Any vision challenged pilots that can give some advice?
Old March 16th 08, 09:02 AM posted to rec.aviation.piloting
akjcbkJA
Default Any vision challenged pilots that can give some advice?
"Paul kgyy" wrote in message
I've flown my Arrow for 7 years with progressives, got my IR with
them, never a problem.
Progressives do the job for me
Old March 16th 08, 05:08 PM posted to rec.aviation.piloting
Bob Gardner
I had no problem flying with trifocals. My eye doc was a pilot, which
probably helped..."Look at the approach plate...set the altimeter...scan for
traffic..."
Bob Gardner
"Kirk Ellis" wrote in message
Before I ask my question thought I'd throw out a few words on my
background. After nearly a lifetime of pent up desire to fly I finally
got my PPL in 1998 at the young old age of 45. Last week I just turned
55 and unfortunately in the last ten years I have been able to log
only about 140 hours total. I have not been able to afford to fly as
much as I'd like. But that's finally beginning to change and I am
getting ready to transition from the Archer III which I last flew
more than 15 months ago to a DA40 with the G1000. Admittedly I've got
some catchin' up to do.
Now to the real reason of the post. For the last 5 years I have been
good with distant and intermediate vision albeit I have had a
restriction to carry glasses for up close reading. But these last 5
years have seen a slight decline in my distant vision as well as the
intermediate due to both presbyopia and astigmatism. Now I need
correction for all three vision distances, close up, intermediate and
infinity.
I have been to an optometrist who speciallizes in vision correction
for pilots and he has suggested progressive lenses to handle all 3
vision tasks. However, what he is prescribing is contrary to the AOA
information I see online that warn pilots to NOT use progressives for
flying due to distortion affects. I understand about the distortion
because I have been using progressives for over a year for other
tasks.
I asked about bifocals, but the eye doc said that's not a good thing
because of glare coming off the separation line and yet the AOA
recommends bi-focals and even tri-focals as the preferred solution for
pilots. I hear from some people that tri-focals are very annoying and
bifocals work better.
But how do you resolve the need for 3 focal distance with only
bifocals?
What I found interesting in the 3rd class vision requirements is that
if your far sight is not at least 20/40 you HAVE to wear glasses. If
your near sight (16 inches) is not at least 20/40 you just have to
carry the glasses with you. But there is no requirement for the
intermediate vision at around 30' - 32" which is right where the glass
panels sit in the DA40.
Seems that with glass cockpits becoming the norm the intermediate
distance is much more important. I still don't completely undersand
why the intermediate with a third class did not have any restrictions.
I assume they thought the hands on the standard analog instruments
where easy enough to see.
But the glass displays have so much digital information on them, that
it's not so easy for me to see the smaller print in focus without some
correction. I will need 3 way correction, but I am not all that
enamored of using trifocals. I think I can live with Bi-focals unless
the glare, as my doc mentioned, is a real problem. But they would have
to be set for intermedaite and distance to make sense to me in a glass
cockpit. However, what about the times you need to focus at the 16"
distance to read sectionals and charts? Perhaps an extra set of
bifocasl that has distance and near and you just switch.
It doesn't seem there is any optimal solution to this delimma and
those 2 pair is the only way I can figure to solve the problem. It's
just double the money and I am still concerned about the glare aspect
of bifocals the doc mentioned.
So what do other pilots opt for in vision correction in this glass
cockpit era?
Kirk
Kirk
PPL-ASEL
Old March 17th 08, 01:16 AM posted to rec.aviation.piloting
Vaughn Simon
I have been flying with progressives for some ten years. I never had a problem
adapting to the progressives, and am at a loss to understand why anyone would
want to deal with lines in their vision if they didn't have to.
There is one tiny issue that I have noticed with my flying, but find it more of
a curiosity than a problem. After I first roll out on final, I have had more
than one CFI complain that I was not lined up with the center line. (I always
arrive in the right place @ the numbers, so I see this as a non-problem.) In
fact, I think that the issue may have disappeared completely as I have learned
to concentrate on an imaginary extension of the center line as my cue and not
the apparent angles of the runway.
