Adding an airplane rating to private pilot glider
Old April 8th 08, 04:07 AM posted to rec.aviation.soaring
sisu1a
Default Adding an airplane rating to private pilot glider
On Apr 7, 7:33 pm, Tony Verhulst wrote:
Other things to get used to: You don't need airbrakes because the whole
plane is just one huge airbrake. When your approach is too high, just
push, the airspeed won't increase.
That works (to a point) in a Cessna. Try that in a Mooney and you'll get
a very close look at the numbers on the far end of the runway as you go
by them. It depends on the airplane.
Tony
Don't they put airbrakes on those Moony things, some type of dragons
teeth arrangement?
Paul
Old April 8th 08, 05:27 AM posted to rec.aviation.soaring
BT
Yes it will, it depends on the airplane.
BT
Old April 8th 08, 05:30 AM posted to rec.aviation.soaring
BT
"Steve" wrote in message
news:vfAKj.3242$N62.1743@trndny07...
My experience was similar - about 35 hours SEL for the ticket. And my
challenges were similar to those previously reported. However, I'd be
curious how many hours is typical for ab initio? I've heard it's a rare
student that gets by with the minimum.
A discussion last year in Rec.Aviation.Students revealed that the national
average is 65-70 hrs with 40 being the required minimum.
BT
Old April 8th 08, 03:15 PM posted to rec.aviation.soaring
On Apr 7, 6:53*pm, J a c k wrote:
Doug,
Stick with it, you'll find a reason in just a few more hours: there are
dozens of them. Don't ever think you've seen it all in aviation.
Jack
Jack,
Of course I haven't seen it all. I'm sure I'll be presented with a
good reason to do a go around. Hopefully though it won't be because I
didn't fly the pattern properly.
Doug
Old April 8th 08, 05:27 PM posted to rec.aviation.soaring
Ralph Jones[_2_]
On Mon, 7 Apr 2008 14:19:52 -0600, "Bill Daniels"
bildan@comcast-dot-net wrote:
[snip]
Then one day as I was putting down a very long, slow approach waiting for
the corporate jet on the runway to finish his checklist, I started thinking
about go-arounds. It suddenly occured to me that if an airplane were to
taxi onto the runway at the last second, I might revert to glider technique
and land the airplane on the grass between the runway and taxiway. Hmmm....
That might be very hard to explain.
I called the tower and asked for a low pass over the numbers and a go-around
to get some practice with the throttle thingy.
The go-around merits as much training and practice as any other
maneuver. In certain situations -- a Cessna with full flaps, for
instance -- there is a great deal of opportunity to screw it up. And
when you do screw it up, you're likely to be doing so in close
proximity to another airplane that may or may not know you're there...
rj
Old April 8th 08, 06:28 PM posted to rec.aviation.soaring
rj
Ralph I fly a 1966 150, that year still had 40 degree flaps. I'm
curious what you find more challenging about the Cessna with full
flaps? Perhaps I mis spoke as Hillary would say....it's not that I
don't think the maneuver should be taught, it's that I don't think
enough emphasis is placed on nailing your landing the first time
around.
Doug
Old April 8th 08, 08:48 PM posted to rec.aviation.soaring
Ralph Jones[_2_]
On Tue, 8 Apr 2008 10:28:09 -0700 (PDT), "
rj
around.
Agreed, the later Cessnas will protect you from some degree of folly
with less flap extension, but you still have to arrest your descent in
an airplane with very little thrust margin. You have to do it quickly,
with a rapid power increase, rapid onset of P-factor, and you may have
to maneuver horizontally at the same time. If you don't know exactly
what the conflict is, you may be descending on top of somebody who
made a straight-in out of sunlit haze...I've seen a few very dicey
situations just like that.
It's not that the go-around is especially hard: just that it's as
important to master as any other maneuver your airplane can do. You
really should be able to land without stalling as you turn final, too,
but in my CFI'ing days I wouldn't have let you get off without
learning to recover from that.
rj
  #28
Old April 8th 08, 09:03 PM posted to rec.aviation.soaring
rj
OK, now we're getting somewhere! I fully agree with you and it brings
up another pet peeve of mine about power that gliders don't seem to
suffer from. It's called Courtesy. Somehow a glider field can have
gliders all over the place, more than one in pattern, the towplane
taking off with someone in tow etc.... all at the same time and we
somehow manage to get through the day.
On the power side, I've come across more clueless Yoke holders busting
patterns, not using a radio, cutting people off, descending without
looking, overtaking and the list goes on.
So if you have to use a go around to save yourself from the clueless,
that's fine by me!!!
Doug
  #29
Old April 8th 08, 09:35 PM posted to rec.aviation.soaring
On Apr 7, 3:01 pm, "
On Apr 7, 3:28 pm, wrote:
the go around is more often used for those times when someone or
something decides to make use of the runway during the time you were
going to land on it. like, when a glider pulls out to stage for
takeoff.
You must fly at an airport with amazing power pilots! I get to see
about 3 or so go arounds each weekend.
Doug
nah i get to see a lot of go arounds from the right seat while my
students are learning to fly the pattern. and we have really long
runways so even when they goof it is usually still safely salvageable.
  #30
Old April 8th 08, 09:50 PM posted to rec.aviation.soaring
students are learning to fly the pattern. *and we have really long
That might be the difference, where I fly it's SHORT as in SHORT not
much room for error.
Doug
sport airplane from private glider Andy[_1_] Soaring 5 November 28th 07 01:29 AM
FA: 1-Day-Left: 5 AVIATION BOOKS: JEPPS, Instrument Rating, IFR, Private Pilot Maneuvers, Pocket Simulator, etc. Jeff[_6_] Aviation Marketplace 0 October 20th 07 02:05 PM
FA: 5 AVIATION BOOKS: Instrument Rating, IFR, Private Pilot Maneuvers, Pocket Simulator, JEPPS, etc. Brent Aviation Marketplace 0 October 8th 07 03:28 AM
endorsements for private pilot glider rating Joel Taylor Soaring 2 October 2nd 03 06:44 AM
Private Pilot Glider Rating Requirements John Soaring 8 August 21st 03 01:09 AM
