Mixing construction materials
Old October 5th 03, 08:27 PM
Neal Fulco
Default Mixing construction materials
In the " I wonder if this would work " department, I have a question
about mixing different materials in main airframe structures. To make
a long story short, I was wondering if some weight could be saved by
making a wing with a carbon fiber spar ( high strength, light weight )
with aluminum ribs and skins. Would the carbon and aluminum be
compatible? Of course an acceptable method would have to be devised
to attach the ribs and skins to the spar, but I don't see this as a
big problem. Since the spars are some of the heaviest part of the
wing, I thought this would be a good way to save some weight, and in a
case I have in mind, an easy way to join the spar to the fuselage,
especially if the fuselage is composite. I would want to keep the
rest of the wing aluminum mainly to save dollars, but also because of
the proven history. Would the weight savings be worth the effort?
Neal
Old October 5th 03, 11:27 PM
Rich S.
"Neal Fulco" wrote in message
om...
To make
Why mess with aluminum? Check out the construction methods for the new
CAP-10C wing at http://www.capaviation.com/. I'm not quite sure where this
link will take you - you may have to drill down a bit to reach to correct
page.
Rich S.
Old October 7th 03, 02:55 PM
Neal Fulco
(Bob Kuykendall) wrote in message . com...
Earlier,
could be saved by making a wing
strength, light weight ) with
I'm pretty sure a way can be found to make it work. But one awkward
aspect is the mismatch in Young's modulus between the spar and the
skin. See my earlier post on this topic:
http://groups.google.com/groups?hl=e...g.goog le.com
[Huge nasty Google link. Must be all on one line.]
Thanks, and best regards to all
As luck would have it, the day after I made this post, I received my
copy of Custom Planes which had an article about a modified Sukhoi
that had a carbon fiber spar with aluminum ribs, but it said it had a
composite skin.
Neal
Bob K.
http://www.hpaircraft.com/hp-24
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 04:07 AM
Carbon Spar design and construction workshop Marske Flying Wings Home Built 0 September 18th 03 06:47 PM
Worthy EAA Construction Books Brock Home Built 5 September 16th 03 08:48 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 06:12 AM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
