A Call to Arms from Richard VanGrunsven
Old March 18th 08, 04:49 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Jay Maynard
Default A Call to Arms from Richard VanGrunsven
On 2008-03-18, Highflyer wrote:
The FAA did precisely that with the S-LSA certification process. It greatly
simplified the proof and oversight needed to ensure an adequate standard for
aircraft that cannot endanger a lot of unsuspecting people. That is why
they limited them to slower airspeeds and lighter weights as well as two
places. They are also only allowed to fly Daytime and by Visual flight
rules.
Not true. They can fly IFR or night VFR if properly equipped. That's one big
reason I wound up with a Zodiac XLi. The key is that no part of the aircraft
must have manufacturer's instructions prohibiting night or IFR operations,
and their equipment must meet the minimum standards of the rules. This
means, for example, that the aircraft must not be powered by a Rotax 912ULS
or Jabiru 3300, both of which have manufacturer's instructions limiting them
to day VFR.
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June)
  #142
Old March 18th 08, 05:26 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Steve Hix
greatly
for
rules.
As long as you have a Private Pilot rating, or above.
That's one big
to day VFR.
  #143
Old March 18th 08, 05:39 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
jan olieslagers[_2_]
greatly
for
rules.
This was about plane certification, not about pilot rating.
  #144
Old March 18th 08, 02:34 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Peter Dohm
"Steve Hix" wrote in message
greatly
standard
for
why
two
rules.
That's one big
aircraft
operations,
912ULS
them
to day VFR.
I am not sure of the phrasing on that last part, regarding the engines; but
engine and propeller combinations not certified under parts 34 and 35 (IIRC)
are not supposed to be approved for night IFR.
Several contributors here are much more knowledgeable of the specifics.
Peter
  #145
Old March 18th 08, 03:28 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Steve Hix
jan olieslagers wrote:
greatly
for
rules.
Nevertheless, whether or not you can legally fly one at night or in IFR
conditions is dependent on pilot rating as well as installed equipment.
Things may be different on your side of the pond, but SLSA applies over
here, and pilot certification affects legal use.
  #146
Old March 18th 08, 06:27 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Gig 601XL Builder[_2_]
Peter
The SLSA version of the 601XL built by AMD can be flown both IFR and VFR
day or night. It all depends on your ticket.
  #147
Old March 18th 08, 09:32 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Jay Maynard
On 2008-03-18, Steve Hix wrote:
Jay Maynard wrote:
Not true. [LSAs] can fly IFR or night VFR if properly equipped.
True, and, for that matter, as long as you're not operating under the sport
pilot rules with just your driver's license as medical.
I was referring strictly to the aircraft. As always, there are a lot more
rules that apply to any given operation than just those.
http://www.hercules-390.org (Yes, that's me!)
Buy Hercules stuff at http://www.cafepress.com/hercules-390
  #148
Old March 18th 08, 09:34 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Peter Dohm
"Gig 601XL Builder" wrote in message
but engine and propeller combinations not certified under parts 34 and 35
(IIRC) are not supposed to be approved for night IFR.
Peter
I took a look on their web site, and saw that they are using the Continental
O-200, which appears to be consistant with what I supposed.
Peter
  #149
Old March 18th 08, 09:46 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Peter
Peter
But I don't think that particular Sensenich propeller is certified.
  #150
Old March 18th 08, 09:54 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Jay Maynard
The certificated version of the O-200, and a certificated Sensenich
composite prop, and TSO'd instruments and avionics. There are only two LSAs
(well, the other one's actually a family of closely related aircraft) that
meet those requirements, the other one being the Tecnam Bravo/Sierra.
There's at least one LSA manufacturer that claims LSAs can't be legally
flown IFR, but I strongly suspect that's because they don't offer one.
Flew home and boy are my arms tired! Steve Schneider Owning 11 September 5th 07 12:16 AM
ASW-19 Moment Arms jcarlyle Soaring 9 January 30th 06 10:52 PM
[!] Russian Arms software sale Naval Aviation 0 December 18th 04 05:51 PM
Dick VanGrunsven commutes to aviation Fitzair4 Home Built 2 August 12th 04 11:19 PM
Small arms locker questions Red Naval Aviation 4 July 30th 03 02:10 PM