Vaughn
Old March 17th 08, 01:13 PM posted to rec.aviation.piloting
Neil Gould
Recently, Vaughn Simon posted:
a problem adapting to the progressives, and am at a loss to
understand why anyone would want to deal with lines in their vision
The reason may be due to a person's prescription. I can't stand
progressives because, for my prescription at least, there is almost no
peripheral vision. To see anything a few degrees off-center, I had to turn
my head. When reading a book (or worse, a chart), only a few words in a
paragraph were in focus. With my "hard line" bifocals, I have normal
peripheral vision for both distance and reading, and the hard line is not
in my "distance" field of view. Of course, I had them custom made by
someone familiar with the tasks associated with flying.
Different strokes...
Neil
Old March 17th 08, 03:06 PM posted to rec.aviation.piloting
Frank[_5_]
"BT" wrote in message
I've read the posts on Progressive lenses and Bi / Tri focal lenses. And I
have both.
I need glasses for distant vision correction and have since my early teen
years. For years I flew in the USAF with prescribed contact lenses, or
regular single prescription lenses to correct for distant vision and the
younger eyes can adjust just fine for up close work.
But we age, and now I have to correct for near vision.
The eyes are too old to make that forced correction on their own and can
no longer adjust from the distant to near with my "distant" corrective
lenses.. For most of my work, I wear the contacts and keep reading glasses
handy for computer and reading. Now the time has come that I cannot read a
VFR chart or a standard sized approach chart without reading glass
assistance if I have my contacts on.
I know many pilots that have fine distant vision, but use the half high
reading glasses in the cockpit.
I have used bifocals and find them workable, I am able to read the glass
cockpit panels with no problems at the intermediate range.
I have progressives, I have found from driving a car with the progressive
lenses that the periphery vision is blurred.. not as clear as looking out
the sides of my bifocal lenses. This gives me concern that if flying with
my progressive lenses that distant objects (aircraft) in the periphery
will not be clear and in focus and could easily be missed. I find that I
have to look directly at what I want to see and then adjust my view
vertically with the progressive to find the clearest picture. Not what I
want to be dealing with while flying.
A fellow pilot prefers the bi focal, with the line, he knows which part of
the lenses he is using to see out the window, and to see his instrument
panel. His glasses are adjusted, so that at normal sitting position, the
line of his bifocal is right at the line of the glare shield.
I was using trifocals, both regular and blended. Once I got used to it, the
blended was, at least for me much superior.
Then I got a slight case of cataracts, and elected to have the Crystalens
implanted. This basaicaly replaces the original, no longer flexible natural
lens with an accomodating lens that focuses both near and far - the lens
actualy moves back and forth in your eye.
After about 3 months of training I don't need glasses at all. I am very
happy with the results.
Frank
Old March 17th 08, 08:55 PM posted to rec.aviation.piloting
Ken S. Tucker
Neil
When I was 30ish I got a physical and eye test for my
PPL, and found out I was near-sighted, needed glasses
to fly. I was (still am) a nerdy book-worm type, but I used
eye exercize and now at age 55 don't need glasses to
pass the eye test. I'm also a smoker (since age 12) and
a drinker (since age 30) , which is claimed to be causal
to coronary hardening.
What I did was used a pirates eye-patch to exercise each
eye. I made sure I could focus on distant land scape and
also read the fine print on bottles, with either eye.
However, I still prefer some correction, for exceptional
clarity, but the required correction is reduced, IOW's
my eye's have improved using excercize.
IIRC, there are 6 muscles in the standard eyeball that
distort the lense to produce focus, so by boosting
those muscle stengths one can improve vision.
Ken
OSH Homerun? Glass Cockpit for the Budget-Challenged Marco Leon Piloting 4 July 27th 07 11:27 PM
Advice To Aspiring Military Pilots Mike Kanze Naval Aviation 0 September 22nd 04 09:49 PM
North Island NZ glider pilots, farm/ranch stay advice pls Kizuno Soaring 1 September 22nd 04 01:37 PM
Cuts to Stealth Force Challenged Henry J Cobb Military Aviation 0 March 6th 04 03:22 PM
Did commercial glider pilots used to give instruction? Mark James Boyd Soaring 7 December 19th 03 07:51 AM
