#21
I am sorry to belabor this point, but hopefully I will understand it better
if you have the patience to help me. I understand that gravity's acceleration is indistinguishable from any other acceleration in a frame of reference, and that it is 1g in a constant descent or climb. I also understand that a turn is accelerating to the center of the arc whether it is descending, level, or climbing. Are you saying the force vector sums are equivalent when comparing level turns at the same bank angle to constant rate descent? In other words, that a 2g load factor occurs in a 60 degree bank regardless of whether remaining level or a constant rate of descent and that the stall speeds are identical? The engine power required is plainly different. Thanks. The center just becomes a line in that case, doesn't it? You end up with the same centripetal force needed towards that center line in order to turn. Nosing over into a descent does temporarily reduce load factor, but as soon as you're established in a constant descent, you're back at the same 1g load. Gravity is *acceleration*, not *velocity*. -- James Carlson, Solaris Networking |
On Mar 12, 3:39 am, Dan wrote:
On Mar 12, 2:18 am, "Ken S. Tucker" wrote: -- IGNORE BELOW -- Depends on the A/C, what were you flying? In an F-4 doing a 3-4g bank is easy, but in a trainer I'd suggest 2g max. Ken -- IGNORE ABOVE --- Assuming you're not flying an F-4 in a sim, we'll move on to reality.... This fear is (correctly) pounded into every aspiring/training pilot -- don't cross control stall on turn to final! A pilot is trained to do 2g coordinated turns, even in twink flying, gee I wonder why. It's a perfectly safe thing to do and IIRC was a requirement for a pilot's license. Ken [snip, I have no comment] |
This is bugging me so much, I am going to climb to altitude and test it
myself next time I fly. It will be good practice anyway. The problem will be that the airspeed indicator isn't that accurate at those slow speeds but it should be equivalent in both level and descending flight stall breaks. The hard part will be maintaining a constant descent rate while in a steep bank and not letting it wander up and down. I believe you guys are correct, I just can't understand the reason behind it. Nothing like a real experiment to prove the theory if I can't understand the physics behind it. |
wrote in news:mrTBj.72580$yE1.11316@attbi_s21:
Why does no one distinguish between a level turn (constant acceleration into the center of the arc, which increases load factor) and the load factor in which the same angle of bank exists in a descent? Because it's negligable. Bertie |
wrote in news:rmVBj.72735$yE1.30385@attbi_s21:
This is bugging me so much, I am going to climb to altitude and test it myself next time I fly. It will be good practice anyway. The problem will be that the airspeed indicator isn't that accurate at those slow speeds but it should be equivalent in both level and descending flight stall breaks. The hard part will be maintaining a constant descent rate while in a steep bank and not letting it wander up and down. Doesn't matter if it's correct or not, you'll reap huge benifits form this sort of experimentation in the experience you'll get flying that close to the edge. Bertie |
#28
In article xQUBj.19725$TT4.4490@attbi_s22, wrote:
I am sorry to belabor this point, but hopefully I will understand it better if you have the patience to help me. I understand that gravity's acceleration is indistinguishable from any other acceleration in a frame of reference, and that it is 1g in a constant descent or climb. I also understand that a turn is accelerating to the center of the arc whether it is descending, level, or climbing. Are you saying the force vector sums are equivalent when comparing level turns at the same bank angle to constant rate descent? In other words, that a 2g load factor occurs in a 60 degree bank regardless of whether remaining level or a constant rate of descent and that the stall speeds are identical? The engine power required is plainly different. Thanks. In the case of descending flight, gravity is supplying some of the power required to maintain flight. With wings level, you are at 1.0 g whether climbing, level or descending. The same rules apply to turning flight. -- Remove _'s from email address to talk to me. |
#29
Ron Natalie wrote:
Dudley Henriques wrote: Ask your instructor to explain to you what happens to the stall speed in a LEVEL turn as opposed to the stall speed in an unloaded gliding turn from base to final. This is a distinction you should definitely be aware of. If he's maintaining a constant rate of descent during the turn there is no distinction. The load factor decreases only if he is accellerating towards the ground. Exactly. The difference between a loaded turn and simply allowing the nose to fall through with reduced back pressure. -- Dudley Henriques |
#30
Ken S. Tucker wrote:
On Mar 12, 3:39 am, Dan wrote: On Mar 12, 2:18 am, "Ken S. Tucker" wrote: -- IGNORE BELOW -- Depends on the A/C, what were you flying? In an F-4 doing a 3-4g bank is easy, but in a trainer I'd suggest 2g max. Ken -- IGNORE ABOVE --- Assuming you're not flying an F-4 in a sim, we'll move on to reality.... This fear is (correctly) pounded into every aspiring/training pilot -- don't cross control stall on turn to final! A pilot is trained to do 2g coordinated turns, even in twink flying, gee I wonder why. It's a perfectly safe thing to do and IIRC was a requirement for a pilot's license. Are you just making this stuff up as you go along? The Practical Test Standard requires the demonstration of a steep turn at 45 degree bank and a safe or recommended airspeed. That's as steep and high g as it gets and it's not going to be 2g in my plane. |
Implications of.....keeping the speed up | [email protected] | Instrument Flight Rules | 48 | January 14th 07 11:41 PM |
Gamepad, stopping throttle axis from being auto-centered | DenisK | Simulators | 1 | December 20th 06 09:16 AM |
Keeping a builders log | Lou | Home Built | 24 | January 28th 06 10:46 PM |
Thanks for ideas on drilling a centered hole! | Scott | Home Built | 12 | October 25th 04 02:52 AM |
Keeping Me Out of Your Warbird? | Stephen Harding | Military Aviation | 47 | February 12th 04 04:34 PM |
