On Mar 11, 9:25*am, "Bob Gardner" wrote:
Your instructor was wrong. Ground control owns everything up to the hold line for the runway in use. Wrong for knowing local procedures? You really shouldn't put that out there with the information we have here. For all you know he knows the local procedures better than you. Again, there are airports where tower takes this resposibility. Its not wrong to ask ground first but they then just ask you to call the tower and ask them. I've been to such ariports and I'm sure you have too. If this CFI was using local procedures knowledge, it sure doesn't make him "wrong". -Robert, CFII |
![]() "Robert M. Gary" wrote in message ... Wrong for knowing local procedures? You really shouldn't put that out there with the information we have here. For all you know he knows the local procedures better than you. Again, there are airports where tower takes this resposibility. Its not wrong to ask ground first but they then just ask you to call the tower and ask them. I've been to such ariports and I'm sure you have too. If this CFI was using local procedures knowledge, it sure doesn't make him "wrong". The instructor was wrong. If local procedures call for the pilot to be on tower frequency for runway crossing instructions the ground controller would have instructed the pilot to contact tower. |
On Mar 11, 10:03*am, "Steven P. McNicoll"
wrote: "Robert M. Gary" wrote in ... The instructor was wrong. *If local procedures call for the pilot to be on tower frequency for runway crossing instructions the ground controller would have instructed the pilot to contact tower. You would think but when I've had the same experience ground has also assumed I knew to ask tower. The instructor is not wrong simply because the controller forgot the instructions. If this CFI flys out of this airport several times a day and knows the procedure, it does not make him wrong simply because ATC forgot to state the procedure. -Robert |
Robert M. Gary wrote:
You would think but when I've had the same experience ground has also assumed I knew to ask tower. The instructor is not wrong simply because the controller forgot the instructions. If this CFI flys out of this airport several times a day and knows the procedure, it does not make him wrong simply because ATC forgot to state the procedure. -Robert I've flown out of KRVS in Tulsa, OK where they have an unusual procedu after taxiing, you report your "run-up complete" to ground and they sequence you for takeoff and give you a positive handoff to tower when you're #1 for takeoff. Sometimes they tell you this when you call up ground, sometimes they don't. I'm not a controller, but doesn't the ground controller have to get permission from (or at least coordinate with) the runway's "owner" (tower) before allowing you to cross anyway? Dan Luke wrote: Didn't say it was, but I bet it's more relaxed than a busy Bravo like Houston Hobby, for example. They don't care much for home-made radio procedure at HOU. Funny thing, I flew out of Hobby too back when they were still an ARSA.... But RDU is busy enough that they don't generally allow any training activity (touch & go's) there. Thanks for the sanity check, all! |
![]() "Robert M. Gary" wrote in message ... You would think but when I've had the same experience ground has also assumed I knew to ask tower. An incorrect assumption. The instructor is not wrong simply because the controller forgot the instructions. If this CFI flys out of this airport several times a day and knows the procedure, it does not make him wrong simply because ATC forgot to state the procedure. The procedure is to remain on ground control frequency until ready to request takeoff clearance. The instructor was wrong because he told the student something contrary to that procedure. |
![]() "TakeFlight" wrote in message ... I'm not a controller, but doesn't the ground controller have to get permission from (or at least coordinate with) the runway's "owner" (tower) before allowing you to cross anyway? Yes. |
On Mar 11, 1:08*pm, TakeFlight wrote:
Dan Luke wrote: Didn't say it was, but I bet it's more relaxed than a busy Bravo like Houston Hobby, for example. They don't care much for home-made radio procedure at HOU. Funny thing, I flew out of Hobby too back when they were still an ARSA.... * Hey, I did too, when were you there? I trained out of Hobby in 84-85! Cheers, John Clonts Temple, Texas |
John Clonts wrote:
Hey, I did too, when were you there? I trained out of Hobby in 84-85! Cheers, John Clonts Temple, Texas 89-90, American Flyers. Then I flew at Bay Area Aero Club at SPX and the club at Ellington Field. |
On Mar 11, 12:25*pm, "Steven P. McNicoll"
wrote: "Robert M. Gary" wrote in ... The procedure is to remain on ground control frequency until ready to request takeoff clearance. *The instructor was wrong because he told the student something contrary to that procedure True the instructor was wrong. I would be wrong too, in fact next time I'm at ABQ I'll be wrong again because I'll continue to follow the procedure requested by ATC despite that fact that its wrong. So we agree, he was wrong, I'm wrong, and he and I will continue to be wrong. -Robert |
