#21
On Tue, 4 Mar 2008 10:43:58 -0800, "Bob Gardner"
wrote: Would this specific instruction include full flaps abeam the numbers? With any airplane? I think the "hard on the motor" argument is bogus. Beech doesn't build airplanes with pre-loaded failure modes. Agreed. As I said in another post. 1300 hours, two sets of tires and no problems with the flap motor. Nor have I ever seen any bulletins on flap motor problems. At one time there was an AD about split flaps but it was rescinded as they have more than enough aileron authority to overcome a full split flap situation. (Might be exciting thoughg) Bob Gardner "Robert M. Gary" wrote in message ... On Mar 4, 9:07 am, "Bob Gardner" wrote: I am reluctant to teach anything that should "always" be used. I agree with you in principle but from a practical point student pilots need to start with very, very specific instruction before they have the tools and expand into these types of judgements. If you don't give students specific airspeeds to hit in the pattern they will always have problems with landings. 9 times out of 10 when a student pilot is having trouble landing all I do is sit in the right seat and say "ok, what speed are you suppose to be at here?" and let them do the rest. -Robert Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
On Tue, 4 Mar 2008 13:33:14 -0800 (PST), "
wrote: On Mar 4, 1:43 pm, "Bob Gardner" wrote: Would this specific instruction include full flaps abeam the numbers? With any airplane? I think the "hard on the motor" argument is bogus. Beech doesn't build airplanes with pre-loaded failure modes. Bob Gardner Apparently people with much more Beechcraft experience than I assert that on-off-on is hard on that flap motor. The piano keys certainly aren't designed to facilitate that method, either. You get used to it. The switch will probably fail long before the flap motor. Dan Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
On Tue, 04 Mar 2008 18:11:59 GMT, "JGalban via AviationKB.com"
u32749@uwe wrote: Bob Gardner wrote: I am reluctant to teach anything that should "always" be used. Flaps are a tool, and we learn early on in life that there are many ways to use a tool to achieve different results. I agree. I usually use multiple flap extensions at my home airport. Lots of student traffic, so there's really no point in slowing down early and flying a wide pattern behind a bunch of students emulating 747s. On the other hand, when I fly into small strips with tall obstructions, I drop full flaps abeam and fly a slow, tight, steep pattern all the way around. It Why? The Bo is a great short field airplane that can slow rapidly. I fly down wind pretty much the same. If it's tight, I dump the gear at the end of the runway. From that point I use the appropriate amount of flaps and size my pattern accordingly.(With full flaps it'll be short and close) If necessary I can go full flaps (40 degrees on those big barn doors is EFFECTIVE) right after gear down as it'll slow so quickly with the gear down the flap speed is no problem. At that point I can simply make a slipping U-turn from pattern altitude on a *close* down wind to the end of the runway and my speed will be down to less than 80 at the round out. With practice I can make it over the so called 50 foot obstacle, at the end of the runway and still make the first turnoff at 800 feet when alone. That PA28-180 can do it in even less distance with those Johnson bar flaps. makes speed control a lot easier in tight places. Different procedures for different conditions. John Galban=====N4BQ (PA28-180) BTW the Deb has the same wing loading as the PA28-180 give or take change (17#/ ft^2. The earlier V35s had even less. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#24
On Wed, 5 Mar 2008 12:26:34 -0800 (PST), Dan
wrote: On Mar 5, 1:29 pm, "JGalban via AviationKB.com" u32749@uwe wrote: wrote: Wait -- why would your second method cause you to "Slow down and fly a wide pattern"? The traffic at the airport necessitates flying a relatively large crowded pattern. There's no real point dropping full flaps and slowing down to approach speed if you're going to be flying a big pattern behind several other aircraft. For me, it works out better to keep the speed up and slow incrementally, depending on what the traffic ahead is doing. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.comhttp://www.aviationkb.com/Uwe/Forums.aspx/aviation/200803/1 In that case, I see the point. "Extend your final" means I'm maintaining my downwind airspeed and altitude until I hear "Follow the Mooney on Final." I'm no longer in a standard pattern, and so the full flaps come later -- probably on final. The question remains -- why not full flaps instead of incremental flaps? For one, the airplane glides a whole lot better clean. Two,it's a whole lot more efficient and three: if there are planes flying a two mile down wind to base and a mile wide base there is no rule you have to follow them if you can make final before any one else turns final. That close in you can be down and clear the runway before any one is even close to the airport. It becomes a necessity when sharing the airport with crop dusters and students. Dan Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#25
