Cambridge data port pins
Old April 6th 08, 05:07 AM posted to rec.aviation.soaring
Andy[_1_]
Default Cambridge data port pins
Can someone please point me to the connector pin specifications for
the cannon D connectors on the 302 and the mode 25 GPS NAV. I'd
like to find out if the Cannon D sub connector on the 302 has the same
pin specification as the GPS NAV. I could not find the info in my
manuals or on the Cambridge site.
My 302 has stopped communicating with both my Aero 1500 PDAs and I
want to substitute a different cable for trouble shooting. I have a
PDA cable for the GPS NAV but don't know if it is compatible with the
302.
thanks
Andy
Old April 6th 08, 01:48 PM posted to rec.aviation.soaring
Gary Emerson
you can move your cable over. They are the same
302.
thanks
Andy
Old April 6th 08, 03:27 PM posted to rec.aviation.soaring
Andy[_1_]
On Apr 6, 5:48*am, Gary Emerson wrote:
you can move your cable over. *They are the same
Thanks.
I eventually found the glide nav PDA cable pinout and also found that
Cumulus Soaring shows the same cable part number for both units.
Seemed logical they would be the same but better safe than sorry.
Andy
Old April 6th 08, 05:33 PM posted to rec.aviation.soaring
Tim Mara
there is a pin-out diagram and kit for making your own cable on my website
page http://www.wingsandwheels.com/page11.htm
tim
"Andy" wrote in message
302.
thanks
Andy
Old April 7th 08, 05:11 AM posted to rec.aviation.soaring
Andy[_1_]
pagehttp://www.wingsandwheels.com/page11.htm
It turned out that my problem was not the cables, or the PDA, or the
302. Just another one of those inexplicable incompatibilities of the
Cambridge PDA utility. Attempting to download either of my flights
from April 5 will cause the utility to exit and lockup the 302 so it
does not transmit GPS data. Downloading any other flights stored in
the 302 works just fine. Cycling 302 power restores normal operation
as long as those 2 flights are not selected for download. Same effect
seen with 2 different PDAs and 2 different cables, and is repeatable
but not 100%. I did get lucky, but only once, and was able to
transfer the flight logs.
Andy
On the job with a port trucker: Port truckers like Marvin Palacios are the tiniest players in a prosperous global transport chain. But while big companies cash in, drivers barely make Goteborgbank Naval Aviation 1 October 13th 07 02:44 PM
Cambridge 302A Data integrity. Bob Soaring 4 June 6th 07 02:04 PM
Cambridge 302 -or- Borgelt B50 plus data logger Romeo Delta Soaring 25 May 30th 04 09:50 AM
