Is this the death of GA
Old February 27th 08, 07:52 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Default Is this the death of GA
"Jay Honeck" wrote in
news:OMfxj.52129$9j6.4081@attbi_s22:
But as a general rule, having trucks driving around an airport
pouring their
expensive product into aircraft unable to carry the weight under some
mission
statements is not compatible with sound management and safety
practices.
I'm not catching your point. Why would an FBO do anything an owner
didn't authorize?
Idiot.
Bertie
  #142
Old February 27th 08, 07:58 PM posted to rec.aviation.piloting
kontiki
Jay Honeck wrote:
Now, you're telling me that refueling an airplane from a
professionally-built fuel truck, properly grounded, with the big door
open, is DANGEROUS? I find it hard that anyone so risk averse actually
flies in an airplane. Those things crash, you know.
Having spent a couple of years as an airport manager I am not
speaking out of ignorance. I'm surprised that you don't seem
to be able see the potential dangers. I strongly suggest that
you and the airport manager have a chat with you local fire
marshal, your fuel supplier and your insurance underwriter before
you continue that activity.
It is dangerous to even fuel a lawn mower in your garage because
of the enclosed space, and the risk of a devastating fire in
the even of a fuel spill.
Check with any authority on the subject and see if they don't
tell you the same thing.
Good luck.
  #143
Old February 27th 08, 09:01 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
Jay Honeck wrote:
I'll tell you where it happens -- in the shop hangar. They unscrew the
quick drain, stick a plastic funnel into a 5-gallon plastic jug, and let the
fuel drain. Then, when that jug is full, they quickly move another jug
under the funnel, dumping gas all over the hangar floor. This happens until
the tank is empty.
Don't they bond the aircraft to the fuel container (electrically)? I met
an A&P/IA several years ago that lost his hangar and 3 of his customers'
airplanes by doing exactly what you described above. It was a dry winter day
and the flowing fuel formed a static charge. A faint blue ring around the
stream of gas that the IA noticed about 2 seconds before the hangar went up
in flames.
A simple bonding strap between the airplane and the container would have
avoided the whole mess.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200802/1
  #144
Old February 27th 08, 09:30 PM posted to rec.aviation.piloting
"JGalban via AviationKB.com" u32749@uwe wrote in
news:805fe25d28088@uwe:
the quick drain, stick a plastic funnel into a 5-gallon plastic jug,
and let the fuel drain. Then, when that jug is full, they quickly
move another jug under the funnel, dumping gas all over the hangar
floor. This happens until the tank is empty.
I met
customers' airplanes by doing exactly what you described above. It
was a dry winter day and the flowing fuel formed a static charge. A
faint blue ring around the stream of gas that the IA noticed about 2
seconds before the hangar went up in flames.
have
Exactly, I have a freind who has some very wrinkly looking skin from
defueling an old mercedes in a garage...
Bertie
  #145
Old February 27th 08, 10:54 PM posted to rec.aviation.piloting
Morgans[_2_]
"Jay Honeck" wrote
Have you ever WORKED on a plane, in a shop? Have you ever had to de-fuel
a plane to work on it? Where do you think this happens?
the fuel drain. Then, when that jug is full, they quickly move another
jug under the funnel, dumping gas all over the hangar floor. This happens
This goes on day after day, week after week, year after year, at hundreds
of airports across America. WITH THE DOOR CLOSED. God almighty, if we
were to believe your nonsense, the newspapers would be full of 5-alarm
fires at airports.
The difference in fueling or defueling an airplane in a hangar is how the
hangar is equipped.
It is against fire code to construct an aircraft or perform major
maintenance in a hangar that is not equipped with a sprinkler system. I
know this, because our local EAA chapter has been looking into constructing
a hangar, and to do more than final assembly will not be allowed without
sprinklers, which of course costs big money.
The risk of a fire from fueling an airplane or working on the fuel system is
the same in any hangar, but it is how the risk is managed if a fire results.
Putting a fire out when it first happens may mean the result is saving lives
and property.
To satisfy fire code, fueling and defueling should be done outside, where
there is no possibility of the potentially explosive vapors concentrating to
a dangerous level. If a fire does result, it will likely not be an
explosive event, and will leave those involved with the ability to get away
from the fire quickly, and will also likely not catch anything else on fire.
Isn't that what all fire codes are about? The tradeoffs between prevention,
protection, and suppression.
