BA 777 crash at Heathrow
Old March 18th 08, 05:15 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Default BA 777 crash at Heathrow
Big John wrote in
On Tue, 18 Mar 2008 03:33:41 +0000 (UTC), Bertie the Bunyip
Tina wrote in
news:f9919557-7cf1-4224-86c4-
Isn't it stretching things to think it would happen to both engines
at the same time when they are drawing from two different tanks?
That's stacking a lot of "If's" in a row.
It's not an if. When kerosene gets cold enough it waxes. Both tanks
were exposed to the same temps for many hours. Probably somthing in
the region of -65 C.
Bertie
Bertie
Before the Airlines started flying jets the Air Force ran into a fuel
problem in their jets at altitude. Can't remember now if it was ice
xtyls forming in the fuel or waxing as you say but the Air Force
started putting an additive in their fuel that stopped that problem
and the Airlines picked up on it when they started flying jets I was
told.
The basic problem was that the xtyls would form in the fuel and then
pack the filter and stop fuel flow.
Do the Airlines still use the/a additive in their fuel for the high
altitude problem?
Dunno. I know they used to put at least one additive in that had to be
added as the fuel was loaded. Prist was one such producet. but I've
never had anything like that added. whatever formula the fuel is made to
arrives at the airplane like that. I don't normally do flight long
enough or at lattitudes high enough to get fuel icing. I did have a
pretty exciting blocakge due to ice in avgas once, but never with
kerosene. I guess the lowest fuel temp I've seen is about -25C
Hope you had a good St Paddies day )
Working!
Erin go bre
Go Ma
Bertie
  #122
Old March 18th 08, 03:55 PM posted to rec.aviation.piloting
Robert Moore wrote in
46.128:
told.
I flew the first generation jets (B-707) for the first major operator,
PanAm. There was nothing in our manuals about a fuel additive being
used,and we bought fuel all over the world. We used bleed air to deice
the fuel filter. One minute ON every thirty minutes if Tank temp was
below zero degrees centigrade or one minute ON if any icing light
illuminated.
However, if the tank temp dropped below three degrees centigrade above
the freeze point of the particular fuel on board, the pilot was
required
to take one of the following actions:
1. Increase IAS to warm up the wing.
2. Descend to a warmer cruise altitude.
3 Reroute to a more southernly route.
The fuel filter was located between the first and second stages of the
fuel pump. Any blockage of the filter opened a bypass around the fuel
filter. So....a blocked filter would NOT stop the fuel flow. Actually,
there were two bypasses, one as just described and a second one around
both the pump first stage and the filter.
I would strongly suspect that Boeing still provides at least this same
level of protection for its current generation of jetliners.
Nope. And I have no idea why. The A300 didn't have one either.
There's certainly no control for it in the flight deck, and if there was
an automatic syste, they would have had to have told us about it since a
malfunction would mean an insanely high oil temp. ( I had three
shutdowns in 727s due to fuel heat getting stuck on)
altitude problem?
Never did as far as I know. The corporate guys do add Prist, probably
due to the much thinner wings.
Yeah, I've never seen it added to an airliner's fuel either. I've a
vague recollecton of seeing prist added to a lear's fuel with a special
fitting on the fuel hose accepting a can of prist. But AFAIK we don't
have anything.
Bertie
  #123
Old March 18th 08, 08:15 PM posted to rec.aviation.piloting
Peter Clark
On Tue, 18 Mar 2008 15:55:12 +0000 (UTC), Bertie the Bunyip
have anything.
I might have this backward, just working into the jet buring world,
but are you loading Jet-A or Jet-A1? Generally isn't Prist in Jet-A
since it has a higher gelling point? I think Prist also has an
antimicrobial effect, helps in the Jet-A stuff that doesn't fly as
much as a jetliner.
  #124
Old March 18th 08, 08:44 PM posted to rec.aviation.piloting
Peter Clark wrote in
special
have anything.
much as a jetliner.
We use both, depending on where we're getting it. We also get some
oddball wide cut stuff in some places. It's fine, but we have to be more
careful loading as it lights up pretty easily. We don't pay too much
attention to what we uplift since we don't spend enough time at cruise
to get it cold enough to worry about. I don't know of any additives ever
added to anything i've flown. I did get a fuel blockage from water in
suspension in 100LL years ago, but I think they fixed that problem.
Bertie
[Fwd: Concord at Heathrow?] Markus Baur Aviation Photos 3 December 26th 07 11:55 PM
B747 at Heathrow Glenn[_2_] Aviation Photos 0 December 8th 07 09:47 AM
A380 flew into Heathrow today Kingfish Piloting 82 May 30th 06 01:55 PM
Google Earth Heathrow 9L approach news.east.cox.net Piloting 23 April 20th 06 09:36 PM
