Thinking about stalls
Old March 13th 08, 07:53 AM posted to rec.aviation.piloting
WingFlaps
Default Thinking about stalls
On Mar 13, 6:45*pm, Big John wrote:
On Wed, 12 Mar 2008 17:14:17 -0700 (PDT), WingFlaps
Hi All,
Imagine a plane in 2 conditions.
1) Climbing with full power
2) Descending fast with 50% power.
Both have constant rates of ascent and descent.
Question A: Which wing is closer to stall?
Question B: A big updraft occurs, which is more likely to stall?
If you vote first it _may_ lead to some good discussion later...
Cheers
Obviously #2. Any one should be able to see that.
Aha, so it is closer to the stall?
Cheers
Old March 13th 08, 01:21 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Jim Logajan wrote in
WingFlaps wrote:
Hi All,
Waitaminute - how can a plane be in both conditions at the same time!?
Ken can probably explain it better than anyone.
Bertie
Old March 13th 08, 03:02 PM posted to rec.aviation.piloting
gatt[_2_]
"WingFlaps" wrote in message
Hi All,
I'm not sure if there's enough information. If it's a typical prop plant I
would expect that there would be a difference between a high wing and a low
wing due to slipstream effects, but my guess would be that the right wing
would be closer. Or, are you asking which of the two scenarios is
closer/more likely to stall. In that case, I'd say the first
configuration. Full-power departure stalls are easy to encounter.
-c
Old March 13th 08, 05:59 PM posted to rec.aviation.piloting
TakeFlight
Put me in the "not enough info" column.
Plane #2 could be in fact _in_ a stall (or spin), "descending fast
with 50% power" or _more_. Think Delta Flight 191, for example.
On Mar 12, 8:14 pm, WingFlaps wrote:
Hi All,
Cheers
Old March 13th 08, 08:11 PM posted to rec.aviation.piloting
Brian[_1_]
OK... *but is the climbing or descending wing generating the most
lift?
I agree, your original question is missing some critical information.
Such as:
1. are the airspeeds the same for each aircraft?
2. confirm that the decending aircraft is not already stalled
3. Do the airplanes weigh the same?
As for your question above, given that the airplanes are ascending or
decending at constant rates then the lift is equal to the wieght of
the airplane in both cases. If the aircraft are the same wieght then
the lift generated will be the same.
Brian CFIIG/ASEL
Old March 13th 08, 08:16 PM posted to rec.aviation.piloting
WingFlaps
That is not correct.
Cheers
Old March 13th 08, 08:18 PM posted to rec.aviation.piloting
WingFlaps
Hi All,
I'm not sure if there's enough information. *If it's a typical prop plant I
would be closer. * Or, are you asking which of the two scenarios is
closer/more likely to stall. * *In that case, I'd say the first
configuration. * *Full-power departure stalls are easy to encounter.
Ok good, but let's say both planes have the same airspeed. Does that
change anything?
Cheers
Old March 13th 08, 08:33 PM posted to rec.aviation.piloting
Jim Logajan
Hmmm. Brian's statement appears essentially correct - and you are correct
too. The "gotcha" is that the vertical component of the lift force exceeds
the weight only during the transition from level flight to constant
ascending flight. And the lift force is less than the weight during the
transition from level flight to constant descending flight.
But once the vertical speed becomes constant (whether up or down) the
vertical component of lift has to equal the downward force of gravity. If
it didn't, then the aircraft would begin _accelerating_ up or down,
depending on the difference.
Old March 13th 08, 08:37 PM posted to rec.aviation.piloting
WingFlaps
Nope, if the airspeed is constant, the lift from the two wings is not
the same. This is thought provoking discussion I was hoping to start!
Can you see why lift does not equal weight in both cases?
Cheers
Old March 13th 08, 08:59 PM posted to rec.aviation.piloting
Jim Logajan
or decending at constant rates then the lift is equal to the
wieght of the airplane in both cases. If the aircraft are the same
wieght then the lift generated will be the same.
correct too. The "gotcha" is that the vertical component of the lift
force exceeds
the transition from level flight to constant descending flight.
gravity. If it didn't, then the aircraft would begin _accelerating_
up or down, depending on the difference.
I don't wish to be confrontational since you are looking for thought
provoking discussion, but I am pretty sure there is a fair amount of
imprecision, and therefore ambiguity, in your statements. This tends to
make it difficult to get very far in these discussions.
Would it help any if I presented the 2-D equations of force involved?
And perhaps you could do the same?
Stalls?? Ol Shy & Bashful Piloting 155 February 22nd 08 03:24 PM
why my plane stalls Grandss Piloting 22 August 14th 05 07:48 AM
Practice stalls on your own? [email protected] Piloting 34 May 30th 05 05:23 PM
Newbie Qs on stalls and spins Ramapriya Piloting 72 November 23rd 04 04:05 AM
Wing tip stalls mat Redsell Soaring 5 March 13th 04 05:07 PM
