I searched around a bit and couldn't seem to find any talk about an
opensource implementation of ADS-B (and maybe some open hardware). Has anyone heard of such a project? It sounds like a worthy project to keep the prices from Garmin and the like in check so a opensource applications can be written to use utilize the underlying ADS-B implementation. Thanks. --Ed |
Ed S wrote:
I searched around a bit and couldn't seem to find any talk about an opensource implementation of ADS-B (and maybe some open hardware). Has anyone heard of such a project? It sounds like a worthy project to keep the prices from Garmin and the like in check so a opensource applications can be written to use utilize the underlying ADS-B implementation. Thanks. --Ed Have you heard of any FAA certified open-source hardware? Hell the GPS is going to have to be WAAS certified you aren't going to get that done via open source. |
On Mar 5, 5:38 pm, Gig 601XL Builder
wrote: Ed S wrote: I searched around a bit and couldn't seem to find any talk about an opensource implementation of ADS-B (and maybe some open hardware). Has anyone heard of such a project? It sounds like a worthy project to keep the prices from Garmin and the like in check so a opensource applications can be written to use utilize the underlying ADS-B implementation. Thanks. --Ed Have you heard of any FAA certified open-source hardware? Hell the GPS is going to have to be WAAS certified you aren't going to get that done via open source. The specs are out (from what I have heard) so in theory, a reference implementation from an outside source put out in open source can be done. I posted this in homebuilt and never mentioned certified. Headless GPS WAAS units are cheap now (as low as $50-60) and I would say are a commodity good. All we would need is a DIY schematic to make the transceiver, a GPS to plugin, and the accompanying software to build the outgoing data and interpret the incoming data. Hope to hear useful responses soon. Thanks. --Ed |
Ed S wrote:
I searched around a bit and couldn't seem to find any talk about an opensource implementation of ADS-B (and maybe some open hardware). Has anyone heard of such a project? It sounds like a worthy project to keep the prices from Garmin and the like in check so a opensource applications can be written to use utilize the underlying ADS-B implementation. Well I'm not surprised - the comment period for the NPRM just closed. In fact some of the comments from the Aircraft Electronics Association[1] seem to indicate not much exists (for light aircraft anyway): "Because the FAA has established this revolutionary change in basic ADS-B performance requirements, there isn't any equipment that currently meets the Minimum Performance Standard for light general aviation aircraft." And they point out that the proposal doesn't make clear whether the equipment must be FAA approved, as noted in this quote: "The FAA once again publishes the performance requirements of equipment, but does not require that the equipment be FAA-approved. This continually causes confusion within the industry. In the proposed 91.225, the FAA should clarify when the ADS-B equipment must be "FAA approved" and when the manufacturer simply needs to show that the ADS-B meets the performance requirements of the respective TSO." A "worthy" project? Hmmm. Any requirment that a citizen who has done nothing wrong must be denied access to a public commons as vast as the national airspace (which is a right by the way, not a privilege[2]) unless that person broadcasts an ID that uniquely identifies that person would seem to be grounds for a lawsuit if that requirement appears in the final rules. Whether it can prevail in the face of ever greater assumption of state patronization of its citizens seem, alas, problematic. :-( [1] http://www.regulations.gov/fdmspubli...ntentType=msw8 [2] "United State Code TITLE 49 - TRANSPORTATION Sec. 40103. Sovereignty and use of airspace .... (2) A citizen of the United States has a public right of transit through the navigable airspace." |
![]() "Jim Logajan" wrote A "worthy" project? Hmmm. Any requirment that a citizen who has done nothing wrong must be denied access to a public commons as vast as the national airspace (which is a right by the way, not a privilege[2]) unless that person broadcasts an ID that uniquely identifies that person would seem to be grounds for a lawsuit if that requirement appears in the final rules. Whether it can prevail in the face of ever greater assumption of state patronization of its citizens seem, alas, problematic. :-( Identifies a person? Humm, I thought it identified an aircraft. I guess you must not like N numbers, or license plates and registrations for your car, either. -- Jim in NC |
"Morgans" wrote:
"Jim Logajan" wrote A "worthy" project? Hmmm. Any requirment that a citizen who has done nothing wrong must be denied access to a public commons as vast as the national airspace (which is a right by the way, not a privilege[2]) unless that person broadcasts an ID that uniquely identifies that person would seem to be grounds for a lawsuit if that requirement appears in the final rules. Whether it can prevail in the face of ever greater assumption of state patronization of its citizens seem, alas, problematic. :-( Identifies a person? Humm, I thought it identified an aircraft. I guess you must not like N numbers, or license plates and registrations for your car, either. Not the same thing. License plates and vehicle registrations don't involve tracking your car's movements. The equivalent (or analogous case) on a car would be a government requirement that everyone using the interstate highway system must have a government approved tracking device on their autos or trucks that allows the government to track (and keep a record for an indefinite time) all your movements on those roads. I'm not sure what your position would be on any government mandate requiring such a thing on any ground vehicles you own. If you are okay with a law that requires you install a tracking device on your ground vehicles then that ends the discussion. We see government in different lights. But if you are not okay with the the government recording all your travels (at your expense too btw), all I can do is to try to stress the similarity in the ground and air cases and hope you see the danger that I see. |
Ed S schreef:
I searched around a bit and couldn't seem to find any talk about an opensource implementation of ADS-B (and maybe some open hardware). Has anyone heard of such a project? It sounds like a worthy project to keep the prices from Garmin and the like in check so a opensource applications can be written to use utilize the underlying ADS-B implementation. What's ADS-B? A US term for a mode S transponder? |
jan olieslagers wrote:
Ed S schreef: I searched around a bit and couldn't seem to find any talk about an opensource implementation of ADS-B (and maybe some open hardware). Has anyone heard of such a project? It sounds like a worthy project to keep the prices from Garmin and the like in check so a opensource applications can be written to use utilize the underlying ADS-B implementation. What's ADS-B? A US term for a mode S transponder? If only it was. It's the FAA plan for "bigger, better" (read way more expensive) Mode S x-ponder. http://en.wikipedia.org/wiki/Automat...ance-broadcast |
cavelamb himself wrote:
here. Happy now? http://www.maxim-ic.com/appnotes.cfm...te_number/1790 I'm aware of similar devices. My wife was part of a startup (http://www.aeris.net/) several years ago that designed and built equipment that could be used for such purposes (technically what they originally did was to piggyback extra data onto the SS7 control channel portion of cell phone comms to send things like break-in alarms for buildings (i.e. no phone lines that burglars could cut) and for sending GPS coordinates when mounted on trucks and other expensive equipment subject to theft). Of course the users of such devices not only have a choice in the matter, the tracking information is considered private. |
