Stalls and Thoughts
Old March 15th 08, 05:10 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Default Stalls and Thoughts
Roger wrote:
On Fri, 14 Mar 2008 09:16:28 -0700 (PDT), "Ol Shy & Bashful"
On Mar 14, 11:11 am, "Ol Shy & Bashful" wrote:
What the hell.....why do we work at teaching stalls and recoveries? It
has gone to stall recognition and avoidance which is good. Does it
teach the proper things? How much of a new students time is spent
flying in slow flight at the low end of the performance envelope?
Isn't that where all the nasty things can happen?
I fly with students that become paranoid when they hear the least
little blip from the stall waring horn, and want to push the nose over
to get airspeed back. They fail to realize the whole point of the
training.
OK Here we go....... I teach slow flight with and without flaps at the
lowest edge of the flight envelope and req
what the hell happened?...... and to follow on to the above.....
flight envelope and require my students to make a lot of turns to
headings while holding altitude and airspeed. I'll have them pitch
slightly to nibble on a stall while in the turn and even to go into a
stall and recover back to the nibble area instead of pushing the nose
over and watching the VSI go to 1000fpm and lose 100'+ while the
airspeed goes back up to Vx.
We are learning to avoid a stall when altitude is at a premium either
on approach or on a departure or go-around. How much altitude can be
sacrificed?
What the hell...lets have a donnybrook on the issue and keep things
interesting.
Ol S&B
I think all of the above are important and particularly so if the
pilot moves up to high performance or even plans on doing so.
Even in my last flight review we flew around at minimum controllable
airspeed for a while.
To back up, I think only teaching stall avoidance is out right bad and
dangerous. I say that as there are times if I pilot flys enough they
are likely to encounter an inadvertent stall even when playing by the
rules. An unexpected vertical gust in one instance. A very strong
gust from the rear is another . In the latter the wing may not be
stalled or it may be, but the lift has been drastically reduced.
But...flying around for a while in a Bo at Vmc all the while nibbling
at a stall while making shallow turns and holding altitude is quite an
exercise. For one, if it's hanging on the edge of a stall and you use
an aileron to raise a wing you just may stall that wing. which
results in a very fast roll to inverted if the pilot doesn't catch it
with the rudder. The Deb and F33 WANT to drop a wing and spin. Their
stall characteristics are very different than the 150, 172, and
Cherokees used in training. In doing stalls like this they are an
absolutely rudder only airplane. When doing stalls the instructors
from the Air Safety foundation even _block_ the yoke to prevent the
pilot from using the ailerons.
Departure stalls even at full power aren't all that bad and although
abrupt can be done without losing any altitude. Accelerated stalls in
a coordinated turn are pretty much a non event. When the stall breaks
you just let the nose go in the direction it wants by easing off on
the back pressure. Uncoordinated can get interesting, or downright
exciting depending on the pilot. Again, if proficient instinct has
you pointing the nose in the direction it wants to go whether the top
wing is going over or the bottom one is going under. As soon as the
nose it pointed where it wants to go the roll stops and you can
recover but there is absolutely no time to stop and think about
recovery techniques. Approach stalls with gear and flaps down and
the plane becomes a different animal where the pilot has to know what
it's going to do. If you don't it'll show a nasty disposition by
turning around and biting the pilot in the back side leaving teeth
marks. It's going to want to drop a wing and spin. It becomes a
rudder only airplane. Touch an aileron and it will ABRUPTLY roll over
into a spin. These are best practiced at 5,000 or above.
With practice the pilot should be able to hold the plane in a stall
but it's like walking on a tight rope using the rudder for balance.
OTOH if back pressure is released (Don't shove the nose down) at the
first break it'll just fly on out of the stall with little or no loss
of altitude.
From what I've seen in trainers one of the biggest errors is "shoving
the nose down". It depends on the plane and conditions, but normally
the only thing needed to recover is release the back pressure on the
yoke.
www.rogerhalstead.com
All good points.
There actually is an argument that can be made about accident stats that
suggests the "avoid the stall through recognition" approach hasn't
been as effective in decreasing the stall/ spin situation as has the
improvement in general aircraft design.
Actually this argument can be made for both the period when spin
training was in effect and during the period where stall recognition has
been stressed.
No matter how this pie is cut, and no matter what side of the argument
one is on, in my opinion there is absolutely no substitute for pilots
seeking out and taking some kind of advanced program after the
certificate has been obtained, that deals directly with extreme unusual
attitude recovery, spins, and advanced stall training.
