valves to allow retraction of one
gear at a time for servicing. The tip pontoons are on a seperate
system, a single drive motor in the pylon driving shafts in the
leading edge of the wing.
Old February 20th 08, 01:31 PM posted to rec.aviation.piloting,rec.aviation.military
William Hung[_2_]
Default PBY
leading edge of the wing.- Hide quoted text -
Cool, all very plausible explanations.
Thanks guys,
Wil
Old February 22nd 08, 08:49 PM
JOM JOM is offline
Junior Member
First recorded activity by AviationBanter: Jan 2008
Wil
I guess that picture is just after take-off and the nose gear retracted first. (even though the plane appears slight nose down).
The Registration number shown under the picture is wrong, as only US registrations start with N and they can have up to 5 places in the registration. You can only have two letters in the registration, and if there are letters they have to be in the last positions. (A number can never follow a letter - except for the starting "N" of course).
Old February 25th 08, 10:24 PM posted to rec.aviation.piloting,rec.aviation.military
Cubdriver
Default Q: PBY
Here is a photo on Wiki that shows how the outer wing floats
(pontoons) can swing up, so that the pontoon becomes the wingtip.
http://upload.wikimedia.org/wikipedi...F_Catalina.JPG
That has got to be the case with your photo. A larger question is:
where's the tail wheel? Blue skies! -- Dan Ford
On Mon, 18 Feb 2008 18:30:54 -0800 (PST), William Hung
Wil
Claire Chennault and His American Volunteers, 1941-1942
new from HarperCollins www.FlyingTigersBook.com
Old February 25th 08, 10:50 PM posted to rec.aviation.piloting,rec.aviation.military
Hawkeye[_2_]
Default Q: PBY
http://upload.wikimedia.org/wikipedi...K_RNZAF_Catali...
Wil
new from HarperCollinswww.FlyingTigersBook.com
It is a tricycle geared aircraft Dan...the question is...where is the
nose gear!
Old February 25th 08, 11:12 PM posted to rec.aviation.piloting,rec.aviation.military
George Z. Bush
Default Q: PBY
Wil
nose gear!
The nose gear is in what's probably some sort of a sealed compartment within
the forward part of the pontoon/fuselage. Just Google "PBY Photos" and
you'll see pictures of it on the ground.
George Z.
Old February 25th 08, 11:18 PM posted to rec.aviation.piloting,rec.aviation.military
Dave Kearton
Default Q: PBY
nose gear!
"Just called shipping, it'll be here on Monday"
Cheers
Dave Kearton
