If you are interested in aircraft 3-view drawings, I have just updated my
website. I put at disposal a lot of aircraft 3-view drawings at the page: http://www.elodieroux.com/EditionsEl..._Drawings.html regards, -- Les Éditions Élodie Roux www.elodieroux.com |
Elodie
I was not able to view any of your drawings. When I clicked on the aircraft name, nothing happened. Tom |
Tom Hayden said the following on 02/03/2008 01:25:
Elodie I was not able to view any of your drawings. When I clicked on the aircraft name, nothing happened. Tom Same here but I be the 'buy my book' link works, for some strange reason! |
On Sat, 1 Mar 2008 20:25:27 -0500, "Tom Hayden"
geezer1two3atcomcast.net wrote: Elodie I was not able to view any of your drawings. When I clicked on the aircraft name, nothing happened. Tom Same here. Just pops into the page of the plane, but all that shows is the same plane names menu... |
oh ! There was a mistake in the link ...
Sorry ! It is fine now .... http://www.elodieroux.com/ZBonus_3vi...vuesDC9-51.htm thank you for the remark ! "Tom Hayden" geezer1two3atcomcast.net a écrit dans le message de news: ... Elodie I was not able to view any of your drawings. When I clicked on the aircraft name, nothing happened. Tom |
Thank you very much for your remarks !
In order to change these mistakes, I will try to find another drawings than the ones provided by Boeing... Indeed, the companies often provide drawings with mistakes volountary... Consequently, my own drawings (based on them) have the same mistakes...and I really would like to improve them. So thanks very much. "Robert Moore" a écrit dans le message de news: 8... "Élodie" wrote It is fine now .... http://www.elodieroux.com/ZBonus_3vi...vuesDC9-51.htm The link might be OK now, but the drawings sure aren't. I speak specifically of the early Boeing jetliners, the B-707-120, B-707-320, B-727-100, B-727-200, B-720, all of which I have flown in service with Pan American World Airways, and also the B-737 series which I have not flown. These aircraft were of what we called the "double bubble" construction. An upper lobe and a lower lobe pinched together at the cabin floor line. The above mentioned aircraft shared an almost identical upper lobe, differing only in length, with the major aircraft difference being the size of the lower lobe. Externally, the cockpit areas all looked the same. I call your attention specifically to the drawing of the B-727-100 which looks more like a DC-9 with a third engine than a Boeing. The B-720 is not even close, since it should look identical to the B-707-100 except that it is 8 feet shorter in length. Bob Moore (PanAm retired) |
Worked AOK for me. I had no trouble viewing the 3 views.
Regards Reed ----- "JR" wrote in message ... On Sat, 1 Mar 2008 20:25:27 -0500, "Tom Hayden" geezer1two3atcomcast.net wrote: Elodie I was not able to view any of your drawings. When I clicked on the aircraft name, nothing happened. Tom Same here. Just pops into the page of the plane, but all that shows is the same plane names menu... |
| Thread Tools | |
| Display Modes | |
| 3-view drawings | Élodie | General Aviation | 2 | April 5th 08 11:40 PM |
| View & search aircraft builder projects | [email protected] | Home Built | 0 | November 1st 06 05:16 PM |
| UH-1 Drawings | JKimmel | Rotorcraft | 5 | November 21st 05 10:03 PM |
| 3-VIEW DRAWINGS GROB III ACRO | bambi | Soaring | 1 | September 28th 04 03:27 AM |
| 3 view drawings? | Brent | Products | 0 | September 17th 03 05:46 AM |