As an aerobatic instructor, one has the opportunity to fly with all
kinds of pilots who have come through the program; each one taught by a
different instructor. You just wouldn't believe the skill differences in
these pilots. Those coming through a learning curve involving emphasis
on accuracy in stall RECOVERY as opposed to stall recognition, in my
opinion are better prepared and posess a much higher degree of basic
flying skills than their "recognition" counterparts.
The bottom line on this issue is that it's quite simple really. The
deeper a pilot goes into the basics involving flight in the left side of
the envelope, the better that pilot will be.
This reason is the exact reason I stress post license training so strongly.
Dudley Henriques
Old March 15th 08, 05:25 PM posted to rec.aviation.piloting
Denny
Ahh common Dudley, admit it... The only reason you want the student to
get inverted so's you can dream about pulling through the split S and
bringing those 50's to bear just ahead of the bogey....
denny
Old March 15th 08, 05:40 PM posted to rec.aviation.piloting
I spent a fair amount of time, probably close to an hour or two in
slow flight. Maybe a little longer.
I don't think it's the case that slow flight is where all the nasty
things can happen. A stall can happen at any speed in any flight
attitude, and may be worse at higher speeds in certain attitudes than
low speed, upright, straight and level.
Old March 15th 08, 06:00 PM posted to rec.aviation.piloting
denny
To tell you the truth, I spent most of the time teaching them to ROLL
out instead of pulling through that Split S :-))))
Dudley Henriques
Old March 15th 08, 08:19 PM posted to rec.aviation.piloting
On Mar 15, 12:13*pm, Bertie the Bunyip wrote:
wrote in news:925e8025-8f81-4991-9a0b-
Yup, your approach is certainly consistent with the PTS. Private
pilots are expected to perform slow flight at "an airspeed at which
any further increase in angle of attack, increase in load factor, or
reduction in power, would result in an immediate stall", and recover
from power-off and power-on stalls "with a minimum loss of altitude
appropriate for the airplane".
There's a difference between being able to demonstrate this and being
comfy or even competent doing it. .
That's true.
The CFIs who taught me treated practice stalls as routine and expected
their students to do so too. But I don't know if that's typical these
days, or if I was just lucky.
Old March 15th 08, 08:24 PM posted to rec.aviation.piloting
On Mar 14, 2:40 pm, Deadstick wrote:
I haven't done any instructing recently, but when I did, I taught slow
flight, stall recognition and avoidance AND stall entry & recovery. I
don't think they have be be exclusive of one another.
Plus I think learning to recognize and avoid stalls is probably a
better risk-management strategy given that it can be easily learned
and mastered by pilots of all skill levels. In principle I agree that
ALL pilots should be fully competent at slow airspeeds and at
recovering from stalls, but I would also tend to say that there's a
lot more that we can teach pilots before we set them free to fly on
their own.
I am curious as to the meaning of the phrase "..dragging it in". As
in "...he turned on final, dragging it in".
I knew a pilot at A&M who died in a C182 while "dragging it in". I
assumed at the time that this was slow flight and without further
details could only assume that he inadvertently stalled the plane at
some point.
I also inferred that this phrase could also say "was behind the power
curve".
Any thoughts would be appreciated. (IIRC, he did not spin in).
Richard
Old March 15th 08, 08:28 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
wrote in news:7bcc745a-a5d6-4731-84a6-
their own.
some point.
curve".
That's generally how I understand that expression ot mean. Even for short
field stuff it's unnecessary to do that, IMO.
Bertie
Old March 15th 08, 08:33 PM posted to rec.aviation.piloting
their own.
some point.
curve".
Richard
The analogy "dragging it in" refers to having the airplane configured
behind the power curve or if you wish, in the area of reverse command,
on final approach....a very dangerous situation.
Dudley Henriques
Old March 15th 08, 09:05 PM posted to rec.aviation.piloting
Dan[_10_]
Dudley Henriques
Dangerous, but certainly useful at times!
Thinking about stalls WingFlaps Piloting 43 April 12th 08 09:35 PM
Stalls?? Ol Shy & Bashful Piloting 155 February 22nd 08 03:24 PM
why my plane stalls Grandss Piloting 22 August 14th 05 07:48 AM
Practice stalls on your own? [email protected] Piloting 34 May 30th 05 05:23 PM
Wing tip stalls mat Redsell Soaring 5 March 13th 04 05:07 PM