On Wed, 5 Mar 2008 05:02:34 -0800 (PST), Dan
wrote: On Mar 5, 7:51 am, Denny wrote: My Apache does not have fixed flap positions, and full down flap results in such an exteme nose down attitude that it makes the passengers think you are dive bombing the airport I kinda like it... As a result I routinely use partial flaps... A little bit on downwind to help slow the fatboy to 110 indicated, a bit more on base to give me 100 on the speedo, and final depends on the amount of wind and the angle to the runway... There is a flap position indicator on the panel but it is just this side of useless - besides being 3 feet away on the other side of the cockpit... I look over my shoulder as I lower the flap and set it by eyeball and feel... On a dark night I set it by the feel and experience... I agree that students and low time pilots need fixed flap settings at specific points int he pattern... denny Twins are a little different as you have the approach speed argument to settle first -- do you want enough speed/energy to maintain Vmc? If so, full flaps will likely require a steep descent as you're describing. Besides, if you're flying a twin you're beyond student pilot days and thus are working on art -- adapting the rules to fit the situation. I would hope students are too. At least well before the checkride. My instructors had me weaned off the stabilized pattern before they let me solo. Good thing too. Dan Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#26
On Mar 6, 1:50 am, Roger wrote:
It shouldn't be. As I said earlier. Just fly the figures in the POH as Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair)www.rogerhalstead.com Thanks for the good feedback based on experience. But I have a few questions/comments --- 1) We replaced the flap actuator assembly this November (last replacement was ~400 hours ago), so I'm sensitive to breaking it. 2) There is no POH for the '47. There is an "Owner's Manual" that looks like something you used to get with a new Ford. There is scant data on takeoff and landing configurations, only speeds. 3) How do you know you have 15 degrees of flaps? Sure you can "Compare to aileron travel" to get an idea on the ground, but you cannot be that precise in flight. 4) I don't know what you mean by "Why trim after each flap change? You aren't flying a Cessna". I find (as expected) that after each Power/ Attitude/Configuration change, there's a subsequent trim adjustment -- in any airplane. 5) 80 MPH on final seems fast, when 1.3 Vso = 62 MPH (flaps down, power off stall speed = 47 MPH). I target 65 on short final and usually land and stop within 1500'. Dan |
#27
On Thu, 6 Mar 2008 04:25:36 -0800 (PST), Dan
wrote: On Mar 6, 1:50 am, Roger wrote: It shouldn't be. As I said earlier. Just fly the figures in the POH as Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair)www.rogerhalstead.com Thanks for the good feedback based on experience. But I have a few questions/comments --- 1) We replaced the flap actuator assembly this November (last replacement was ~400 hours ago), so I'm sensitive to breaking it. In 1300 hours I've had no problems and IF the airframe log is correct it's still original. 2) There is no POH for the '47. There is an "Owner's Manual" that looks like something you used to get with a new Ford. There is scant data on takeoff and landing configurations, only speeds. 3) How do you know you have 15 degrees of flaps? Sure you can "Compare to aileron travel" to get an idea on the ground, but you cannot be that precise in flight. Lay a straight edge on the top of the wing. Lower the flaps while measuring the change with a protractor. Using a straight edge and felt marker, place the appropriate marks on the leading edge of the flap on the pilot's side. You'll soon find you can count one thousandone, one thousand two...etch and come out within a couple of degrees. 