Best warbird to own
Old November 8th 03, 01:30 PM
MLenoch
Correction: A T-28 does require a LOA letter. A limited licensed P-51D does
not require a LOA letter.
V Lenoch
LOOA
  #44
Old November 8th 03, 02:23 PM
N329DF
V Lenoch
LOOA
Vlado,
A big engine 28 requires a letter. The small engine T-28A does not. It's a
HorsePower thing.
Matt Gunsch,
A&P,IA,Private Pilot
Riding member of the
2003 world champion drill team
Arizona Precision Motorcycle Drill Team
GWRRA,NRA,GOA
  #45
Old November 8th 03, 02:24 PM
G.R. Patterson III
Gregg Germain wrote:
THREE guys? Wow I'm impressed. Was one in the nose? ;^)
There was a modification of the P-38 that added a passenger seat in the nose.
The troops gave it the nickname "droop-snoot". Since it replaced the guns, it
was not a popular mod with the pilots. The military radio gear lived in a hole
behind the pilot and was quite substantial. Remove that, and you can fit a
rather cramped seat back there.
George Patterson
If you're not part of the solution, you can make a lot of money prolonging
the problem.
  #46
Old November 8th 03, 02:26 PM
G.R. Patterson III
Peter Stickney wrote:
A Bf 108 would be rather neat, or one of the French Nord Bf
108 followons.
When I bought my Maule, TAP had an ad for a 108 for the same price. It was a
hard choice.
George Patterson
the problem.
  #47
Old November 8th 03, 02:41 PM
G.R. Patterson III
Charles Talleyrand wrote:
I've read three things. The p51 is unstable in pitch with full tanks and the
resulting aft CG, and that a p51 has a high speed stall that's tougher than
most other WWII fighters. And finally the p51 has a higher stall speed
than other contemporary fighters.
The balance problem is caused by the aft fuselage tank. Many Mustangs have had
this removed. In any case, you won't need to fill it unless you're planning a
1600 mile trip. Stall speed in military configuration was about 95, which isn't
out of line with other fighters of the era and is actually a bit lower than the
Bf-109. I've read, however, that the plane doesn't give warning before the stall
and drops the left wing dramatically when it does. Len Deighton claims that few
military pilots three-pointed the Mustang because that gets you too close to the
stall speed. Some years back, I got to watch 52 of these planes land at Sun'n
Fun. Every landing was a wheel landing with the tail slightly low.
George Patterson
the problem.
  #48
Old November 8th 03, 03:30 PM
Larry Dighera
On Fri, 07 Nov 2003 16:50:42 GMT, Larry Dighera
wrote in Message-Id: :
On Fri, 07 Nov 2003 10:39:34 -0600, Alan Minyard
How about an A-37 (or T-37) Tweety Bird? Two seats, reasonable
handling, not too bad on fuel.
Are these actually available? Do you have any idea of the going
price?
http://www.aircraft.com/listings/for...D=1041145&nh=0
CESSNA T-37C, N37VC, Upgraded Engine 20 SMOH, Complete Restoration,
NAT Audio Panel, Skyforce Display, Full Dual Controls, 400 Knots with
Air. Make Offer , $550,000
http://www.airshow.net/globeaero/
Warbirds
(5) T-37 Dragonflys, Removed from foreign government's inventory, need
complete restoration. $100,000 USD in container.
Great PIREP:
Budd Davisson, Air Progress, October, 1976
http://www.caaviation.com/links/fram...essnaT-37.html
The T-37 is cheap (new copies are being sold by Cessna for around
$350,000.
  #49
Old November 8th 03, 04:32 PM
Dale
"G.R. Patterson III" wrote:
orary fighters.
had
isn't
stall
few
I only have 1 hour in a Mustang, but when doing stalls it gave plenty of
warning with the stall occuring at about 81KIAS. We did not however do
any accelerated stalls.
Dale L. Falk
  #50
Old November 8th 03, 04:33 PM
Dale
"killfile" wrote:
The P-51 is a little more unforgiving than some other WWII fighters because
of it's high speed laminar-flow wing - this gives it speed and range, at the
cost of a more 'sudden' wing stall and a higher stall speed.
The Spitfire is more forgiving to fly because, due to a design quirk, it's
airframe actually gives a little shudder to warn you you're near a wing
stall state.
I've never flown a Spitfire, but if you miss the buffet on a Mustang you
must be brain-dead.
Dale L. Falk
Military & vintage warbird slides for sale Wings Of Fury Aviation Marketplace 0 July 10th 04 01:17 AM
FA: 5 Airplane Model Kits - Bomber, Jet, Warbird Disgo Aviation Marketplace 0 February 22nd 04 05:00 PM
FS: Aircraft Instruments Parts Avionics Warbird Parts Bill Berle Home Built 0 January 10th 04 02:20 AM
New B-24 Double Feature Now Showuing at Zeno's Warbird VideoDrive-In! Zeno Military Aviation 0 September 16th 03 03:59 PM
Warbird Runway Crash Mark and Kim Smith Military Aviation 3 September 14th 03 07:47 PM