This information, taken from the Air Traffic Control Handbook, may be
useful: "3-1-3. USE OF ACTIVE RUNWAYS The local controller has primary responsibility for operations conducted on the active runway and must control the use of those runways. Positive coordination and control is required as follows: NOTE- Exceptions may be authorized only as provided in para 1-1-10, Constraints Governing Supplements and Procedural Deviations, and FAAO 7210.3, Facility Operation and Administration, Use of Active Runways, para 10-1-7, where justified by extraordinary circumstances at specific locations. REFERENCE- FAAO 7110.65, Constraints Governing Supplements and Procedural Deviations, Para 1-1-10. FAAO 7210.3, Use of Active Runways, Para 10-1-7. a. Ground control must obtain approval from local control before authorizing an aircraft or a vehicle to cross or use any portion of an active runway. The coordination shall include the point/intersection at the runway where the operation will occur. PHRASEOLOGY- CROSS (runway) AT (point/intersection). b. When the local controller authorizes another controller to cross an active runway, the local controller shall verbally specify the runway to be crossed and the point/intersection at the runway where the operation will occur preceded by the word "cross." PHRASEOLOGY- CROSS (runway) AT (point/intersection). c. The ground controller shall advise the local controller when the coordinated runway operation is complete. This may be accomplished verbally or through visual aids as specified by a facility directive. d. USA/USAF/USN NOT APPLICABLE. Authorization for aircraft/vehicles to taxi/proceed on or along an active runway, for purposes other than crossing, shall be provided via direct communications on the appropriate local control frequency. This authorization may be provided on the ground control frequency after coordination with local control is completed for those operations specifically described in a facility directive. NOTE- The USA, USAF, and USN establish local operating procedures in accordance with, respectively, USA, USAF, and USN directives. e. The local controller shall coordinate with the ground controller before using a runway not previously designated as active. REFERENCE- FAAO 7110.65, Coordination Between Local and Ground Controllers, Para 3-1-4. 3-1-4. COORDINATION BETWEEN LOCAL AND GROUND CONTROLLERS Local and ground controllers shall exchange information as necessary for the safe and efficient use of airport runways and movement areas. This may be accomplished via verbal means, flight progress strips, other written information, or automation displays. As a minimum, provide aircraft identification and applicable runway/intersection/taxiway information as follows: a. Ground control shall notify local control when a departing aircraft has been taxied to a runway other than one previously designated as active. REFERENCE- FAAO 7110.65, Use of Active Runways, Para 3-1-3. FAAO 7210.3, Selecting Active Runways, Para 10-1-6. {New-2007-17 b. revised August 30, 2007} b. Ground control must notify local control of any aircraft taxied to an intersection for takeoff. This notification may be accomplished by verbal means or by flight progress strips. REFERENCE- FAAO 7110.65, Wake Turbulence Separation for Intersection Departures, Para 3-9-7. c. When the runways in use for landing/departing aircraft are not visible from the tower or the aircraft using them are not visible on radar, advise the local/ground controller of the aircraft's location before releasing the aircraft to the other controller." Bob Gardner "TakeFlight" wrote in message ... Had a dual flight the other day at RDU (runway diagram link at bottom for reference). We requested runway 14 for departure, and ground told us "taxi to runway 14 via Juliet, Charlie, hold short of 23L" (we were departing from the general aviation ramp). So I taxied out, eventually holding short of 23L on Charlie. The instructor asked if I was going to switch to tower. I told him no, that we weren't at 14 yet. He insisted that since we were holding short of 23L that we needed to contact the tower to get across. I disagreed. So he called the tower and reported us as "holding short of 23L." After a landing aircraft rolled by, tower told us to taxi to 14 and cleared us for takeoff. In 18 years of flying, I've never run across this before. Is this something new, peculiar to RDU, or was he just mistaken? Whenever I've been in this situation before, ground always was the one to tell me to cross a runway and taxi on to my departing runway. Granted, it could be the same controller just on a different freq.... http://204.108.4.16/d-tpp/0802/00516AD.PDF |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
OSH question | Bill Chernoff | Home Built | 8 | November 20th 04 01:07 AM |
Serious question | BackToNormal | Military Aviation | 33 | November 3rd 03 06:47 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