4) I don't know what you mean by "Why trim after each flap change? You aren't flying a Cessna". I find (as expected) that after each Power/ Attitude/Configuration change, there's a subsequent trim adjustment -- in any airplane. Not in the Bo. In the ones I've flown you can go from no to basically full (40 degrees) with no trim change required. HOWEVER when slowing down substantial trim changes are required with airspeed changes, so if there is an airspeed change coupled with the flap change then yes retrimming is required. Normally I find no need to change trim on down wind (unless slowing from a fast entry) and base. On final, I know I was flying the right speeds for the loading if the trim ends up against the up stop. 5) 80 MPH on final seems fast, when 1.3 Vso = 62 MPH (flaps down, power off stall speed = 47 MPH). I target 65 on short final and usually land and stop within 1500'. The older ones are much lighter and can be flown slower., I think I mentioned that. With mine stall in the landing configuration is 63 at gross which works out to about 80 MPH on final. With just me and half fuel it's about 75 to 76 MPH. That ends up with land and roll out of about 1200 feet and little if any use of the brakes. With short field technique it'll easily stop in 800 or less (IF the pilot is up-to-date and proficientg). That also results in a steep final with substantial power. Power out landings are faster at 90 MPH and take considerably more runway. Gross is 2950 or 3100# when the tip tanks are full. Dan Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
#28
Dan wrote:
I'm no longer in a standard pattern, and so the full flaps come later -- probably on final. The question remains -- why not full flaps instead of incremental flaps? I suppose I could pop out all of the flaps at once, but as I said above, I base it on what the traffic (ahead and behind) is doing. Traffic ahead is generally slowing down in increments, so I use my flaps to do the same. For following traffic I don't want to slow down too early in the pattern. There are a lot of students and they tend to start crowding my tail if I do. On those rare occasions when the pattern ahead is empty, I do drop full flaps abeam and make a tight pattern. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200803/1 |
#29
On Mar 6, 1:10 pm, Roger wrote:
In 1300 hours I've had no problems and IF the airframe log is correct it's still original. Is the flap actuator/motor the same in a Deb as a '47 V tail? Not in the Bo. In the ones I've flown you can go from no to basically full (40 degrees) with no trim change required. HOWEVER when slowing down substantial trim changes are required with airspeed changes, so if there is an airspeed change coupled with the flap change then yes retrimming is required. Normally I find no need to change trim on down wind (unless slowing from a fast entry) and base. On final, I know I was flying the right speeds for the loading if the trim ends up against the up stop. OK, that explains it. When I apply full flaps, I'm also pitching and trimming to attain my turn to base speed of 70 MPH in the '47 V, and 80 KIAS in the A36. 5) 80 MPH on final seems fast, when 1.3 Vso = 62 MPH (flaps down, power off stall speed = 47 MPH). I target 65 on short final and usually land and stop within 1500'. The older ones are much lighter and can be flown slower., I think I mentioned that. With mine stall in the landing configuration is 63 at gross which works out to about 80 MPH on final. With just me and half fuel it's about 75 to 76 MPH. That ends up with land and roll out of about 1200 feet and little if any use of the brakes. With short field technique it'll easily stop in 800 or less (IF the pilot is up-to-date and proficientg). That also results in a steep final with substantial power. Power out landings are faster at 90 MPH and take considerably more runway. Right -- the '47 V is very light, and bounces like a cork in the smallest breeze. The A36, however, is like an airliner -- it grosses at 3780 with full tip tanks. My 1500' figure is 50' obstacle clearance -- not ground roll. I'm guessing I'm at about 800' ground roll with heavy braking, but I rarely need to do that. Thanks for the feedback! I like to disagree if the contrary opinion can be explained rationally. I'm more than happy to have my mind changed if my knowledge/skills improve! Dan |
#30
On Thu, 6 Mar 2008 15:21:37 -0800 (PST), Dan