So while you do not feel that fueling in a hangar is a risk, it is to a fire
marshal, and his regulations say that if you choose to participate in this
risky behavior, you must prevent the possible result from getting out of
hand. That means install sprinklers, at minimum.
Jim in NC
  #146
Old February 27th 08, 11:48 PM posted to rec.aviation.piloting
B A R R Y
On Wed, 27 Feb 2008 17:54:18 -0500, "Morgans"
Is that a local code? Neither of the A&P's I use have sprinklers,
and they run legit businesses that do major repairs.
  #147
Old February 28th 08, 01:25 AM posted to rec.aviation.piloting
Roger[_4_]
On Wed, 27 Feb 2008 15:54:52 GMT, "Jay Honeck"
Fueling an aircraft in a hangar is irresponsible and dangerous.
Here even with our small airport it's not permitted.
Over at MBS they move planes outside to de fuel them. They did that
when I had the Deb weighed for a new W&B.
OTOH we can build plane in the hangars. If the hangar is properly
ventilated we can even paint in it...I only know of one so equipped
and it's prohibited in all others. More than likely due to the fact
you'd be painting planes three hangars either side of you. (they
aren't real tight)
Ya know, Kontiki, normally I agree with your posts -- but this is just plain
crap.
Have you ever WORKED on a plane, in a shop? Have you ever had to de-fuel a
the tank is empty.
It's done ,but in most places it's against the fire code.
The FBO changed a quick drain on one of the tanks on the Deb at
annual. He just unscrewed it and I stuck my finger in the dike until
he had the new one lined up and ready to go. He even remarked we
should be doing that outdoors, but he didn't want to move so many
planes to get it out and back in.
This goes on day after day, week after week, year after year, at hundreds of
airports across America. WITH THE DOOR CLOSED. God almighty, if we were
to believe your nonsense, the newspapers would be full of 5-alarm fires at
airports.
professionally-built fuel truck, properly grounded, with the big door open,
is DANGEROUS? I find it hard that anyone so risk averse actually flies in
www.rogerhalstead.com
  #148
Old February 28th 08, 02:40 AM posted to rec.aviation.piloting
Bob F.
"Roger" wrote in message
aren't real tight)
plain
crap.
a
until
the tank is empty.
of
airports.
open,
In case you haven't noticed, the death of aviation has already occurred. It
happened with all the law suits, rising cost of gas prices and scab CFI's
that will fly for nothing. I've been in the industry for over 45 years.
They say there is a lot of money in aviation. I know that because I put a
lot of it in there! I am appalled that you can't make a decent living in
the industry. Oh yes, there are a few souls that have made it, but it's
like the lotto, not a planned definite process. I can't believe that I have
spent so much time and money in the industry and can't make it there. In
what other industry can you invest almost $100k in training and experience
achieve, what is called "the PhD of Aviation, the ATP", all the CFI's
offered by the FAA and still can't command more then minimum wags?? The
AOPA, FAA, NAFI and defunct organizations such as NPA, etc have all fallen
down on the job, BIG TIME. All useless to foster the community. I go into
a flight school and immediately get the feeling that "I don't want to be
here". You do not feel welcome! All these managers need serious marketing
and business education. And pilots need to start DEMANDING a living wage,
or just don't fly. Students need to expect to PAY for training, $100 per hr
for an instructor is not unreasonable. This about how much you would pay any
other professional. How much would you pay a plumber. Then think about how
much you pay a CFI and gripe about it! NUTS.
BobF.
Lincoln actually got it right but was way ahead of his time when he said,
"You can have some of you computer working all of the time and all of your
computer working some of the time but..." It was he that said that, wasn't
it?
  #149
Old February 28th 08, 03:14 AM posted to rec.aviation.piloting
Morgans[_2_]
"B A R R Y" wrote in message
constructing
As far as I know, NC fire code. Could be that an older building is
grandfathered in, but to build new, there was no doubt that there would have
to be sprinklers.
Jim in NC
  #150
Old February 28th 08, 03:59 AM posted to rec.aviation.piloting
Jay Honeck[_2_]
No.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Death? Ol Shy & Bashful Rotorcraft 10 July 9th 06 12:31 AM
The death of the A-65? Michael Horowitz Home Built 35 November 23rd 05 12:08 AM
death of GA in NY [email protected] Piloting 51 September 16th 05 11:36 PM
