ATC Phraseology
Old March 13th 08, 03:56 PM posted to rec.aviation.piloting
Larry Dighera
Default ATC Phraseology
I heard the following exchange this morning:
ABC-Tower: "Citation-XXX, ABC-Tower."
Citation-XXX: "ABC-Tower, Citation-XXX; say current wind."
ABC-Tower: "Citation-XXX, ABC-Tower, wind 150 at 4."
Citation-XXX: "ABC-Tower, Citation-XXX; is that wind *ZERO* 4?"
silence
Citation-XXX: "ABC-Tower, Citation-XXX; confirm wind *ZERO* 4."
ABC-Tower: "Citation-XXX, ABC-Tower; that's affirmative."
Was the Citation pilot's pedantic request appropriate? Must
controllers prepend a "zero" to single-digit wind speeds?
Old March 13th 08, 04:13 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Larry Dighera" wrote in message
silence
No.
Must controllers prepend a "zero" to single-digit wind speeds?
No.
Old March 13th 08, 04:20 PM posted to rec.aviation.piloting
Gig 601XL Builder[_2_]
silence
They should. 04 and 40 are very different directions and radios in
aircraft are notoriously bad so adding the 0 where it is supposed to be
certainly can cut down on mis-communication.
Old March 13th 08, 04:32 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Gig 601XL Builder" wrote in message
The issue was the wind speed, not the direction. The controller issued the
wind correctly.
Old March 13th 08, 04:50 PM posted to rec.aviation.piloting
wind correctly.
You are right I mis-read.
Old March 13th 08, 05:57 PM posted to rec.aviation.piloting
Mortimer Schnerd, RN[_2_]
I'd say both were appropriate. The AC asked; the controller answered; the AC
wasn't sure whether he heard "four" or "forty" (although it should have been
painfully obvious), and so the controller clarified his original answer.
I still would have said "150 at 4" the first time. I'd bet 90% of pilots would
never ask for the answer to be amplified unless they had good reason... say
heavy turbulence, passing cells or whatever. So for 90%, that would have been
the end of it.
But if I don't understand or am not sure I understand a reply, I'd ask for an
amplified answer in a heartbeat.
mschnerdatcarolina.rr.com
Old March 13th 08, 06:04 PM posted to rec.aviation.piloting
Was the Citation pilot's pedantic request appropriate? *Must
I've never heard a controller or ATIS or ASOS or AWOS state wind is
"at zero four" when they mean "at four".
However, maybe the Citation pilot had static or otherwise bad
reception -- he wanted to make sure it wasn't "four zero". In other
words, he *might* have heard "wind 150 at 4static burst or heterodyne
squeal". In which case you might ask for clarification without being
pedantic.
I can't remember if that squeal that is caused by stepping on someone
else's transmission is called "heterodyne" or not.
Old March 13th 08, 06:11 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Mortimer Schnerd, RN" mschnerdatcarolina.rr.com wrote in message
news
AC wasn't sure whether he heard "four" or "forty" (although it should have
been painfully obvious), and so the controller clarified his original
answer.
If there had been 40 knots of wind it would have been issued as "four zero",
not "forty".
Old March 13th 08, 06:16 PM posted to rec.aviation.piloting
Steve Foley
"Steven P. McNicoll" wrote in message
zero",
not "forty".
It *should* have been issued as "four zero".
I've heard plenty of non-standard phraseology from ATC.
The wind speed makes a lot more difference to the guy in the plane than it
does to the guy in the tower. I would have asked.
Old March 13th 08, 06:17 PM posted to rec.aviation.piloting
answer.
not "forty".
Most likely but it wouldn't be the first time I've heard nonstandard phrasing.
Non Standard ATC Phraseology In Soo Piloting 20 November 24th 04 06:45 PM
Phraseology Thomas Myers Instrument Flight Rules 13 July 20th 03 01:56 PM