wrote: On Mar 6, 1:10 pm, Roger wrote: In 1300 hours I've had no problems and IF the airframe log is correct it's still original. Is the flap actuator/motor the same in a Deb as a '47 V tail? According to my manual the actuator motor assembly is 35-080109 for both models, BUT and I emphasize that BUT in capital letters I have found the occasional discrepancy in those shop manuals. One, with which I am intimately familiar is the routing of the Throttle, prop, and mixture controls which were replaced (died of old age) so although my manual lists it as the same, "like anything on the web" I'd take that with a grain of salt:-)) I'd really expect better from Beech though. Like the old 35s the switch is a momentary one, but unlike you guys flying the "expensive planes", with the "piano key switches, my economy class Deb only has a momentary toggle switch with a handle shaped like a flap.:-)) Not in the Bo. In the ones I've flown you can go from no to basically full (40 degrees) with no trim change required. HOWEVER when slowing down substantial trim changes are required with airspeed changes, so if there is an airspeed change coupled with the flap change then yes retrimming is required. Normally I find no need to change trim on down wind (unless slowing from a fast entry) and base. On final, I know I was flying the right speeds for the loading if the trim ends up against the up stop. The early Debs (a V35 with a conventional tail grafted on - Designator is 35-33) had a very coarse manual trim with the trim wheel hidden up behind the panel. There's a white stripe painted on the panel to show you where you should reach to try to find it:-)) OTOH there is no mistaking it, but less than half an inch travel can shove you right down in the seats or leave *things* floating around the cabin. It is coarse in the extreme. They fixed that in the first year or early on into the second. At 5'7" my eyes are just peaking over the edge of the glare shield when adjusting the trim. That makes the adjustment from 120 on the ILS at DH to landing speed ... interesting. Tis a good thing they slow quickly, but that means some major trim changes in just a few seconds. However, after well over a 1000 hours I just automatically reach for it any time I find myself holding forward or aft pressure on the yoke. Even coming down final I find myself retrimming with out conscious thought as the Deb slows. OK, that explains it. When I apply full flaps, I'm also pitching and trimming to attain my turn to base speed of 70 MPH in the '47 V, and 80 KIAS in the A36. 5) 80 MPH on final seems fast, when 1.3 Vso = 62 MPH (flaps down, power off stall speed = 47 MPH). I target 65 on short final and usually land and stop within 1500'. The older ones are much lighter and can be flown slower., I think I mentioned that. With mine stall in the landing configuration is 63 at gross which works out to about 80 MPH on final. With just me and half Book figures for short field landing are still better than a lot of 172s though. fuel it's about 75 to 76 MPH. That ends up with land and roll out of about 1200 feet and little if any use of the brakes. With short field technique it'll easily stop in 800 or less (IF the pilot is up-to-date and proficientg). That also results in a steep final with substantial power. Power out landings are faster at 90 MPH and take considerably more runway. Right -- the '47 V is very light, and bounces like a cork in the smallest breeze. The A36, however, is like an airliner -- it grosses at 3780 with full tip tanks. The Deb and F-33 is in between and a joy to fly even in weather. OTOH if flying in IMC an autopilot is almost a necessity for the workload. It may have a big wing light loading at 17# (give or take change), but it's slipperier than snot on a doorknob. I've never had a chance to fly one of the later F-33s after the 40% increase in useful load. Mine has the 260 HP IO-470N STC with the big 3-blade Hartzell prop, gap seals, 1/2" thick speed sloped windshield, and tip tanks. http://www.rogerhalstead.com/833R/833R_frame.htm That prop made a tremendous difference in energy management. My 1500' figure is 50' obstacle clearance -- not ground roll. I'm guessing I'm at about 800' ground roll with heavy braking, but I rarely need to do that. The heavier weight, a slow, steep descent and lots of power will yield between 800-1200 over that 50 footer on a cool day with a light head wind, but that's with lots of practice. I'm no where near that proficient at present. Thanks for the feedback! I like to disagree if the contrary opinion can be explained rationally. I'm more than happy to have my mind changed if my knowledge/skills improve! Dan Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
| teaching emergency landings...How low do you go... | gatt[_2_] | Piloting | 18 | February 27th 08 10:57 PM |
| Aerotow - learning and teaching | [email protected] | Soaring | 11 | September 12th 05 10:53 PM |
| Teaching the aerotow | Paul Moggach | Soaring | 5 | September 12th 05 04:31 AM |
| Ground launch and the incremental vanishing of soaring | Mark James Boyd | Soaring | 24 | March 8th 04 11:50 PM |
| Teaching airworthiness | Roger Long | Piloting | 28 | October 2nd 03 10:08 PM |
