Rotary engines in WW1
Old November 13th 03, 03:10 AM
Mike Marron
David Windhorst wrote:
Not to mention 2-cycle racing motorcycles. I have great smell-memories
of attending bike races in my early teens, when the sport was less
stratified, and more grass-roots, run-what-ya-brung. Sitting around an
abandoned quarry turned into a scrambles track, bikes (many converted
from street use) from five or six different displacement classes
screaming around in circles under a cloud of sweet-fragrance blue
smoke...not very environmentally friendly, but a spectacle I'm glad to
have witnessed.
Although I have a 4-stroke behind me when I fly nowadays,
2-strokes have evolved into extraordinarily reliable engines
and I've accumulated more than 1,500 hrs. flying aircraft
equipped with "grassroot" 2-stroke engines. We normally
premix the oil 50:1 (not Castor oil) but except when starting
after a prolonged period of inactivity, they rarely emit the
characteristic blue 2-cycle smoke anymore. Given their
impressive power-to-rate ratio, 2-cycles are ideal for light sport
A/C. For example, in 1993 an intrepid Alaskan pilot flew a 2-stroke
over Mt. McKinley's 20,320 ft. summit, and on Sept. 29, 2000, Czech
pilot Jan Bem set a world altitude record of 26,546 ft. overflying
the peak of Annapurna, Nepal, in the Himalaya Mountains while
flying a 2-stroke powered trike. The U.S. military still uses 2-cycle
engines on numerous different remotely-controlled surveillance
drones.
Old November 13th 03, 04:47 AM
B2431
Just as a matter of curiosity why were rotary engines used?
Dan, U. S. Air Force, retired
Old November 13th 03, 05:15 AM
QDurham
Delicious weight/horsepower ratio. Simple, reliable. Being aircooled, perhaps
less liable to gunfire damage. Smooth operating. Available.
There is possibility that there still is a modern engine hidden in the concept.
Quent
Old November 13th 03, 07:55 AM
Keith Willshaw
"B2431" wrote in message
see
http://www.aviation-history.com/engi...ary-theory.htm
Keith
Old November 13th 03, 01:22 PM
Robert Inkol
One of the big advantages was that the rotary motion assured a
substantial flow of cooling air across the cylinders and cylinder
heads, even when the aircraft was flying slowly, or the engine was
instlled in a pusher configuration. This was very important since the
engineering knowledge and manufacturing technology available at the
time was not really sufficient to achieve satisfactory air cooling
with static cylinders. Most early attempts at air cooled aircraft
engines with static cylinders had limited success. At best, very rich
fuel-air mixtures had to be used to help with the cooling. In other
cases, such as the disasterous ABC Dragonfly (of which over 10,000
were ordered off the drawing board), the result was an engine that was
completely useless.
Robert
Old November 13th 03, 08:55 PM
David Windhorst
Quent
Rotaries got applied to motorcycles a few times, too, both to the rear wheel
http://www.motorcycle.com/mo/mcmuseu...tos/millet.jpg
and the front http://www.magpie.com/nycmoto/guggen...ola_engine.jpg
Gyroscopic effect and all that rotating mass reportedly made turning the
latter about like trying to roll an a/c into the rotational direction of
a big cubic-inch aviation powerplant.
Old November 13th 03, 08:59 PM
David Windhorst
Mike Marron wrote:
snip
drones.
Has the Orbital design been applied to any aviation 2-strokes? After
Honda licensed it in the 90s there was much anticipation of a new,
cleaner generation of high-output, lightweight 2-stroke bikes, but it
hasn't happened yet.
Old November 13th 03, 09:22 PM
QDurham
Mike wrote in part:Has the Orbital design been applied to any aviation
2-strokes? After
hasn't happened ye
My understanding is that by the time the *much* needed mufflers are added, and
the anti-smog stuff and the cooling stuff, the weight/power/space advantages
aren't all that wonderful.
And of course, in planes there has to be some sort of gearing (not lightweight)
so that the prop turns much slower than the engine.
Quent
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
